Cisco 3500XL
gillbard.jerome
I am trying to configure a 3500XL switch (and I know its old). I get to the int fa 0/1 line and thats where it all stops working.
switch#(config-if)#switchport mode access
switch#copy run start
or
switch#sh run int fa 0/1
It will show the configuration for port fa 0/1 as if I hadnt entered the "switchport mode access" command. Or any other command for that matter.
Any ideas why the switch is not holding configuration and seemingly loses it as soon as you exit out of each interface?
Jerome
HI,
Also Please let us know the software version running on the switch?
Second provide the show tech/run config from the device? Does all other config appers on the switch?
REgards
Inayath
mhnedirli
which vlan do you want to assign. you can see port status with "show int f0/1 switchport"
Switchport: Enabled
Administrative Mode: static access
Operational Mode: up
Administrative Trunking Encapsulation: negotiate
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Operational Native VLAN tagging: disabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
HI,
REgards
Inayath
Gregory Snipes
Level 4
Level 4
"switchport mode access" is a default command in the 3500XL switches and as such is not displayed. The 3500XLs were released prior to Cisco moving to dynamic desirable being the default mode.
gillbard.jerome
Hi all,
Thanks for your responses, I have now fixed the issue. I updated the software - which fixed all issues I was having. I would have done this earlier, but the switch is only a very temporary solution so I didnt want to spend too much time on it.
Thanks for your assistance.
