High CPU issues on switch
haranadh.s
Community Member
                   We are facing teh issue with high cpu process. In the output could see Cat4k Mgmt LoPri is taking 95% utilization. Model: WS-C4506-E (MPC8548) processor (revision 9)
cusred024c4n01#sh process cpu | ex 0.00%
CPU utilization for five seconds: 99%/0%; one minute: 99%; five minutes: 99%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  15    19653416 183476902        107  0.07%  0.07%  0.07%   0 ARP Input
  38    56781500  20608396       2755  0.23%  0.27%  0.26%   0 IDB Work
  53  13838846243254520233        425  3.11%  3.30%  3.32%   0 Cat4k Mgmt HiPri
  54   554815588 986263607        562 95.04% 94.50% 94.15%   0 Cat4k Mgmt LoPri
  61     2741100 282548882          9  0.07%  0.10%  0.09%   0 Net Input
111      697064  47195707         14  0.15%  0.08%  0.08%   0 CDP Protocol
118    345109481354955568         25  0.15%  0.19%  0.17%   0 IP Input
124    67883960  41782263       1624  0.47%  0.37%  0.37%   0 Spanning Tree
155     4198860 210817071         19  0.07%  0.07%  0.07%   0 LLDP Protocol
157    15573184 247647069         62  0.07%  0.03%  0.03%   0 DHCPD Receive
183      558064 480031648          1  0.07%  0.03%  0.02%   0 PM Callback
barweiss45
Level 4
Level 4
I've had this happen to me before, where the Cat4k Mgmt process was over 95%. In my case it was caused by a layer 2 loop due to a spanning tree misconfiguration. I would suggest checking logs (depending how your switch is configured the logs may state that there is a particular mac looping) and spanning tree. I would run the "show spanning-tree detail" command try to see if you can isolate the port that has excessive Topology Change notifications.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.08.22 20:33:48 =~=~=~=~=~=~=~=~=~=~=~=
VLAN0002 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 2, address f866.f2b1.2800
  Configured hello time 2, max age 20, forward delay 15
  Current root has priority 8192, address 000a.421b.1802
  Root port is 1 (TenGigabitEthernet1/1), cost of root path is 2
  Topology change flag not set, detected flag not set
  Number of topology changes 3 last change occurred 9w4d ago
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
Port 1 (TenGigabitEthernet1/1) of VLAN0002 is root forwarding
   Port path cost 2, Port priority 128, Port Identifier 128.1.
   Designated root has priority 8192, address 000a.421b.1802
   Designated bridge has priority 8192, address 000a.421b.1802
   Designated port id is 128.513, designated path cost 0
   Timers: message age 2, forward delay 0, hold 0
   Number of transitions to forwarding state: 1
   Link type is point-to-point by default
   BPDU: sent 14, received 10258974
Port 65 (GigabitEthernet2/1) of VLAN0002 is designated forwarding
--More--                              Port path cost 19, Port priority 128, Port Identifier 128.65.
   Designated bridge has priority 32770, address f866.f2b1.2800
   Designated port id is 128.65, designated path cost 2
   Timers: message age 0, forward delay 0, hold 0
   The port is in the portfast mode
   Link type is shared by default
   Bpdu guard is enabled by default
   BPDU: sent 333720, received 0
Port 130 (GigabitEthernet3/2) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.130.
   Designated port id is 128.130, designated path cost 2
   BPDU: sent 2831794, received 0
--More--                            Port 132 (GigabitEthernet3/4) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.132.
   Designated port id is 128.132, designated path cost 2
   BPDU: sent 2840100, received 0
Port 134 (GigabitEthernet3/6) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.134.
   Designated port id is 128.134, designated path cost 2
   BPDU: sent 2829405, received 0
--More--
Port 136 (GigabitEthernet3/8) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.136.
   Designated port id is 128.136, designated path cost 2
   BPDU: sent 2920866, received 0
Port 138 (GigabitEthernet3/10) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.138.
   Designated port id is 128.138, designated path cost 2
--More--                              BPDU: sent 5699544, received 0
Port 142 (GigabitEthernet3/14) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.142.
   Designated port id is 128.142, designated path cost 2
   BPDU: sent 2795037, received 0
Port 146 (GigabitEthernet3/18) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.146.
   Designated port id is 128.146, designated path cost 2
--More--                              Bpdu guard is enabled by default
   BPDU: sent 295834, received 0
Port 165 (GigabitEthernet3/37) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.165.
   Designated port id is 128.165, designated path cost 2
   BPDU: sent 2533988, received 0
Port 166 (GigabitEthernet3/38) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.166.
   Designated port id is 128.166, designated path cost 2
--More--                              Link type is point-to-point by default
   BPDU: sent 2166365, received 0
Port 167 (GigabitEthernet3/39) of VLAN0002 is designated forwarding
   Port path cost 100, Port priority 128, Port Identifier 128.167.
   Designated port id is 128.167, designated path cost 2
   BPDU: sent 2834473, received 0
Port 168 (GigabitEthernet3/40) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.168.
   Designated port id is 128.168, designated path cost 2
--More--                              The port is in the portfast mode
   BPDU: sent 2915960, received 0
Port 169 (GigabitEthernet3/41) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.169.
   Designated port id is 128.169, designated path cost 2
   BPDU: sent 2917549, received 0
Port 170 (GigabitEthernet3/42) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.170.
   Designated port id is 128.170, designated path cost 2
--More--                              Number of transitions to forwarding state: 1
   BPDU: sent 2653374, received 0
Port 171 (GigabitEthernet3/43) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.171.
   Designated port id is 128.171, designated path cost 2
   BPDU: sent 1889549, received 0
Port 172 (GigabitEthernet3/44) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.172.
   Designated port id is 128.172, designated path cost 2
--More--                              Timers: message age 0, forward delay 0, hold 0
   BPDU: sent 2920071, received 0
Port 193 (GigabitEthernet4/1) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.193.
   Designated port id is 128.193, designated path cost 2
   BPDU: sent 2833871, received 0
Port 194 (GigabitEthernet4/2) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.194.
--More--                              Designated port id is 128.194, designated path cost 2
   BPDU: sent 2919087, received 0
Port 197 (GigabitEthernet4/5) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.197.
   Designated port id is 128.197, designated path cost 2
   BPDU: sent 857592, received 0
Port 200 (GigabitEthernet4/8) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.200.
--More--                              Designated bridge has priority 32770, address f866.f2b1.2800
   Designated port id is 128.200, designated path cost 2
   BPDU: sent 2919552, received 0
Port 202 (GigabitEthernet4/10) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.202.
   Designated port id is 128.202, designated path cost 2
   BPDU: sent 2165045, received 0
Port 204 (GigabitEthernet4/12) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.204.
