09-11-2013 02:05 PM - edited 03-07-2019 03:25 PM
Hey guys i need yr help.
I have a router and a switch which i want to connect. Before that i want to make three vlans. I have this ip adress to use 172.26.0.0 and subnet mask 255.255.0.0. After this i will have to connect my small network to another small network of the same infrastructure. you can use any subnet and it does no matter how many host on each subnet. Thanks
09-11-2013 02:28 PM
Can you may be try to draw it up what you are trying to accomplish first part kinda makes sense that you want to connect a router and a switch and you want 3 VLAN's, not sure what do you mean by the second part, are you connecting two small networks to the same switch?
Are you may be trying to connect 3 networks to the same switch and the router and want to keep them completely separate?
09-11-2013 03:17 PM
Im trying to connect one router to one switch! all i need is the configuration and forming those three vlans plus subnetting of course! thats all i need so far! later i will have to do the same on other one router and one switch then i will connect those two network using point to point connection but first i want to configure the router and the switch and form a small network before i connect to anything else!
thanks
09-11-2013 03:37 PM
we can help you in configure in one Router and one switch.
we need some information to go further.
1 )Model number of the rotuer and Switch.
if your switch is not an L3 device then we need to do different configuration (ROS).
2 )you have mentioned you need 3 Vlans please provide us the range of the subnet that you need for each vlan
in the above you have mentioned 172.26.0.0/16 which means you can
your start ip is 172.26.0.1 to 172.26.255.255 the total number of host would be around 65534.
09-11-2013 05:43 PM
Don't worry about my switch or router model because its in PT!
The range also should not matter as long as you have three vlans. Maybe have 100 hosts or less in each vlan will help.
09-11-2013 05:59 PM
Let say i want 5 subnets and 60 hosts on each subnet!
09-11-2013 09:55 PM
The router and switch model matter because people need to know how to help you. Different hardware are configured differently...
For a start please provide thebinfo being requested...
Sent from Cisco Technical Support Android App
09-12-2013 11:15 AM
i want 3 subnet, the first will have 60 hosts the second 100 and the third 120 hosts.
the router model is 1800 series and the switch is 3350 series.
thanks
09-12-2013 05:51 PM
for the router you can try these config these config are just basic configs
Router configuration
1)interface for facing the internet
2)interface for facing to the Lan side
Interface Gigabitethernet 0/1
ip address (INternet IP )
Interface Gigabitethernet 0/2
description LAN
ip address 172.26.100.9 255.255.255.248
access-list 11 permit 172.26.0.0 0.0.255.255
access-list 110 permit 172.26.0.0 0.0.255.255 any
access-list 10 deny any
ip route 0.0.0.0 0.0.0.0 internet gate ip
ip route 172.26.6.0 255.255.255.0 172.26.100.10
ip route 172.26.7.0 255.255.255.0 172.26.100.10
ip route 172.26.8.0 255.255.255.0 172.26.100.10
on switch you can use the below config
configuration on the switch
use all the subnet has /24 subnet is easy purpose.
fine tunning has to be done... but for basic these config should be working.
configuration on the switch 3550 l3 device so intervlan communcation will be happeing
interface Vlan6
ip address 172.26.6.1 255.255.255.0
interface Vlan7
ip address 172.26.7.1 255.255.255.0
interface Vlan8
ip address 172.26.8.1 255.255.255.0
Interface Gigabitethernet 1/0/1
Description Uplink to switch 3550
no switch port
ip address 172.23.100.10 255.255.255.245
ip route 0.0.0.0 0.0.0.0 172.23.100.9
if you have any doubts then please let me know. As i said these are just basic configuration.
09-13-2013 03:30 AM
Hi Arsene Muhigirwa,
My advice you go for the following IP addressing schemes
1. Vlan 10 - 172.26.10.0 /24 valid ip - 172.26.10.1 to 172.26.10.254 , default ip - 172.26.10.1
2. Vlan 11 - 172.26.11.0 /24 valid ip - 172.26.11.1 to 172.26.11.254 ,default ip - 172.26.11.1
3. Vlan 12 - 172.26.12.0 /24 valid ip - 172.26.12.1 to 172.26.12.254 , default ip - 172.26.12.1
Steps to configure :
1. Create 3 vlans ( for e.g vlan 10, vlan 11, vlan 12 ) in the switch and assign the ports as a access port on which host systems are connected
2. Connect the router to the switch and configure that port as a trunk port to carry all VLAN traffic.
3. Then go to router and create 3 sub interface,one sub interface for each vlan . set the default ip address of all the vlans as a sub interface ip address.
Then try to communicate from host machine in one vlan to other system in anothe vlan.
09-13-2013 03:49 AM
This Url gives you a clear undestanding of how to configure L3 on switch 3550.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
09-13-2013 09:07 AM
Thank you guys this will work!
