Helper address in EVPN/VXLAN not working
dodgerfan78
I have an EVPN config for Cat9000 that is working from a L2 and L3 perspective. On the leaf switches, I put helper-address on the SVI that face the hosts. These SVIs are inside a VRF. The client send the DHCP Discover message but the leaf only bridges it into the VXLAN using the MDT rather than acting as a relay. Am I missing something?
This is the config I have:
ip dhcp relay information option vpn
ip dhcp relay information trust-all
interface Vlan1230
 description vni 11230 default-gateway
 vrf forwarding VRF1
 ip dhcp relay source-interface Loopback211
 ip address 10.5.38.253 255.255.255.0
 ip helper-address 192.168.255.1
 no autostate
end
LEAF4# ping vrf VRF1 192.168.255.1 source lo211
Sending 5, 100-byte ICMP Echos to 192.168.255.1, timeout is 2 seconds:
Packet sent with a source address of 10.5.0.164
Thanks.
This is what I needed to do: For the L2 leafs with Anycast GWs I needed to enable snooping. For the L2 and L3 Leafs, I needed to make the source the VLAN so that the scope could be determined properly.
Reza Sharifi
Does it make a difference if you add the below command to the SVI:
ip dhcp relay address 192.168.255.1 use-vrf VRF1
dodgerfan78
This command does not exist. Where is that supposed to go? It's not under the SVI:
LEAF4(config-if)#ip dhcp relay ?
information DHCP relay information option
short-lease Set and enable short lease for clients
source-interface Set source interface for relayed messages
What @Reza Sharifi meaning are the LO which yoh use as source in same vrf or not?
MHM
