Ip statics more bandwidth than dinamic (DHCP)
erdosain99
Hi. I want to control the bandwidth of the dynamic ip provided by DHCP.
I want, static ip have more bandwidth.
How could I accomplish this?
This is my configuration file
! Last configuration change at 17:49:07 UTC Mon Jun 6 2016
version 15.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.0.150.1 10.0.150.153
ip dhcp excluded-address 192.168.9.1 192.168.9.153
ip dhcp pool Red150
 network 10.0.150.0 255.255.255.0
 default-router 10.0.150.1
 dns-server 192.168.1.1
 lease 0 2
ip dhcp pool Red9
 network 192.168.9.0 255.255.255.0
 default-router 192.168.9.1
 lease 0 2
ip name-server 192.168.1.1
no ipv6 cef
voice-card 0
license udi pid CISCO2901/K9 sn FTX180581WJ
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.1.11 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.9.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 switchport access vlan 150
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface Vlan1
 no ip address
interface Vlan150
 ip address 10.0.150.1 255.255.255.0
 ip nat inside
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 109 interface GigabitEthernet0/0 overload
ip nat inside source list 150 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 109 remark ==Red9==
access-list 109 permit ip 192.168.9.0 0.0.0.255 any
access-list 110 remark ==DHCP-Red9==
access-list 150 remark ==Red 150==
access-list 150 permit ip 10.0.150.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Reza Sharifi
Assigning IPs (static or dynamic) has no relation to the speed of the port where the device is connected.  DHCP or static are 2 ways that you can assign IPs to the end devices.  If you want to rate limit you need to look at QOS. See below link:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfcar.html
Hi.
thanks.
I know... but i want to rate limit to the ip static and dinamyc
for example.
if the ip was delivered from the dhcp i wan that thas machine have less bandwith.....
for example: pcs within a certain range (acces list with that ips??) have less bandwith.