--More--                              Designated root has priority 8192, address 000a.421b.1802
   Designated port id is 128.204, designated path cost 2
   BPDU: sent 69527, received 0
Port 206 (GigabitEthernet4/14) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.206.
   Designated port id is 128.206, designated path cost 2
   BPDU: sent 1221259, received 0
Port 209 (GigabitEthernet4/17) of VLAN0002 is designated forwarding
--More--                              Port path cost 19, Port priority 128, Port Identifier 128.209.
   Designated port id is 128.209, designated path cost 2
   BPDU: sent 1321575, received 0
Port 210 (GigabitEthernet4/18) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.210.
   Designated port id is 128.210, designated path cost 2
   BPDU: sent 2167444, received 0
--More--                            Port 212 (GigabitEthernet4/20) of VLAN0002 is designated forwarding
   Port path cost 100, Port priority 128, Port Identifier 128.212.
   Designated port id is 128.212, designated path cost 2
   BPDU: sent 2836961, received 0
Port 214 (GigabitEthernet4/22) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.214.
   Designated port id is 128.214, designated path cost 2
   BPDU: sent 2140822, received 0
--More--
Port 216 (GigabitEthernet4/24) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.216.
   Designated port id is 128.216, designated path cost 2
   BPDU: sent 94192, received 0
Port 217 (GigabitEthernet4/25) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.217.
   Designated port id is 128.217, designated path cost 2
--More--                              BPDU: sent 2836377, received 0
Port 218 (GigabitEthernet4/26) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.218.
   Designated port id is 128.218, designated path cost 2
   BPDU: sent 1625315, received 0
Port 219 (GigabitEthernet4/27) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.219.
   Designated port id is 128.219, designated path cost 2
   BPDU: sent 2921011, received 0
Port 222 (GigabitEthernet4/30) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.222.
   Designated port id is 128.222, designated path cost 2
   BPDU: sent 2919768, received 0
Port 223 (GigabitEthernet4/31) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.223.
   Designated port id is 128.223, designated path cost 2
   BPDU: sent 2439327, received 0
Port 226 (GigabitEthernet4/34) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.226.
   Designated port id is 128.226, designated path cost 2
   BPDU: sent 1585369, received 0
Port 227 (GigabitEthernet4/35) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.227.
   Designated port id is 128.227, designated path cost 2
   BPDU: sent 1502778, received 0
Port 228 (GigabitEthernet4/36) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.228.
   Designated port id is 128.228, designated path cost 2
   BPDU: sent 1619608, received 0
Port 229 (GigabitEthernet4/37) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.229.
   Designated port id is 128.229, designated path cost 2
   BPDU: sent 2139057, received 0
Port 230 (GigabitEthernet4/38) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.230.
   Designated port id is 128.230, designated path cost 2
   BPDU: sent 421912, received 0
Port 231 (GigabitEthernet4/39) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.231.
   Designated port id is 128.231, designated path cost 2
   BPDU: sent 2918553, received 0
Port 234 (GigabitEthernet4/42) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.234.
   Designated port id is 128.234, designated path cost 2
   BPDU: sent 1840313, received 0
Port 235 (GigabitEthernet4/43) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.235.
--More--                              Designated port id is 128.235, designated path cost 2
   BPDU: sent 2164496, received 0
Port 236 (GigabitEthernet4/44) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.236.
   Designated port id is 128.236, designated path cost 2
   BPDU: sent 2148858, received 0
Port 237 (GigabitEthernet4/45) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.237.
   Designated port id is 128.237, designated path cost 2
   BPDU: sent 2164473, received 0
Port 239 (GigabitEthernet4/47) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.239.
   Designated port id is 128.239, designated path cost 2
   BPDU: sent 2829492, received 0
Port 257 (GigabitEthernet5/1) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.257.
   Designated port id is 128.257, designated path cost 2
   BPDU: sent 2920488, received 0
Port 258 (GigabitEthernet5/2) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.258.
   Designated port id is 128.258, designated path cost 2
   BPDU: sent 644663, received 0
Port 259 (GigabitEthernet5/3) of VLAN0002 is designated forwarding
--More--                              Port path cost 4, Port priority 128, Port Identifier 128.259.
   Designated port id is 128.259, designated path cost 2
   BPDU: sent 2837193, received 0
Port 263 (GigabitEthernet5/7) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.263.
   Designated port id is 128.263, designated path cost 2
   BPDU: sent 5237594, received 0
--More--                            Port 265 (GigabitEthernet5/9) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.265.
   Designated port id is 128.265, designated path cost 2
   BPDU: sent 2142974, received 0
Port 269 (GigabitEthernet5/13) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.269.
   Designated port id is 128.269, designated path cost 2
   BPDU: sent 7908512, received 0
--More--
Port 270 (GigabitEthernet5/14) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.270.
   Designated port id is 128.270, designated path cost 2
   BPDU: sent 2744680, received 0
Port 271 (GigabitEthernet5/15) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.271.
   Designated port id is 128.271, designated path cost 2
--More--                              BPDU: sent 2837124, received 0
Port 272 (GigabitEthernet5/16) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.272.
   Designated port id is 128.272, designated path cost 2
   BPDU: sent 2920581, received 0
Port 273 (GigabitEthernet5/17) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.273.
   Designated port id is 128.273, designated path cost 2
   BPDU: sent 266998, received 0
Port 276 (GigabitEthernet5/20) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.276.
   Designated port id is 128.276, designated path cost 2
   BPDU: sent 10261055, received 0
Port 277 (GigabitEthernet5/21) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.277.
   Designated port id is 128.277, designated path cost 2
   BPDU: sent 2048815, received 0
Port 278 (GigabitEthernet5/22) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.278.
   Designated port id is 128.278, designated path cost 2
   BPDU: sent 10261056, received 0
Port 279 (GigabitEthernet5/23) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.279.
   Designated port id is 128.279, designated path cost 2
   BPDU: sent 2168368, received 0
Port 280 (GigabitEthernet5/24) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.280.
   Designated port id is 128.280, designated path cost 2
   BPDU: sent 71608, received 0
Port 281 (GigabitEthernet5/25) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.281.
   Designated port id is 128.281, designated path cost 2
   BPDU: sent 544217, received 0
Port 282 (GigabitEthernet5/26) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.282.
   Designated port id is 128.282, designated path cost 2
   BPDU: sent 1923672, received 0
Port 285 (GigabitEthernet5/29) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.285.
   Designated port id is 128.285, designated path cost 2
   BPDU: sent 5237893, received 0
Port 286 (GigabitEthernet5/30) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.286.
