Im trying to setup an Aironet with 1 SSID (hidden) with VLAN tag 2 to serve some CCTV cameras and Im tearing my hair out getting it to work.
Clients can connect to the wifi network OK but then cannot access anything on the LAN (they use a static IP address, there is no DHCP server), also despite setting no guest-mode the SSID keeps showing on the list of available networks.
This is the output from show run, can anyone please show me what Im doing wrong here?
! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname ap ! no logging console enable secret 5 $1$slaE$/PAsh4WifdGnBjUi.Vxhl/ ! ip subnet-zero ip domain name wrinehillvilla.local ! ! no aaa new-model ! dot11 ssid 7 Bishops Wood CCTV vlan 2 authentication open authentication key-management wpa wpa-psk ascii 7 044803031D314D45000D110E ! ! ! username Cisco password 7 1531021F0725 ! bridge irb ! ! interface Dot11Radio0 no ip address no ip route-cache ! encryption mode ciphers aes-ccm ! encryption vlan 2 mode ciphers tkip ! ssid 7 Bishops Wood CCTV ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0 station-role root ! interface Dot11Radio0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface Dot11Radio0.2 encapsulation dot1Q 2 no ip route-cache bridge-group 2 bridge-group 2 subscriber-loop-control bridge-group 2 block-unknown-source no bridge-group 2 source-learning no bridge-group 2 unicast-flooding bridge-group 2 spanning-disabled ! interface FastEthernet0 no ip address no ip route-cache duplex auto speed auto ! interface FastEthernet0.1 encapsulation dot1Q 1 native no ip route-cache bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled ! interface FastEthernet0.2 encapsulation dot1Q 2 no ip route-cache bridge-group 2 no bridge-group 2 source-learning bridge-group 2 spanning-disabled ! interface BVI1 ip address 192.168.253.253 255.255.255.0 no ip route-cache ! ip default-gateway 192.168.253.254 ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! ! control-plane ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 login local ! end
Have you checked that the ssid name matches under dot11 ssid and under interface Dot11Radio0? As a test, have you tried with an ssid that does not have spaces?
Have you configured the interface on the switch connected to the access point as a trunk with vlan 2 allowed on the trunk?
John
