Help with simple etherchannel
Andy White
Level 7
Level 7
For a simple etherchannel to work between 2 switches I have configured ports 1 and 2 on both cisco 2960 switches with the channel-group option like this:
interface FastEthernet0/1
channel-group 1 mode on
interface FastEthernet0/2
I thought the port-channel 1 would get automatically created but it didn't, should it?  And under the port-channel interface should I set this as a trunk or do I do this on the 2 fa interfaces on each switch?
darren.g
Level 10
Level 10
You need to create the port channel interface on each switch as well. And you need to set both the port-channel interface and the individual ports exactly the same - so if you set one as a trunk, you need to set ALL of them as a trunk
So you need something like this
interface port-channel 1
description switch link
switchport mode trunk
switchpore mode trunk
Put that into each switch (etherchannel numbers are only lcoally significant, so you can use the same number on each switch), and then issue the command
show int port-channel 1 etherchannel
to verify that the link comes up with both ports active.
Cheers.
Willard Dennis
Level 2
Level 2
I do not believe that you have to create the "Port-channel1" interface yourself as the previous comment indicates - I did the same thing as the original poster on a pair of 2960's (albeit running in Packet Tracer) and as soon as I did the configs on Fa0/1 and Fa0/2 on both sides, I could see that IOS had created the "Port-channel1" interface (pic attached.) Now, I would do further config using "int Po1" and any config entered against this interface will flow down to the physical int's (f0/1 and f0/2 in this case.)
Best,
Will
Hi Dennis,
Once create a channel group in physical interface automatically port channel is getting created. But in port channel you need to define the vlan and its informations as well. like stated in the below.
interface Port-channel1
description SWa-SWb
switchport trunk native vlan [v]
switchport trunk allowed vlan [v],[v2]....
switchport nonegotiate
no shutdown
So that it will work. If you mention access in one end and other end if you have trunk... then it will not take. If you are etherchanneling 2 ports then both the ports should be with same configuration on both the ends.
Hope this makes clear.
By
Karthik