   Designated port id is 128.286, designated path cost 2
   BPDU: sent 1843458, received 0
Port 288 (GigabitEthernet5/32) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.288.
--More--                              Designated port id is 128.288, designated path cost 2
   BPDU: sent 4758440, received 0
Port 291 (GigabitEthernet5/35) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.291.
   Designated port id is 128.291, designated path cost 2
   BPDU: sent 2135395, received 0
Port 294 (GigabitEthernet5/38) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.294.
   Designated port id is 128.294, designated path cost 2
   BPDU: sent 1622541, received 0
Port 295 (GigabitEthernet5/39) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.295.
   Designated port id is 128.295, designated path cost 2
   BPDU: sent 2350127, received 0
Port 296 (GigabitEthernet5/40) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.296.
   Designated port id is 128.296, designated path cost 2
   BPDU: sent 2168655, received 0
Port 298 (GigabitEthernet5/42) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.298.
   Designated port id is 128.298, designated path cost 2
   BPDU: sent 269840, received 0
Port 299 (GigabitEthernet5/43) of VLAN0002 is designated forwarding
--More--                              Port path cost 19, Port priority 128, Port Identifier 128.299.
   Designated port id is 128.299, designated path cost 2
   BPDU: sent 2169138, received 0
Port 301 (GigabitEthernet5/45) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.301.
   Designated port id is 128.301, designated path cost 2
   BPDU: sent 636478, received 0
--More--                            Port 302 (GigabitEthernet5/46) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.302.
   Designated port id is 128.302, designated path cost 2
   BPDU: sent 2836465, received 0
Port 304 (GigabitEthernet5/48) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.304.
   Designated port id is 128.304, designated path cost 2
   BPDU: sent 228968, received 0
--More--
Port 321 (GigabitEthernet6/1) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.321.
   Designated port id is 128.321, designated path cost 2
   BPDU: sent 2139484, received 0
Port 322 (GigabitEthernet6/2) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.322.
   Designated port id is 128.322, designated path cost 2
--More--                              BPDU: sent 2164310, received 0
Port 323 (GigabitEthernet6/3) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.323.
   Designated port id is 128.323, designated path cost 2
   BPDU: sent 718000, received 0
Port 325 (GigabitEthernet6/5) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.325.
   Designated port id is 128.325, designated path cost 2
   BPDU: sent 2834734, received 0
Port 326 (GigabitEthernet6/6) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.326.
   Designated port id is 128.326, designated path cost 2
   BPDU: sent 2752218, received 0
Port 327 (GigabitEthernet6/7) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.327.
   Designated port id is 128.327, designated path cost 2
   BPDU: sent 2794349, received 0
Port 328 (GigabitEthernet6/8) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.328.
   Designated port id is 128.328, designated path cost 2
   BPDU: sent 2531232, received 0
Port 332 (GigabitEthernet6/12) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.332.
   Designated port id is 128.332, designated path cost 2
   BPDU: sent 2916089, received 0
Port 333 (GigabitEthernet6/13) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.333.
   Designated port id is 128.333, designated path cost 2
   BPDU: sent 2164777, received 0
Port 336 (GigabitEthernet6/16) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.336.
   Designated port id is 128.336, designated path cost 2
   BPDU: sent 2168137, received 0
Port 337 (GigabitEthernet6/17) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.337.
   Designated port id is 128.337, designated path cost 2
   BPDU: sent 2918147, received 0
Port 341 (GigabitEthernet6/21) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.341.
   Designated port id is 128.341, designated path cost 2
   BPDU: sent 1851935, received 0
Port 344 (GigabitEthernet6/24) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.344.
   Designated port id is 128.344, designated path cost 2
   BPDU: sent 1620478, received 0
Port 346 (GigabitEthernet6/26) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.346.
--More--                              Designated port id is 128.346, designated path cost 2
   BPDU: sent 2165265, received 0
Port 350 (GigabitEthernet6/30) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.350.
   Designated port id is 128.350, designated path cost 2
   BPDU: sent 2052099, received 0
Port 352 (GigabitEthernet6/32) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.352.
   Designated port id is 128.352, designated path cost 2
   BPDU: sent 7466593, received 0
Port 354 (GigabitEthernet6/34) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.354.
   Designated port id is 128.354, designated path cost 2
   BPDU: sent 2478251, received 0
Port 355 (GigabitEthernet6/35) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.355.
   Designated port id is 128.355, designated path cost 2
   BPDU: sent 2144396, received 0
Port 356 (GigabitEthernet6/36) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.356.
   Designated port id is 128.356, designated path cost 2
   BPDU: sent 1844578, received 0
Port 359 (GigabitEthernet6/39) of VLAN0002 is designated forwarding
--More--                              Port path cost 19, Port priority 128, Port Identifier 128.359.
   Designated port id is 128.359, designated path cost 2
   BPDU: sent 2164627, received 0
Port 360 (GigabitEthernet6/40) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.360.
   Designated port id is 128.360, designated path cost 2
   BPDU: sent 2164454, received 0
--More--                            Port 362 (GigabitEthernet6/42) of VLAN0002 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.362.
   Designated port id is 128.362, designated path cost 2
   BPDU: sent 10261061, received 0
Port 364 (GigabitEthernet6/44) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.364.
   Designated port id is 128.364, designated path cost 2
   BPDU: sent 2918779, received 0
--More--
Port 367 (GigabitEthernet6/47) of VLAN0002 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.367.
