High CPU Load
huaingomez
I'm having this problem, my router Cisco 2801 is having, each time more frequently, these episodes of very high CPU Load.
I don't have the knowledge to pinpoint tha cause of this situation, can anybody help me based in the information bellow what steps should i follow to solve this situation?
Thanks in advance
99999999999999999999999999999999999999999999966666
999999999999999999999999999999999999999999999666666666688888
100 *********************************************
90 *********************************************
80 *********************************************
70 **************************************************
60 **************************************************
50 **************************************************
40 **************************************************
30 **************************************************
20 **************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
949399911677421128999799799999294989687955399911323682112334
973889895252921642899895499599496559408993999071064453996672
100 * *** *** ** ***** * * * * **
90 * * *** *** ** ***** * *** * *** *
80 * * *** * ******* ***** * *** *** *#* *
70 * * *** ** ************* * *** *** *#* *
60 * * *#* *** ************* * ******#* *#* **
50 *** *#* **** **********### #**#****#** *#* **
40 #***### **** *##**##*##### #*###***#****#* ** ***
30 #***### **** ############# #*###*####**##* ***## **##
20 #*#*###***##** **#############*###############* **###****###
10 ############################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
1 1 1
999999999998599499999990999999453584857435999990909995563343333454999999
999999999992399799999990999991017825982421999990909994877729899815999999
100 *********** ** ************* *********** ******
90 *********** ** ************** * *********** ******
80 ************ ** ************** * * *********** ******
70 ************ ** *******#****** * * * *********** * ******
60 ***#******** ** *******#****** ** *** *********** ** ******
50 *#*#*#*****************#*#**#* * ****** *************** *********
40 *###*#*****************#*#**#*******#*** ****##*****#****************#**
30 ######**************#*#######*******#*******####*#*##***************##*#
20 ######**************#########******##*******####*####**************#####
10 ######*************##########*****###*****###########*************######
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
sh proc cpu sort 5sec | ex 0.00% 0.00% 0.00%
CPU utilization for five seconds: 99%/95%; one minute: 68%; five minutes: 53%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 754764 107852 6998 2.01% 1.21% 0.85% 0 Load Meter
104 26164348 5197908 5033 0.88% 1.06% 0.80% 0 IP Input
40 3860264 530088 7282 0.48% 0.28% 0.25% 0 Per-Second Jobs
167 1104820 17827874 61 0.08% 0.10% 0.13% 0 HQF Shaper Backg
168 641868 5067447 126 0.08% 0.04% 0.05% 0 RBSCP Background
315 1413340 15692385 90 0.08% 0.09% 0.11% 0 PPP Events
332 346444 530408 653 0.08% 0.02% 0.00% 0 NAT MIB Helper
137 7176 2311 3105 0.08% 0.01% 0.00% 0 TCP Timer
188 5936 117 50735 0.08% 0.04% 0.02% 194 Virtual Exec
98 96244 90238 1066 0.08% 0.00% 0.00% 0 CDP Protocol
101 549328 379557 1447 0.08% 0.01% 0.00% 0 ADJ resolve proc
338 581504 2077510 279 0.08% 0.03% 0.02% 0 MLD
311 2228496 15713671 141 0.08% 0.16% 0.19% 0 PPP manager
18 962028 339959 2829 0.00% 0.03% 0.02% 0 ARP Input
49 1135840 9465 120004 0.00% 0.03% 0.04% 0 Per-minute Jobs
153 299948 762127 393 0.00% 0.03% 0.05% 0 CEF: IPv4 proce
s
5 1361412 87428 15571 0.00% 0.15% 0.17% 0 Check heaps
177 1023944 1025001 998 0.00% 0.08% 0.07% 0 FW DP Inspect pr
238 338452 2579393 131 0.00% 0.02% 0.00% 0 Atheros LED Ctro
312 626564 1017239 615 0.00% 0.04% 0.05% 0 IP NAT Ager
314 599628 98430 6091 0.00% 0.02% 0.00% 0 DHCPD Receive
319 886472 5148115 172 0.00% 0.04% 0.05% 0 FR Broadcast Out
Have you checked that there is no excessive logging enabled on the router?
John
**Please rate posts you find helpful**
7 Replies 7
saif musa
Level 4
Level 4
Dose it happened just when downloading or always ? which services dose you router works for ( examole natting, Qos, cme ... etc ). ?
anyway you got to stop all debugs on the router first by entering the command undebug all . then chick if there is any diffrances
I don't think there is any debug running.
If a use the command show debug, it returns 2 blank lines, nothing else.
Any other idea?
John
Besides show debug, there is another way to deter if there excessive logging?
Besides the notification of high cpu notification it doesn't appear to me there is excessive logging.
What do you think?
RT2801-IGLVEN-BARB#sh logging history
Syslog History Table:1 maximum table entries,
saving level warnings or higher
 43 messages ignored, 0 dropped, 0 recursion drops
 1923 table entries flushed
 SNMP notifications enabled, 1922 notifications sent
   entry number 1924 : IVR-3-LOW_CPU_RESOURCE
    IVR: System experiencing high cpu utilization (96/100).
     Call (callID=62978) is rejected.
    timestamp: 105990073
Joseph W. Doherty
What's the aggregate traffic volume, passing through the router, when you see the high CPU?
huaingomez
This is weird, i have a squid proxy behind the router, i had implemented bandwidth control through Delay Pools, well, it occurred to me that it could be the problem, to be honest i was just blindly guessing, so i removed the Delay Pools instructions from my proxy's configuration, and magically everything went back to normal in the router and it is that way ever since.
I post this here because it may be usefull for some one somewhere.
