High CPU Processes on MPLS 2821
steven.t27
Hello
I have a 2821 router which 99% CPU load. I check show processes it indicate that the Pool Manager and IP Input causing a lot of problem.
Can anyone help? Thanks
R-MPLS#sh proc
Load for five secs: 99%/29%; one minute: 99%; five minutes: 98%
Time source is NTP, 20:13:41.017 WST Thu Sep 1 2011
CPU utilization for five seconds: 99%/29%; one minute: 99%; five minutes: 98%
PID QTy       PC Runtime (ms)    Invoked   uSecs    Stacks TTY Process
   1 Cwe 400AB0A4            0          3       0 5672/6000   0 Chunk Manager
   2 Csp 4008F0D0       864168    5429090     159 2524/3000   0 Load Meter
   3 Mwe 41FEF484      2620732    9724423     269 4324/6000   0 LDP
   4 Mwe 421EE1E0            0          1       023372/24000  0 EDDRI_MAIN
   5 Lst 400A7F68     26159996    2804359    9328 5392/6000   0 Check heaps
   6 Cwe 400AF138   1401703808  252355086    5554 5480/6000   0 Pool Manager
   7 Mst 411497AC            0          2       0 5496/6000   0 Timers
   8 Mwe 401124D0         1396     452412       3 5704/6000   0 IPC Dynamic Cach
   9 Mwe 401034B0            0          1       0 5700/6000   0 IPC Zone Manager
  10 Mwe 40102658       111056   27104550       4 5616/6000   0 IPC Periodic Tim
  11 Mwe 401024AC        97876   27104559       3 5640/6000   0 IPC Deferred Por
  12 Mwe 4010318C            0          1       0 5564/6000   0 IPC Seat Manager
  13 Mwe 4010873C            0          1       0 5668/6000   0 IPC BackPressure
  14 Mwe 40259448            0          1       011668/12000  0 OIR Handler
  15 Mwe 402F8624            0          1       023604/24000  0 Crash writer
  16 Msi 403F98BC       131256     904780     145 5496/6000   0 Environmental mo
  17 Mwe 40C68CC4       187904    1520583     123 4748/6000   0 ARP Input
  18 Mwe 40CCB688            0          2       0 5444/6000   0 ATM Idle Timer
  76           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  77      227924   3423030         66  0.00%  0.00%  0.00%   0 CDP Protocol
  78  2524663424-1614061345          0 37.66% 37.35% 36.58%   0 IP Input
  79           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  80           0         4          0  0.00%  0.00%  0.00%   0 TurboACL
  81           0         2          0  0.00%  0.00%  0.00%   0 TurboACL chunk
195   470407752-1600026626          0  2.52%  2.60%  2.57%   0 Tag Input
196       45592   2714562         16  0.00%  0.00%  0.00%   0 Tag Control
197     4516012  18962892        238  0.00%  0.00%  0.00%   0 IP SNMP
198     1287372   9446713        136  0.08%  0.00%  0.00%   0 PDU DISPATCHER
199     8860360   9514382        931  0.00%  0.02%  0.02%   0 SNMP ENGINE
200           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
201           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
202           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
203      217736  27357624          7  0.00%  0.00%  0.00%   0 NTP
204           0        11          0  0.00%  0.00%  0.00%   0 AAA Accounting
205           0         3          0  0.00%  0.00%  0.00%   0 IP-EIGRP: PDM
206      674216   5865759        114  0.00%  0.00%  0.00%   0 IP-EIGRP: PDM
207      471488  57875748          8  0.00%  0.00%  0.00%   0 BGP Router
208           0        75          0  0.00%  0.00%  0.00%   0 Tagcon Addr
209           0         1          0  0.00%  0.00%  0.00%   0 IP-EIGRP: HELLO
210      789664  11731560         67  0.00%  0.00%  0.00%   0 IP-EIGRP: HELLO
211      283860   2693814        105  0.00%  0.00%  0.00%   0 BGP I/O
212     3950944   1811980       2180  0.00%  0.00%  0.00%   0 BGP Scanner
R-MPLS#
R-MPLS#
R-MPLS#
R-MPLS#sh ver
Time source is NTP, 20:13:04.136 WST Thu Sep 1 2011
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(25a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 22-May-09 22:00 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
R-MPLS uptime is 44 weeks, 6 days, 4 hours, 23 minutes
System returned to ROM by Reload Command
System restarted at 15:38:57 WST Fri Oct 22 2010
System image file is "flash:c2800nm-spservicesk9-mz.124-25a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK1246F32R
2 Gigabit Ethernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
R-MPLS#
Reza Sharifi
Have a look at the release notes.  The high CPU issue was supposed to be resolved in 12.2(25a), but may still be there.
Resolved Caveats—Cisco IOS Release 12.4(25a)
Cisco IOS Release 12.4(25a) is a rebuild release for Cisco IOS  Release 12.4(25). The caveats in this section are resolved in Cisco IOS  Release 12.4(25a) but may be open in previous Cisco IOS releases.
CSCek77849
Symptoms: BGP convergence is very slow, and CPU utilization at BGP  router process can reach 100% during the convergence at aggregation  router. During normal operation, if BGP prefixes included in the  aggregation flap, it will also produce high CPU utilization.
This issue shows the following tendencies:
1) The more of the component prefixes belonging to the aggregate-address  entry, the slower the convergence at aggregation router. 2) The more of  the duplicated aggregation component prefixes for aggregate- address  entry, the slower convergence at aggregation router.
Conditions: Any releases would be affected if "aggregate-address" is  configured, and routing updates involving aggregate components are  received every few seconds.
Workaround: Remove the "aggregate-address".
Here is the doc:
http://www.cisco.com/en/US/docs/ios/12_4/release/notes/124MCAVS.html#wp312957
Peter Paluch
Hi Steven,
In addition to Reza's great reply, please have a close look at the following documents about troubleshooting high CPU load particularly with regard to the IP Input process, and on routers generally. It is possible that you are hitting one of the situations described in these docs.
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af3.shtml
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
I assume you are running wth IP CEF activated. Running without CEF can be a major source of these problems, so I am better asking to be sure.
Best regards,
Peter
