High cpu spike in cisco 3750X switch
vijay kumar
Level 2
Level 2
Hi All,
We are using three 3750X switches in stack. we are seeing the cpu spike is reaching 100% once in a 2 hours or three hours . But the average CPU is upto 40% only .
we are using this switch as L2 and L3 also with PBR. IS this spikes are expected ? Kindly suggest me
BR//
Vijay.
7 Replies 7
Leo Laohoo
Vijay,
What IOS version are you using?
For a 3750X, use IOS version 12.2(55)SE8. If you need to use 15.X, then use 15.0(2)SE4.
Sent from Cisco Technical Support Nintendo App
Hi All,
I'm hoping you can help.
Having the same issue too.  Daily CPU spikes on with pair of stacked 3750X switches.
I upgraded the IOS to c3750e-universalk9-mz.152-3.E2.bin and the issue went away for a week.
It then returned, though not as often, this time two or three times a week.  Always at the same time period though, between roughly 08:19 and 9:00 am.
There are no active sessions on the stack at the time running commands.
I suspected the HULC led process but the cpu % for it only dropped from 21% to 19% once the cpu usage returned to ok level.  See during and after output below...
DURING high cpu alert à
3750STACK#sh processes cpu
CPU utilization for five seconds: 94%/36%; one minute: 93%; five minutes: 93%
PID Runtime(ms)     Invoked     uSecs   5Sec   1Min   5Min TTY Process
   1       11102     132583         83 0.00% 0.00% 0.00%   0 Chunk Manager
   2       73211     1927461         37 0.00% 0.01% 0.00%   0 Load Meter
   3       2106         130     16200 0.32% 1.97% 0.45%   1 SSH Process
   4   240689544   10262242     23453 7.53% 2.17% 2.40%   0 Check heaps
   5       3240       46595         69 0.00% 0.00% 0.00%   0 Pool Manager
   6           0           1         0 0.00% 0.00% 0.00%   0 DiscardQ Backgr                                               o
   7           0           2         0 0.00% 0.00% 0.00%   0 Timers
   8         664       31373         21 0.00% 0.00% 0.00%   0 WATCH_AFS
   9     598995   38548259         15 0.00% 0.01% 0.00%   0 HUSB Console
10           8           5       1600 0.00% 0.00% 0.00%   0 License Client                                                 N
11   26812910     160161     167413 0.00% 0.21% 0.25%   0 Licensing Auto                                                U
12         227         12     18916 0.00% 0.00% 0.00%   0 Image License br
13   16873425   27059329       623 0.00% 0.16% 0.21%   0 ARP Input
14     598746     9952520         60 0.00% 0.00% 0.02%   0 ARP Background
15           0           1         0 0.00% 0.00% 0.00%   0 CEF MIB API
16           0           2         0 0.00% 0.00% 0.00%   0 AAA_SERVER_DEADT
17           0           1        0 0.00% 0.00% 0.00%   0 Policy Manager
18         75         19       3947 0.00% 0.00% 0.00%   0 Entity MIB API
19           0           1         0 0.00% 0.00% 0.00%   0 IFS Agent Manage
20       68751     1915768         35 0.00% 0.00% 0.00%   0 IPC Event Notifi
21     106701     9330161         11 0.00% 0.00% 0.00%   0 IPC Mcast Pendin
22       5991     160169         37 0.00% 0.00% 0.00%   0 IPC Dynamic Cach
23           0           1         0 0.00% 0.00% 0.00%   0 IPC Session Serv
24           0           1         0 0.00% 0.00% 0.00%   0 IPC Zone Manager
25     112321     9330200         12 0.00% 0.02% 0.00%   0 IPC Periodic Tim
26     108497     9330168         11 0.00% 0.00% 0.00%   0 IPC Deferred Por
27           0           1         0 0.00% 0.00% 0.00%   0 IPC Process leve
28     993291     4947039       200 0.00% 0.00% 0.00%   0 IPC Seat Manager
29       5093     550382         9 0.00% 0.00% 0.00%   0 IPC Check Queue
30           8         25       320 0.00% 0.00% 0.00%   0 IPC Seat RX Cont
31           0           1         0 0.00% 0.00% 0.00%   0 IPC Seat TX Cont
32       9944     963755         10 0.00% 0.00% 0.00%   0 IPC Keep Alive M
33       53369     1921951         27 0.00% 0.00% 0.00%   0 IPC Loadometer
34           0           1        0 0.00% 0.00% 0.00%   0 IPC Session Deta
35         133           6     22166 0.00% 0.00% 0.00%   0 PrstVbl
36           0           1         0 0.00% 0.00% 0.00%   0 Crash writer
37           0           1         0 0.00% 0.00% 0.00%   0 Exception contro
