HIGH CPU 4500X UTILIZATION
Derek Mayabi
Visitor
Hello Support
Please inform me on how to prevent high cpu ulization on a cisco device. An example is a cisco 4500X switch with a sample of the configs shown below.
BRM_HQ_CSW_01#sh proc cpu sort
Core 0: CPU utilization for five seconds: 1%; one minute: 4%; five minutes: 23%
Core 1: CPU utilization for five seconds: 99%; one minute: 70%; five minutes: 56%
PID   Runtime(ms) Invoked uSecs 5Sec     1Min     5Min     TTY   Process
8418   120346     280131   429   49.94   36.36   28.11  0     iosd
11263 106         1028     103   0.08     0.04     0.18     0     oom_poll.sh
11803 3644       33795   107   0.08     0.79     8.19     0     ffm
This high utilization has prevented the 4500x switch from issueing Ip addresses( It acts as the organizations DHCP server)
InayathUlla Sharieff
Derek,
1- Below you can find a simple guide to troubleshoot on the most common causes of high CPU in the 4500 platform just in case you need it for future reference.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
2- Kindly check in the logs if there are any logs pointing to any routing protocols flaps/ HSRP flaps/MAC addres flaps?
3- If any issues see when the routes are unreachalbe refer the following bug :CSCua99861 (
High CPU identified attributed to L3 Glean packets coming in from a couple of print servers sending packets to unknown destinations and after shutting them down, the CPU had dropped down).
4-Further more to determine the root cause we would need the following information:
- show version, show module
- show process cpu history
- show processes cpu sorted
- show processes cpu detailed process iosd sorted
- show platform health
- show platform cpu packet statistics
- show platform cpu packet statistics all
- show platform cpu packet buffered
- show ip traffic
Inayath
*Plz rate all usefull posts.
5 Replies 5
Reza Sharifi
This maybe an IOS bug.  You need to open a ticket with TAC and send them this output, so they can help you.
Steve Fuller
Level 11
Level 11
Hi Derek,
Take a read of the forum post cisco 4510R+E high cpu utilization on one core and note the link to DoS attack with MAC-Address (K5 L2 Hardware Addre process).
I'm not suggesting you necessarily have a DoS attack, but do you see MAC address flapping?
Derek,
- show ip traffic
Inayath
Erik Molenaar
Level 2
Level 2
Hi Derek,
Glad your problem is solved, but what exactly turned out to be the problem?
Erik
ibrahimbadr4669
Hi Derek,
what's the root cause of the high utilization
