11-03-2021 12:00 PM
I have a problem with high CPU processing on the switch.
I tried to run EEM from the link below on the device (WS-C2960-24PC-L), but it doesn't have the event command
switchA(config)#event ?
% Unrecognized command
But if I run it on device WS-C2960X-24PS-L, I can get it normally
switchB(config)#event ?
manager Event Manager configuration commands
Can something help me how do I apply EEM to identify high CPU consumption?
7876609866877777796987988777697796877767766678888766777678786969798686
6529905965092538325090620941439907720399129938064699582440479143259965
100 ** * *
90 * *** * ** * * * * * * * * * ** *
80 ** *** ** * * * ** **** **** * * ***** ** * * * * ** *
70 **************************** ************ ************* ****** *******
60 **********************************************************************
50 ######################################################################
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
* = maximum CPU% # = average CPU%
11-03-2021 12:11 PM
From switch A post below information :
show version
show processes cpu sorted | ex 0.00
=====️ Preenayamo Vasudevam ️=====
11-03-2021 12:41 PM
I've already done this, but the process presented is low, and it also reports that it is being affected by a bug in another device model, but it shouldn't be above 80% CPU.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsi78581?rfs=iqvred
switch#show processes cpu sorted | e 0.00
CPU utilization for five seconds: 41%/28%; one minute: 49%; five minutes: 51%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
121 40672710 71039895 572 5.59% 1.85% 1.21% 0 Hulc LED Process
73 178990503 83544041 2142 0.79% 9.67% 12.27% 0 HLFM address lea
101 670 219 3059 0.47% 0.56% 0.15% 1 SSH Process
188 8066270 51998089 155 0.47% 0.25% 0.27% 0 Spanning Tree
60 1679032 157511637 10 0.15% 0.07% 0.08% 0 Fifo Error Detec
130 1076273 604385 1780 0.15% 0.04% 0.01% 0 HQM Stack Proces
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24PC-L 12.2(55)SE12 C2960-LANBASEK9-M
I'm recommended version
11-03-2021 01:26 PM
EEM is only supported on the Catalyst 2960X/XR (on 15.2(4)E and higher versions), not on the non-X/XR models.
11-04-2021 10:38 AM
Is there any other way I can identify CPU spikes?
11-04-2021 03:08 PM
your best option is an external SNMP host. Below is a link to a list of a few free tools.
The configuration of your switch would look something like this:
C2960(config)# process cpu threshold type total rising 80 interval 5 falling 20 interval 5 switch 1
C2960(config)#snmp-server host host_ip_addr
C2960(config)#snmp-server enable traps cpu threshold