   Designated port id is 128.367, designated path cost 2
   BPDU: sent 716758, received 0
--More--
VLAN0502 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 502, address f866.f2b1.2800
  Current root has priority 8192, address 000a.421b.19f6
Port 1 (TenGigabitEthernet1/1) of VLAN0502 is root forwarding
   Designated root has priority 8192, address 000a.421b.19f6
   Designated bridge has priority 8192, address 000a.421b.19f6
   Timers: message age 1, forward delay 0, hold 0
   BPDU: sent 25, received 10258992
Port 65 (GigabitEthernet2/1) of VLAN0502 is designated forwarding
   Designated bridge has priority 33270, address f866.f2b1.2800
   BPDU: sent 333739, received 0
Port 130 (GigabitEthernet3/2) of VLAN0502 is designated forwarding
   BPDU: sent 2831811, received 0
--More--                            Port 132 (GigabitEthernet3/4) of VLAN0502 is designated forwarding
   BPDU: sent 2840117, received 0
Port 134 (GigabitEthernet3/6) of VLAN0502 is designated forwarding
   BPDU: sent 2829421, received 0
--More--
Port 136 (GigabitEthernet3/8) of VLAN0502 is designated forwarding
   BPDU: sent 2920881, received 0
Port 138 (GigabitEthernet3/10) of VLAN0502 is designated forwarding
--More--                              BPDU: sent 5699560, received 0
Port 142 (GigabitEthernet3/14) of VLAN0502 is designated forwarding
   BPDU: sent 2795054, received 0
Port 146 (GigabitEthernet3/18) of VLAN0502 is designated forwarding
   BPDU: sent 295851, received 0
Port 165 (GigabitEthernet3/37) of VLAN0502 is designated forwarding
   BPDU: sent 2534004, received 0
Port 166 (GigabitEthernet3/38) of VLAN0502 is designated forwarding
   BPDU: sent 2166381, received 0
Port 167 (GigabitEthernet3/39) of VLAN0502 is designated forwarding
   BPDU: sent 2834490, received 0
Port 168 (GigabitEthernet3/40) of VLAN0502 is designated forwarding
   BPDU: sent 2915977, received 0
Port 169 (GigabitEthernet3/41) of VLAN0502 is designated forwarding
   BPDU: sent 2917565, received 0
Port 170 (GigabitEthernet3/42) of VLAN0502 is designated forwarding
   BPDU: sent 2653390, received 0
Port 171 (GigabitEthernet3/43) of VLAN0502 is designated forwarding
   BPDU: sent 1889565, received 0
Port 172 (GigabitEthernet3/44) of VLAN0502 is designated forwarding
   BPDU: sent 2920086, received 0
Port 193 (GigabitEthernet4/1) of VLAN0502 is designated forwarding
   BPDU: sent 2833887, received 0
Port 194 (GigabitEthernet4/2) of VLAN0502 is designated forwarding
   BPDU: sent 2919103, received 0
Port 197 (GigabitEthernet4/5) of VLAN0502 is designated forwarding
   BPDU: sent 857607, received 0
Port 200 (GigabitEthernet4/8) of VLAN0502 is designated forwarding
--More--                              Designated bridge has priority 33270, address f866.f2b1.2800
   BPDU: sent 2919566, received 0
Port 202 (GigabitEthernet4/10) of VLAN0502 is designated forwarding
   BPDU: sent 2165061, received 0
Port 204 (GigabitEthernet4/12) of VLAN0502 is designated forwarding
--More--                              Designated root has priority 8192, address 000a.421b.19f6
   BPDU: sent 69543, received 0
Port 206 (GigabitEthernet4/14) of VLAN0502 is designated forwarding
   BPDU: sent 1221275, received 0
Port 209 (GigabitEthernet4/17) of VLAN0502 is designated forwarding
   BPDU: sent 1321591, received 0
Port 210 (GigabitEthernet4/18) of VLAN0502 is designated forwarding
   BPDU: sent 2167459, received 0
--More--                            Port 212 (GigabitEthernet4/20) of VLAN0502 is designated forwarding
   BPDU: sent 2836976, received 0
Port 214 (GigabitEthernet4/22) of VLAN0502 is designated forwarding
   BPDU: sent 2140837, received 0
--More--
Port 216 (GigabitEthernet4/24) of VLAN0502 is designated forwarding
   BPDU: sent 94207, received 0
Port 217 (GigabitEthernet4/25) of VLAN0502 is designated forwarding
--More--                              BPDU: sent 2836393, received 0
Port 218 (GigabitEthernet4/26) of VLAN0502 is designated forwarding
   BPDU: sent 1625330, received 0
Port 219 (GigabitEthernet4/27) of VLAN0502 is designated forwarding
   BPDU: sent 2921025, received 0
Port 222 (GigabitEthernet4/30) of VLAN0502 is designated forwarding
   BPDU: sent 2919782, received 0
Port 223 (GigabitEthernet4/31) of VLAN0502 is designated forwarding
   BPDU: sent 2439342, received 0
Port 226 (GigabitEthernet4/34) of VLAN0502 is designated forwarding
   BPDU: sent 1585383, received 0
Port 227 (GigabitEthernet4/35) of VLAN0502 is designated forwarding
   BPDU: sent 1502792, received 0
Port 228 (GigabitEthernet4/36) of VLAN0502 is designated forwarding
   BPDU: sent 1619622, received 0
Port 229 (GigabitEthernet4/37) of VLAN0502 is designated forwarding
   BPDU: sent 2139071, received 0
Port 230 (GigabitEthernet4/38) of VLAN0502 is designated forwarding
   BPDU: sent 421926, received 0
Port 231 (GigabitEthernet4/39) of VLAN0502 is designated forwarding
   BPDU: sent 2918567, received 0
Port 234 (GigabitEthernet4/42) of VLAN0502 is designated forwarding
   BPDU: sent 1840327, received 0
Port 235 (GigabitEthernet4/43) of VLAN0502 is designated forwarding
   BPDU: sent 2164510, received 0
Port 236 (GigabitEthernet4/44) of VLAN0502 is designated forwarding
   BPDU: sent 2148872, received 0
Port 237 (GigabitEthernet4/45) of VLAN0502 is designated forwarding
   BPDU: sent 2164487, received 0
Port 239 (GigabitEthernet4/47) of VLAN0502 is designated forwarding
   BPDU: sent 2829506, received 0
Port 257 (GigabitEthernet5/1) of VLAN0502 is designated forwarding
   BPDU: sent 2920501, received 0
Port 258 (GigabitEthernet5/2) of VLAN0502 is designated forwarding
   BPDU: sent 644676, received 0
Port 259 (GigabitEthernet5/3) of VLAN0502 is designated forwarding
   BPDU: sent 2837206, received 0
Port 263 (GigabitEthernet5/7) of VLAN0502 is designated forwarding
   BPDU: sent 5237606, received 0