38           0           3         0 0.00% 0.00% 0.00%   0 License IPC stat
39           0           1         0 0.00% 0.00% 0.00%   0 License IPC serv
40     170000     9637314         17 0.00% 0.00% 0.00%   0 GraphIt
41       3055         454       6729 0.00% 0.00% 0.00%   0 crypto sw pk pro
42           0           2         0 0.00% 0.00% 0.00%   0 SMART
43           0           2         0 0.00% 0.00% 0.00%   0 XML Proxy Client
44          0           1         0 0.00% 0.00% 0.00%   0 ARP Snoop
45       82537     9545454         8 0.00% 0.00% 0.00%   0 Dynamic ARP Insp
46           0           1         0 0.00% 0.00% 0.00%   0 Critical Bkgnd
47     8751222   11437155       765 0.31% 0.11% 0.11%   0 Net Background
48           0           6         0 0.00% 0.00% 0.00%   0 IDB Work
49       23237     427516         54 0.00% 0.00% 0.00%  0 Logger
50       91735     9545699         9 0.00% 0.00% 0.00%   0 TTY Background
51           0           4         0 0.00% 0.00% 0.00%   0 CTS CORE
52         41         66       621 0.00% 0.00% 0.00%   0 SXP CORE
53         16          21       761 0.00% 0.00% 0.00%   0 IF-MGR control p
54         236       10363         22 0.00% 0.00% 0.00%   0 IF-MGR event pro
55           0           4         0 0.00% 0.00% 0.00%   0 IP Admission HA
56     2127160   18496529       115 1.43% 2.59% 2.81%   0 Net Input
57     2871545     1957373       1467 0.00% 0.04% 0.05%   0 Compute load avg
58     6837616     171753     39810 0.00% 0.05% 0.05%   0 Per-minute Jobs
59     6492717     9722264       667 0.00% 0.14% 0.18%   0 Per-Second Jobs
60           0           1         0 0.00% 0.00% 0.00%   0 Inode Table Dest
61           0           1         0 0.00% 0.00% 0.00%   0 AggMgr Process
62         241       11495         20 0.00% 0.00% 0.00%   0 Transport Port A
63     1303619     2731833       477 0.00% 0.02% 0.00%   0 HC Counter Timer
64           0           1         0 0.00% 0.00% 0.00%   0 SFF8472
65           8           4       2000 0.00% 0.00% 0.00%   0 EEM ED Identity
66           0           4         0 0.00% 0.00% 0.00%   0 EEM ED MAT
67     610244     2038417       299 0.00% 0.00% 0.00%   0 EEM ED ND
68         42         79       531 0.00% 0.00% 0.00%   0 USB Startup
69     508478   183350237         2 0.15% 0.14% 0.14%   0 DownWhenLooped
70           0           1         0 0.00% 0.00% 0.00%   0 Hulc Warm Upgrad
71           0           1         0 0.00% 0.00% 0.00%   0 HRPC hdwl reques
72           0           1         0 0.00% 0.00% 0.00%   0 Hulc EEM Process
73           0           1         0 0.00% 0.00% 0.00%   0 HRPC lpip reques
74           0           2         0 0.00% 0.00% 0.00%   0 HLPIP Sync Proce
75           0           1         0 0.00% 0.00% 0.00%   0 HRPC Multi-FS Sy
76           8         58       137 0.00% 0.00% 0.00%   0 HULC multifs pro
77           0           1         0 0.00% 0.00% 0.00%   0 HRPC hnetwpol re
78           0           1         0 0.00% 0.00% 0.00%   0 HRPC EnergyWise
79           0           1         0 0.00% 0.00% 0.00%   0 HRPC actual powe
80           0           1         0 0.00% 0.00% 0.00%   0 HRPC ipadm reque
81       17000     320399         53 0.00% 0.00% 0.00%   0 PSP Timer
82       3122         12     260166 0.00% 0.00% 0.00%   0 X2 HAMM detect p
83           0           1         0 0.00% 0.00% 0.00%   0 Madmax Process
84           0           1         0 0.00% 0.00% 0.00%   0 HRPC asic-stats
85   270958294   193479043       1400 3.35% 3.50% 3.89%   0 RedEarth I2C dri
86   622823829   119951017       5192 4.15% 5.07% 5.12%   0 RedEarth Tx Mana
87   16915003   90168868       187 0.63% 0.32% 0.28%   0 RedEarth Rx Mana
88       26654     1927466         13 0.00% 0.00% 0.00%   0 HULC Thermal Pro
89           0           1         0 0.00% 0.00% 0.00%   0 HRPC hsm request
90         126         135       933 0.00% 0.00% 0.00%   0 Stack Mgr
91         797         157       5076 0.00% 0.00% 0.00%   0 Stack Mgr Notifi
92     4110021     1097969       3743 0.00% 0.02% 0.03%   0 Adjust Regions
93     492842     4798973       102 0.00% 0.02% 0.00%  0 hrpc -> response
94     431621   12969555         33 0.00% 0.00% 0.00%   0 hrpc -> request
