11-25-2017 12:18 AM - edited 03-08-2019 12:52 PM
Guys I have an assignment in one of my routing/switching classes and I just cant' figure it out. I've literally redone this 4 times and I can't figure it out. I'm following all the instructions I can find to a T. What am I doing wrong ?
I can ping PC2 and PC3 from the router and from each other but I can't ping PC1. I have no idea why. Is the default gateway for the switches wrong? I don't get it.
I have attached a file with the assignment. Please someone give me an idea of why I can't ping PC1. (in this version, I haven't done the serial links yet - I know how to get that working - what I cant' figure out is pinging PC1!)
I'm sure you'll want some information from my routers and switches - just let me know what exactly you need! Thanks
Thanks!!!
Solved! Go to Solution.
11-25-2017 03:53 AM - edited 11-25-2017 03:54 AM
The issue you are experiencing is related to the native VLAN.
On interface FastEthernet0/24, add the following command;
#switchport trunk native vlan 70
The reason it is not working is because the switch's trunk port on FasEthernet0/24 is sending the PC1 traffic with a dot1q tag. The router receives the frame, but drops it because it expect VLAN 70 to be native (untagged), because you have configured the router's VLAN70 interface to be the native vlan.
Just tested this is packet tracer, can reproduced the issue and adding the native vlan to the trunk worked.
Hope that helps!
11-26-2017 09:56 PM
On R1, you need the advertise the connected networks through EIGRP and you need to do the same on R3. Once the networks are advertised, each router will know how to get to each network.
To advertise the PC1 network, you can configure R1 in EIGRP configuration mode with the following command. #network 172.16.8.1 0.0.0.255
On R3, you can advertise the server network in EIGRP configuration mode with the following command. #network 172.16.9.129 0.0.0.0.63
11-25-2017 12:27 AM
Here are my running configs :
R1:
Current configuration : 1041 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
description Sales
encapsulation dot1Q 10
ip address 172.16.9.1 255.255.255.128
interface FastEthernet0/0.20
description Support
encapsulation dot1Q 20
ip address 172.16.0.1 255.255.248.0
interface FastEthernet0/0.70
description Management
encapsulation dot1Q 70 native
ip address 172.16.8.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
no ip address
clock rate 2000000
shutdown
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
SW1 :
Current configuration : 2336 bytes
version 12.2
hostname Switch
switchport mode trunk
switchport access vlan 70
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
switchport port-security mac-address sticky
switchport port-security violation protect
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 10
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
ip default-gateway 172.16.8.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
SW2:
Current configuration : 2273 bytes
version 12.2
hostname Switch
switchport access vlan 20
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Hope that helps!
11-25-2017 11:18 AM
Thank you! I knew I had to set a native VLAN on the switch but I couldn't find out how!
11-25-2017 01:13 PM
Hey so I set up the EIGRP on all the routers through the serial. They can all communicate with each other now. They can all ping each other. But PC4 (the server) still cannot ping PC1. It says desitination host unreachable. Why do you think that is so?
11-25-2017 03:55 PM
Without seeing the rest of the config I can't be sure as this could be due to a couple of reasons.
1. Make sure all interfaces are in up/up state.
2. Make sure PC4 and PC1 have the correct default gateway.
3. Make sure each router has a route with EIGRP to the PC4 and PC1 subnet in its routing table, verify using "show ip route".
Hope that helps!
11-26-2017 09:45 PM
1 and 2 are correct (PC4 should has the 172.16.9.129 default gateway)
as for 3 - i'm not sure exactly what it should show but the ISP router doesn't have the EIGRP in its routing tables.
Do you have any idea what I should do ?
ISP>enable
ISP#show ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is not set
192.168.1.0/30 is subnetted, 2 subnets
C 192.168.1.0 is directly connected, Serial0/0/0
C 192.168.1.4 is directly connected, Serial0/0/1
ISP#show ip ei
ISP#show ip eigrp interface
IP-EIGRP interfaces for process 21
Xmit Queue Mean Pacing Time Multicast Pending
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Se0/0/1 1 0/0 1236 0/10 0 0
Se0/0/0 1 0/0 1236 0/10 0 0
ISP#show ip eigrp ne
ISP#show ip eigrp neighbors
IP-EIGRP neighbors for process 21
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
0 192.168.1.2 Se0/0/0 10 00:15:43 40 1000 0 3
1 192.168.1.6 Se0/0/1 14 00:15:43 40 1000 0 3
11-26-2017 09:46 PM
the ISP router can ping R1 and R3 but not PC4.
11-26-2017 09:56 PM
11-26-2017 09:57 PM
but R1 and R3 can already communicate. Do I still need to do this? I already advertised the networks - I didn't use the wildcard mask though.
11-26-2017 10:00 PM
OK this worked! But can you explain why? Before, I just advertised the different router's serial interface network (192.168.1.0)
11-26-2017 10:07 PM
The reason it was not working is based around how Routers operate at layer 3. Once a packet is received, the router looks at the destination IP address field inside the packet. Once it has the destination IP address, it needs to check its routing table in order to determine where to send the packet. In your case, the routers do not know how to get to that network because a route to that network does not existing in their tables. When you advertise the network in EIGRP, you tell all of your EIGRP neighbors about that network and they install it in their routing table, so that next time they receive a packet, they know how to get there.
If you need a more detailed explanation, let me know.
11-26-2017 10:12 PM
that makes some sense. Why didn't I need to do it on ISP?
11-26-2017 10:21 PM
11-26-2017 10:24 PM
thanks so much - one last thing. For the PPP with authentication should I use CHAP? It doesn't say which one to use and I heard CHAP was best for the default. So I should just do encapsulation PPP then ppp authentication chap on the S0/0/0 line on R1 and then again on the S0/0/0 line for ISP? That's it?