--More--                            Port 265 (GigabitEthernet5/9) of VLAN0502 is designated forwarding
   BPDU: sent 2142987, received 0
Port 269 (GigabitEthernet5/13) of VLAN0502 is designated forwarding
   BPDU: sent 7908524, received 0
--More--
Port 270 (GigabitEthernet5/14) of VLAN0502 is designated forwarding
   BPDU: sent 2744693, received 0
Port 271 (GigabitEthernet5/15) of VLAN0502 is designated forwarding
--More--                              BPDU: sent 2837137, received 0
Port 272 (GigabitEthernet5/16) of VLAN0502 is designated forwarding
   BPDU: sent 2920593, received 0
Port 273 (GigabitEthernet5/17) of VLAN0502 is designated forwarding
   BPDU: sent 267011, received 0
Port 276 (GigabitEthernet5/20) of VLAN0502 is designated forwarding
   BPDU: sent 10261067, received 0
Port 277 (GigabitEthernet5/21) of VLAN0502 is designated forwarding
   BPDU: sent 2048828, received 0
Port 278 (GigabitEthernet5/22) of VLAN0502 is designated forwarding
Port 279 (GigabitEthernet5/23) of VLAN0502 is designated forwarding
   BPDU: sent 2168380, received 0
Port 280 (GigabitEthernet5/24) of VLAN0502 is designated forwarding
   BPDU: sent 71620, received 0
Port 281 (GigabitEthernet5/25) of VLAN0502 is designated forwarding
   BPDU: sent 544229, received 0
Port 282 (GigabitEthernet5/26) of VLAN0502 is designated forwarding
   BPDU: sent 1923685, received 0
Port 285 (GigabitEthernet5/29) of VLAN0502 is designated forwarding
   BPDU: sent 5237904, received 0
Port 286 (GigabitEthernet5/30) of VLAN0502 is designated forwarding
   BPDU: sent 1843469, received 0
Port 288 (GigabitEthernet5/32) of VLAN0502 is designated forwarding
   BPDU: sent 4758450, received 0
Port 291 (GigabitEthernet5/35) of VLAN0502 is designated forwarding
   BPDU: sent 2135407, received 0
Port 294 (GigabitEthernet5/38) of VLAN0502 is designated forwarding
   BPDU: sent 1622553, received 0
Port 295 (GigabitEthernet5/39) of VLAN0502 is designated forwarding
   BPDU: sent 2350138, received 0
Port 296 (GigabitEthernet5/40) of VLAN0502 is designated forwarding
   BPDU: sent 2168666, received 0
Port 298 (GigabitEthernet5/42) of VLAN0502 is designated forwarding
   BPDU: sent 269851, received 0
Port 299 (GigabitEthernet5/43) of VLAN0502 is designated forwarding
   BPDU: sent 2169149, received 0
Port 301 (GigabitEthernet5/45) of VLAN0502 is designated forwarding
   BPDU: sent 636489, received 0
--More--                            Port 302 (GigabitEthernet5/46) of VLAN0502 is designated forwarding
   BPDU: sent 2836476, received 0
Port 304 (GigabitEthernet5/48) of VLAN0502 is designated forwarding
   BPDU: sent 228978, received 0
--More--
Port 321 (GigabitEthernet6/1) of VLAN0502 is designated forwarding
   BPDU: sent 2139494, received 0
Port 322 (GigabitEthernet6/2) of VLAN0502 is designated forwarding
--More--                              BPDU: sent 2164320, received 0
Port 323 (GigabitEthernet6/3) of VLAN0502 is designated forwarding
   BPDU: sent 718010, received 0
Port 325 (GigabitEthernet6/5) of VLAN0502 is designated forwarding
   BPDU: sent 2834744, received 0
Port 326 (GigabitEthernet6/6) of VLAN0502 is designated forwarding
   BPDU: sent 2752229, received 0
Port 327 (GigabitEthernet6/7) of VLAN0502 is designated forwarding
   BPDU: sent 2794360, received 0
Port 328 (GigabitEthernet6/8) of VLAN0502 is designated forwarding
   BPDU: sent 2531242, received 0
Port 332 (GigabitEthernet6/12) of VLAN0502 is designated forwarding
   BPDU: sent 2916099, received 0
Port 333 (GigabitEthernet6/13) of VLAN0502 is designated forwarding
   BPDU: sent 2164787, received 0
Port 336 (GigabitEthernet6/16) of VLAN0502 is designated forwarding
   BPDU: sent 2168147, received 0
Port 337 (GigabitEthernet6/17) of VLAN0502 is designated forwarding
   BPDU: sent 2918157, received 0
Port 341 (GigabitEthernet6/21) of VLAN0502 is designated forwarding
   BPDU: sent 1851945, received 0
Port 344 (GigabitEthernet6/24) of VLAN0502 is designated forwarding
   BPDU: sent 1620488, received 0
Port 346 (GigabitEthernet6/26) of VLAN0502 is designated forwarding
   BPDU: sent 2165275, received 0
Port 350 (GigabitEthernet6/30) of VLAN0502 is designated forwarding
   BPDU: sent 2052108, received 0
Port 352 (GigabitEthernet6/32) of VLAN0502 is designated forwarding
   BPDU: sent 7466601, received 0
Port 354 (GigabitEthernet6/34) of VLAN0502 is designated forwarding
   BPDU: sent 2478261, received 0
Port 355 (GigabitEthernet6/35) of VLAN0502 is designated forwarding
   BPDU: sent 2144406, received 0
Port 356 (GigabitEthernet6/36) of VLAN0502 is designated forwarding
   BPDU: sent 1844588, received 0
Port 359 (GigabitEthernet6/39) of VLAN0502 is designated forwarding
   BPDU: sent 2164637, received 0
Port 360 (GigabitEthernet6/40) of VLAN0502 is designated forwarding
   BPDU: sent 2164464, received 0
--More--                            Port 362 (GigabitEthernet6/42) of VLAN0502 is designated forwarding
   BPDU: sent 10261070, received 0
Port 364 (GigabitEthernet6/44) of VLAN0502 is designated forwarding
   BPDU: sent 2918788, received 0
--More--
Port 367 (GigabitEthernet6/47) of VLAN0502 is designated forwarding
   BPDU: sent 716767, received 0
--More--
VLAN0700 is executing the ieee compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 700, address f866.f2b1.2800
  Current root has priority 8192, address 000a.421b.1abc
  Number of topology changes 86 last change occurred 1w1d ago
          from GigabitEthernet2/48
Port 1 (TenGigabitEthernet1/1) of VLAN0700 is root forwarding
   Designated root has priority 8192, address 000a.421b.1abc
   Designated bridge has priority 8192, address 000a.421b.1abc
   BPDU: sent 106, received 10259084
--More--                            Port 112 (GigabitEthernet2/48) of VLAN0700 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.112.
