Help with switching and routing
Grant Serbousek
What am I missing?
I've got a verizon fios router (IP 10.1.1.2) acting as DHCP server for network 10.1.1.0/24. I have a route configured: destination: 192.168.10.0/24 and gateway 10.1.1.2.
Connected to a Cisco C2950G all in VLAN1 (to be edited later) distributing the 10.1.1.0/24 network, that connects to an Apple Airport extreme in bridge mode.
A Cisco 2611XM router f0/0 ip 10.1.1.249 connected to the airport extreme listed above. Interface f0/1 ip: 192.168.10.235 and a DHCP server configured on this router for the 192.168.10.0/24 network.  Interface 0/1 is connected to a Cisco 3512 also all on VLAN1.
1) Host connected to Cisco 3512 (192.168.10.0/24 network) won't get a default gateway from my router.  Why?
2) Host connected to Cisco 3512 (192.168.10.0/24 network) can't ping my Verizon router (10.1.1.2) - I get a "PING: transmit failed. General failure". Why?
3) Host connected to Airport Extreme (10.1.1.18) can ping Cisco 2611XM router f0/0 (10.1.1.249) and f0/1 (192.168.10.235) but cannot ping a host (192.168.10.2) connected to the 192.168.10.0/24 network via Cisco 3512.  Why?
4) I can't ping google.com from the switch.  Why?
version 12.4
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone EST -5
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip dhcp use vrf connected
ip dhcp pool america
import all
network 192.168.10.0 255.255.255.0
dns-server 10.1.1.2
ip name-server 10.1.1.2
vlan internal allocation policy ascending
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 10.1.1.0 255.255.255.0 FastEthernet0/1
ip route 192.168.10.0 255.255.255.0 FastEthernet0/0
no ip http server
no ip http secure-server
version 12.4
service password-encryption
hostname TESTBED-01-2611XM
boot-start-marker
boot-end-marker
aaa new-model
ip cef
import all
dns-server 10.1.1.2
interface FastEthernet0/0
ip address 10.1.1.249 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.10.235 255.255.255.0
duplex auto
speed auto
no ip http server
control-plane
G
2 Accepted Solutions
Wilson Bonilla
Level 3
Level 3
Hello.
Can you post a topology diagram?
If the DHCP server is in a different vlan from where the users are you should have a relay agent to help the users reach the server leasing ip addresses.
What IP address are the users currently getting?
Regards.
Wilson B
Ping Transit Failed is because of routing Loop or bad Routes.
Jawad
Wilson Bonilla
Level 3
Level 3
Hello.
Regards.
Wilson B
Jawad
Thanks to those who replied...and yes, my routes were bad.
Instead of the following routes:
I should have had the single static route:
ip route 0.0.0.0 0.0.0.0 10.1.1.2
Q1)  I did not have the "default-router" configured in my DHCP pool - why my client wouldn't get a default gateway.
Q2) Answered via proper static route above
Q3) Also attributable to not having a default router configured for the DHCP pool.
And now it works.  I hope this helps someone in the future.