   Designated bridge has priority 33468, address f866.f2b1.2800
   Designated port id is 128.112, designated path cost 2
   BPDU: sent 10259131, received 2151
cusred024c4n01#     sh log
Syslog logging: enabled (0 messages dropped, 2843 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level informational, 10585 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 13428 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 13431 message lines logged
        Logging to 10.36.192.90  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              13431 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.36.194.21  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 10.36.198.150  (udp port 514,  audit disabled,
              11052 message lines logged,
--More--                                         0 message lines dropped-by-MD,
              filtering disabled
        Logging to 10.36.207.182  (udp port 514,  audit disabled,
              125 message lines logged,
              filtering disabled
--More--
Log Buffer (100000 bytes):
cation failure for SNMP req from host 10.36.198.175
Aug  2 20:53:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  2 21:16:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  2 21:18:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  2 21:20:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  2 21:26:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  2 21:44:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  2 21:54:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  2 21:58:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 22:00:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 22:10:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  2 22:12:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 22:32:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  2 22:35:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 22:36:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  2 23:02:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  2 23:07:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 23:09:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 23:15:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  2 23:28:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  2 23:45:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  2 23:48:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  2 23:53:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  3 00:01:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 00:19:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 00:20:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 00:25:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 00:32:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 00:45:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 00:55:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 01:03:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 01:10:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 01:11:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 01:30:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 01:37:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 01:40:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 01:48:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 01:49:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 02:03:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 02:04:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 02:18:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 02:26:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 02:29:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 02:39:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 02:43:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 02:54:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 02:56:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           .Aug  3 03:04:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 03:09:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
.Aug  3 03:14:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 03:20:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 03:34:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 03:38:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 03:42:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 03:46:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 03:48:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 04:11:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 04:21:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 04:23:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  3 04:33:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 04:38:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 04:49:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 04:58:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 05:03:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 05:27:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 05:29:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 05:34:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 05:37:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 05:55:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 06:05:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 06:08:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  3 06:16:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 06:21:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 06:28:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.65
.Aug  3 06:43:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 06:47:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 06:54:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 07:13:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 07:15:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 07:17:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 07:21:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 07:33:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 07:39:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 07:52:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 07:58:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 08:05:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 08:09:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 08:11:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 08:27:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 08:31:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 08:36:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 08:50:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 08:57:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 09:02:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 09:04:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  3 09:13:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 09:22:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 09:28:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 09:36:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 09:48:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 09:52:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 09:58:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 10:06:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 10:11:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 10:14:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 10:29:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 10:40:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 10:44:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 10:46:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 10:53:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 11:06:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 11:07:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 11:20:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 11:22:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 11:32:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 11:45:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 11:47:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 11:55:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 11:58:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 12:01:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 12:23:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 12:30:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 12:39:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 12:42:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 12:49:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 13:00:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 13:05:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 13:15:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 13:17:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 13:36:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 13:38:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           .Aug  3 13:40:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 13:41:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 13:56:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 14:07:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 14:15:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 14:16:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 14:30:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 14:32:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 14:34:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 14:49:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 14:54:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 14:58:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 15:12:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 15:24:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 15:32:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 15:50:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 15:59:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 16:10:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 16:16:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 16:19:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 16:29:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 16:33:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 16:42:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 16:48:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           .Aug  3 17:07:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 17:08:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 17:13:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 17:27:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 17:34:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 17:43:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 17:45:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 18:00:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 18:05:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 18:07:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 18:18:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 18:24:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  3 18:25:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 18:42:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 18:51:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 18:53:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 19:01:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 19:02:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 19:17:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 19:20:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 19:28:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 19:40:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 19:43:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 19:56:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  3 19:58:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 20:02:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 20:09:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 20:19:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 20:34:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 20:36:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  3 20:37:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 20:50:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 20:57:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 21:00:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  3 21:13:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 21:26:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  3 21:36:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  3 21:44:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 21:48:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 21:51:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 22:14:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 22:18:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 22:22:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 22:30:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 22:38:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 22:44:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 22:53:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 22:57:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  3 23:07:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  3 23:09:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 23:31:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 23:33:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  3 23:35:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  3 23:45:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 00:01:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 00:06:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 00:10:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 00:23:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 00:27:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 00:41:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 00:48:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 00:53:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 01:01:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 01:16:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 01:20:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 01:21:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 01:26:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 01:39:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 01:45:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 01:51:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 02:05:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 02:11:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  4 02:16:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 02:26:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 02:38:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 02:43:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 02:54:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 03:00:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 03:03:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 03:10:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 03:22:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 03:29:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 03:31:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 03:35:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 03:55:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 04:00:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 04:04:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 04:09:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 04:21:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 04:39:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 04:45:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 04:47:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 04:58:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 05:13:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 05:17:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 05:20:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 05:25:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 05:39:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 05:53:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 05:55:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 06:03:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 06:05:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 06:30:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 06:31:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 06:33:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 06:40:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 06:47:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 06:57:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  4 07:05:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 07:12:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 07:18:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 07:23:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 07:40:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 07:41:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 07:48:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 07:50:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 07:56:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 08:14:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 08:28:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 08:34:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           .Aug  4 08:35:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 08:40:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 08:49:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 09:06:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 09:07:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 09:11:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 09:24:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 09:29:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 09:32:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 09:45:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 09:49:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 09:58:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  4 09:59:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 10:23:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 10:27:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 10:34:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 10:49:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 11:01:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 11:04:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 11:09:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 11:15:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 11:17:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 11:39:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 11:41:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  4 11:42:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 11:43:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 12:06:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 12:11:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 12:17:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 12:20:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 12:32:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 12:53:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 12:56:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 12:58:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 13:05:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 13:24:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  4 13:28:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 13:34:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 13:36:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 13:50:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 14:00:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 14:03:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 14:13:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 14:14:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 14:16:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 14:38:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 14:42:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 14:51:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 14:54:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 15:08:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 15:12:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 15:29:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 15:34:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 15:47:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 15:49:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 16:00:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 16:07:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 16:22:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 16:26:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 16:43:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 16:45:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 16:46:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 16:52:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 16:56:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 17:17:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 17:23:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 17:25:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 17:31:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 17:37:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 17:43:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 18:01:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 18:03:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 18:06:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 18:09:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 18:32:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 18:34:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 18:39:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 18:41:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 19:00:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 19:16:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 19:20:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 19:26:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 19:50:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 19:52:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  4 19:54:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 19:58:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 20:18:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 20:21:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 20:25:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 20:32:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 20:37:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 20:44:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 20:59:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 21:10:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 21:15:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 21:34:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  4 21:36:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 21:47:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 21:53:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 22:02:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 22:09:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 22:25:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 22:28:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 22:31:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 22:44:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 22:54:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  4 23:03:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  4 23:04:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           .Aug  4 23:09:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  4 23:19:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 23:41:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  4 23:45:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  4 23:48:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 23:54:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  4 23:59:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 00:11:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 00:19:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 00:26:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 00:29:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 00:37:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  5 00:53:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 00:57:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 01:02:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 01:04:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 01:28:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 01:35:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 01:39:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 01:42:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 01:48:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 01:54:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 02:13:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  5 02:20:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           .Aug  5 02:42:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 02:45:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 02:48:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 02:51:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  5 02:59:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 03:11:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 03:23:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 03:29:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  5 03:36:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 03:58:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 04:03:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 04:07:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           .Aug  5 04:15:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 04:29:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 04:31:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 04:33:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 04:45:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
.Aug  5 04:54:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
.Aug  5 04:55:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
.Aug  5 05:07:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 05:21:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 05:22:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 05:25:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 05:32:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 05:42:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 05:47:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 06:00:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 06:10:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 06:12:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 06:17:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 06:20:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 06:38:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 06:48:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 06:51:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 07:04:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 07:14:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 07:16:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 07:26:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 07:30:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 07:53:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 07:56:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 08:00:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 08:05:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 08:09:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 08:21:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 08:31:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 08:35:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 08:43:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 08:47:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 09:03:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 09:09:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 09:10:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 09:13:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 09:22:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 09:39:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 09:45:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 09:46:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 09:57:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:00:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:05:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  5 10:19:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:24:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 10:30:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 10:38:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:52:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:54:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 10:56:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 11:02:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 11:17:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 11:22:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 11:28:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 11:40:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  5 11:45:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 11:48:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 11:55:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 12:02:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 12:14:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 12:17:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 12:33:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 12:37:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 12:39:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 12:55:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 13:06:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 13:11:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 13:31:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 13:33:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 13:46:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 13:49:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 13:57:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 14:11:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 14:20:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 14:23:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 14:27:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 14:49:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 14:55:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 15:05:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 15:14:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 15:20:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 15:26:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 15:29:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 15:40:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 15:43:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 16:03:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 16:04:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 16:05:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 16:14:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 16:21:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 16:31:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  5 16:37:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 16:42:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 16:56:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 16:58:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 17:08:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 17:11:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 17:20:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 17:22:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 17:36:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 17:46:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 17:48:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 17:57:50: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
--More--                           Aug  5 17:58:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 18:02:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 18:13:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 18:20:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 18:35:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 18:37:06: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/22 to port Gi5/9
Aug  5 18:39:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 18:51:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 18:54:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 18:56:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 19:04:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 19:13:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  5 19:28:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 19:30:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 19:50:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 19:55:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 20:03:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 20:07:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 20:21:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 20:28:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 20:37:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 20:44:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 20:46:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 21:06:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  5 21:11:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 21:12:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 21:23:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 21:37:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 21:43:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 21:46:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 22:00:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 22:04:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 22:19:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 22:21:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 22:29:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 22:31:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
--More--                           Aug  5 22:38:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 22:53:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 22:59:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 23:16:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 23:20:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 23:25:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 23:28:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  5 23:37:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  5 23:45:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  5 23:53:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  6 00:02:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  6 00:11:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 00:15:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 00:19:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  6 00:31:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  6 00:37:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 00:53:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 01:03:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 01:12:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.175
Aug  6 01:28:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 01:30:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 01:54:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 02:08:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 02:19:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 02:44:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.174
Aug  6 02:45:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 03:05:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug  6 03:10:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 03:23:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 03:36:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 04:01:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 04:27:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 04:39:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 04:52:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 05:07:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.157
Aug  6 05:16:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  6 05:18:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 05:44:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 05:54:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 06:09:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 06:31:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 06:35:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 07:01:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 07:09:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 07:26:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 07:46:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 07:52:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 08:17:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 08:24:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 08:43:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 09:02:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 09:09:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 09:34:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 09:40:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 10:00:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 10:18:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 10:26:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 10:51:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 10:56:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 11:17:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 11:33:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 11:42:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 12:08:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 12:11:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 12:33:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 12:49:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 12:59:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 13:24:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 13:26:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 13:50:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 14:04:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 14:15:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 14:41:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 14:42:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 15:06:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 15:20:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 15:32:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 15:57:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 16:24:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 16:35:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 16:49:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 17:13:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 17:15:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 17:41:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 17:50:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 18:06:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 18:19:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.157
Aug  6 18:28:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 18:31:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.157
Aug  6 18:32:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 18:54:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.177
Aug  6 18:57:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 19:06:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 19:22:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 19:43:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 19:48:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  6 20:14:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 20:20:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 20:39:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 20:58:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 21:05:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 21:30:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 21:35:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 21:56:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 22:13:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 22:21:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 22:47:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 22:51:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  6 23:13:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  6 23:29:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  6 23:38:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 00:04:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 00:06:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 00:29:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 00:44:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 00:55:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 01:21:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 01:22:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 01:46:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 02:00:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  7 02:12:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 02:37:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 03:02:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug  7 03:03:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 03:15:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 03:29:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 03:53:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 03:54:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 04:20:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 04:31:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 04:45:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 05:08:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  7 05:11:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 05:37:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 05:46:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 06:03:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 06:24:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 06:28:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 06:54:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 07:02:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 07:19:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 07:40:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 07:45:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 08:10:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  7 08:18:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 08:36:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 08:55:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 09:02:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 09:27:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 09:33:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 09:53:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 10:11:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 10:19:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 10:45:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 10:48:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 11:10:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  7 11:25:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 11:36:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 12:02:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 12:03:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 12:28:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 12:41:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 12:53:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 13:18:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 13:19:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 13:45:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 13:56:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 14:11:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  7 14:33:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 14:36:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 15:02:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 15:11:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 15:28:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 15:49:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 15:53:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 16:19:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 16:26:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 16:45:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 17:04:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 17:11:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  7 17:36:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 17:42:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 18:02:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 18:20:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 18:28:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 18:53:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 18:57:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 19:19:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 19:35:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 19:44:32: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 20:10:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 20:12:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  7 20:35:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 20:50:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 21:00:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 21:26:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 21:28:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 21:51:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 22:05:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 22:17:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 22:43:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 23:08:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  7 23:20:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  7 23:34:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  7 23:58:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 00:00:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 00:26:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 00:36:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 00:51:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 01:13:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 01:17:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 01:43:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 01:51:44: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 02:08:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 02:29:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 02:34:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 03:00:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 03:04:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug  8 03:07:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 03:25:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 03:45:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 03:51:15: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 04:16:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 04:23:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 04:42:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 05:01:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 05:08:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 05:33:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 05:38:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 05:59:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 06:16:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 06:25:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 06:50:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 06:54:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 07:16:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 07:32:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 07:42:08: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 08:07:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 08:09:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 08:33:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 08:47:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 08:58:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 09:23:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 09:25:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 09:49:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 10:02:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 10:15:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 10:40:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 11:06:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 11:18:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 11:32:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 11:56:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  8 11:57:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 12:23:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 12:33:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 12:49:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 13:11:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 13:14:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 13:40:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 13:49:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 14:06:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 14:27:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 14:31:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 14:57:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 15:04:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 15:22:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 15:42:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 15:48:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 16:13:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 16:19:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 16:36:02: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi6/21, count=102160
Aug  8 16:39:40: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 16:46:07: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi6/21, count=102267
Aug  8 16:56:10: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi6/21, count=102373
Aug  8 16:56:10: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId7 on Switch Phyport Gi6/21, count=101948
Aug  8 16:57:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug  8 17:05:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 17:31:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 17:34:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 17:57:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 18:12:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 18:22:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 18:48:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 18:50:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 18:57:12: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
Aug  8 19:13:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 19:28:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 19:39:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 20:05:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 20:30:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 20:43:48: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 20:55:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 21:20:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 21:45:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 21:59:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 22:29:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 22:36:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug  8 22:57:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  8 23:01:15: %C4K_EBM-4-HOSTFLAPPING: Host 9C:EB:E8:06:0D:5F in vlan 2 is moving from port Gi5/42 to port Gi5/22
Aug  8 23:26:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  8 23:55:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 00:24:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 00:53:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 01:21:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 01:50:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 02:03:03: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi4/12 in vlan 2
Aug  9 02:18:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 02:47:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 03:13:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug  9 03:15:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 03:44:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 04:13:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  9 04:41:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 05:10:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 05:39:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 06:07:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 06:36:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 07:05:17: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 07:33:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 08:02:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 08:31:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 09:00:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 09:29:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 09:58:09: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  9 10:26:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 10:55:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 11:24:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 11:53:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 12:22:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 12:51:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 13:20:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 13:49:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 14:17:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 14:46:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 15:15:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 15:43:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  9 16:12:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 16:40:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 17:09:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 17:38:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 18:06:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 18:35:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 19:04:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 19:33:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 20:02:00: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 20:30:51: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 20:59:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 21:28:34: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug  9 21:36:46: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.36.207.184 port 514 stopped - CLI initiated
Aug  9 21:36:48: %SYS-5-CONFIG_I: Configured from console by deviceAuthority on vty1 (10.36.204.23)
Aug  9 21:36:49: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.36.207.182 Port 514 started - CLI initiated
Aug  9 21:57:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 22:26:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 22:55:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 23:23:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug  9 23:53:02: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 00:21:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 00:51:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 01:20:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 01:48:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug 10 02:17:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 02:45:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 03:10:56: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 10 03:14:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 03:43:39: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 04:12:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 04:41:06: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 05:09:55: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 05:38:45: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 06:07:43: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 06:28:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.65
Aug 10 06:35:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug 10 07:04:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 07:33:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 08:01:33: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 08:30:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 08:59:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 09:27:21: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 09:56:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 10:25:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 10:53:59: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 11:22:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 11:51:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 12:20:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug 10 12:49:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 13:18:23: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 13:47:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 14:16:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 14:44:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 15:13:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 15:42:19: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 16:11:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 16:39:42: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 17:08:25: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 17:37:12: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 18:05:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
--More--                           Aug 10 18:34:37: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 19:03:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 19:32:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 20:00:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 20:29:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 20:58:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 21:27:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 21:56:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 10 22:24:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 11 03:10:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 12 03:09:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 12 19:02:00: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
--More--                           Aug 12 20:03:34: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/22 to port Gi5/9
Aug 13 00:39:44: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 15 times)Packet received with invalid source MAC address (A9:E5:CA:95:D3:FE) on port Gi3/42 in vlan 2
Aug 13 03:10:20: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 13 18:58:48: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
Aug 14 00:02:07: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 00:39:47: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 01:16:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 01:54:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 02:32:11: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 03:09:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 03:47:18: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug 14 04:24:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 05:02:04: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 05:39:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 06:17:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 06:54:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 07:32:14: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 08:10:26: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 08:47:58: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 09:25:22: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 10:03:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 10:40:49: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 11:18:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
--More--                           Aug 14 11:55:53: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 12:33:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 13:10:38: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 13:48:01: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 14:25:46: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 15:03:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 15:40:24: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 16:17:52: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 16:55:28: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.162
Aug 14 19:02:01: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Te1/1
Aug 14 20:47:22: %C4K_EBM-4-HOSTFLAPPING: Host 00:0F:FE:E5:0A:19 in vlan 2 is moving from port Gi6/34 to port Gi2/1
Aug 14 20:49:06: %C4K_EBM-4-HOSTFLAPPING: Host 00:0F:FE:EB:01:A4 in vlan 2 is moving from port Gi6/34 to port Gi2/1
--More--                           Aug 14 20:49:07: %C4K_EBM-4-HOSTFLAPPING: Host 00:0F:FE:E5:0A:19 in vlan 2 is moving from port Gi6/34 to port Gi2/1
Aug 14 22:12:51: %C4K_EBM-4-HOSTFLAPPING: Host 00:0F:FE:E5:0A:19 in vlan 2 is moving from port Gi2/1 to port Gi6/34
Aug 14 22:19:30: %C4K_EBM-4-HOSTFLAPPING: Host 18:A9:05:FB:1F:78 in vlan 2 is moving from port Gi6/34 to port Gi2/1
Aug 15 03:14:31: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 15 11:32:14: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 15 18:57:58: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
Aug 15 21:36:25: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 16 03:14:54: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 16 07:13:13: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.159
Aug 16 10:49:57: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 17 03:16:29: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 17 06:28:41: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.65
--More--                           Aug 17 16:14:11: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 18 03:12:36: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 18 06:21:50: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 1 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 18 19:21:44: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 19 03:16:05: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 20 00:40:30: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 20 03:01:35: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.207.170
Aug 20 03:12:16: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 20 13:46:27: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.154
Aug 20 14:35:05: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: (Suppressed 8 times)Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 20 16:53:46: %SYS-5-CONFIG_I: Configured from console by deviceAuthority on vty1 (10.36.204.23)
--More--                           Aug 20 19:02:46: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Gi5/22
Aug 20 19:58:30: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.171
Aug 21 03:13:10: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 21 04:38:50: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.170
Aug 21 11:09:28: %C4K_L2MAN-6-INVALIDSOURCEADDRESSPACKET: Packet received with invalid source MAC address (00:00:00:00:00:00) on port Gi6/13 in vlan 2
Aug 21 15:02:57: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.198.155
Aug 21 19:03:16: %C4K_EBM-4-HOSTFLAPPING: Host 28:92:4A:23:6E:C3 in vlan 2 is moving from port Gi5/9 to port Te1/1
Aug 22 03:22:03: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 10.36.192.97
Aug 22 14:29:41: SSH2 0: trying to get more bytes than in ssh_buffer
cusred024c4n01#            sh clo
15:06:59.790 UTC Thu Aug 22 2013
cusred024c4n01#
Looking at the Spanning tree output it looks like it is pretty stable as there are no recent or frequent topology changes. However you do have some sort of loop on your network on Vlan 2 per you logs. I would start your troubleshooting with vlan 2. If you need further assistance troubleshooting the issue, it may be best for you to engage Cisco TAC if you have a service contract with them for this device.