95     4413600   12503347       352 0.15% 0.04% 0.03%   0 hrpc <- response
96           0           3         0 0.00% 0.00% 0.00%   0 HRPC hcomp reque
97     2229885   48184196         46 0.00% 0.15% 0.14%   0 yeti2_emac_proce
98           0         22         0 0.00% 0.00% 0.00%   0 HULC Device Mana
99     116818     380967       306 0.00% 0.00% 0.00%   0 HRPC hdm non blo
100           0           4         0 0.00% 0.00% 0.00%   0 HRPC hdm blockin
101       99913     1915737         52 0.00% 0.00% 0.00%   0 HIPC bkgrd proce
102           0          1         0 0.00% 0.00% 0.00%   0 RTTYS Process
103           0           1         0 0.00% 0.00% 0.00%   0 HRPC hautosecure
104     1044452     3738380       279 0.00% 0.00% 0.00%   0 Hulc Port-Securi
105     649202     3087315      210 0.00% 0.00% 0.00%   0 HRPC hpsecure re
106           0           3         0 0.00% 0.00% 0.00%   0 HRPC hfbm reques
107         241         83       2903 0.00% 0.00% 0.00%   0 hulc cfg mgr mas
108           0           1         0 0.00% 0.00% 0.00%   0 HRPC hrcmd reque
109           0         30         0 0.00% 0.00% 0.00%   0 HRPC emac reques
110         16         10       1600 0.00% 0.00% 0.00%   0 HULC EMAC Proces
111           9           7       1285 0.00% 0.00% 0.00%   0 HRPC hulc misc r
112       61631     3203191         19 0.00% 0.00% 0.00%   0 HVLAN main bkgrd
113           0          2         0 0.00% 0.00% 0.00%   0 HVLAN Mapped Vla
114           0           2         0 0.00% 0.00% 0.00%   0 Vlan shutdown Pr
115           8         70       114 0.00% 0.00% 0.00%   0 HRPC vlan reques
116           0           1          0 0.00% 0.00% 0.00%   0 HULC VLAN REF Ba
117       6131     160168         38 0.00% 0.00% 0.00%   0 hulc_xps_process
118     207923     1589715       130 0.00% 0.00% 0.00%   0 HRPC ilp request
119     145404     9545317         15 0.00% 0.00% 0.00%   0 Hulc ILP Alchemy
120     791346     640640       1235 0.00% 0.00% 0.00%   0 Strider Tcam Mem
121       44906     232546       193 0.00% 0.00% 0.00%   0 HRPC hlfm reques
122     9188176   238896899         38 0.30% 0.27% 0.32%   0 HLFM address lea
123     131756     9545273         13 0.00% 0.00% 0.00%   0 HLFM aging proce
124       48715     2442975         19 0.00% 0.00% 0.00%   0 HLFM address ret
125       84422       84295       1001 0.00% 0.00% 0.00%   0 HULC PM Vector P
126           0           1         0 0.00% 0.00% 0.00%   0 HPM Msg Retry Pr
127           0           1         0 0.00% 0.00% 0.00%   0 Connection Mgr
128   19244246   188797206       101 0.46% 0.90% 0.95%   0 hpm main process
129       3528       12813       275 0.00% 0.00% 0.00%   0 HPM Stack Sync P
130       9947       30178       329 0.00% 0.00% 0.00%   0 HRPC pm request
131          0           5         0 0.00% 0.00% 0.00%   0 HPM if_num mappi
132   145074491     9637313     15053 1.08% 1.18% 1.27%   0 hpm counter proc
133   10254698   11963237       857 0.00% 0.08% 0.08%   0 HRPC pm-counters
134           0           4         0 0.00% 0.00% 0.00%   0 hpm vp events ca
135           0           1         0 0.00% 0.00% 0.00%   0 HRPC hcmp reques
136       20119       4718       4264 0.00% 0.00% 0.00%   0 HCEF ADJ Refresh
137           0           1         0 0.00% 0.00% 0.00%   0 hl3md_rpfq_thrl_
138       48393     4798973         10 0.00% 0.00% 0.00%   0 hl3mm_rp
139           0          1         0 0.00% 0.00% 0.00%   0 HACL Queue Proce
140           0           1         0 0.00% 0.00% 0.00%   0 HRPC acl request
141           9         81       111 0.00% 0.00% 0.00%   0 HACL Acl Manager
142           0           1         0 0.00% 0.00% 0.00%   0 HRPC aim request
143           0           5         0 0.00% 0.00% 0.00%   0 HRPC axiom-mgmt
144       52999     4798962         11 0.00% 0.00% 0.00%   0 Hulc Axiom Mgmt
145           0           1         0 0.00% 0.00% 0.00%   0 HRPC backup inte
146       1885       32173         58 0.00% 0.00% 0.00%   0 OBFL TEMP obfl0
147           0           1         0 0.00% 0.00% 0.00%   0 HRPC cdp request
148           0           2         0 0.00% 0.00% 0.00%   0 HULC CISP Proces
149     114619     9552706         11 0.00% 0.00% 0.00%   0 Hulc CTS Process
150           0           1         0 0.00% 0.00% 0.00%   0 HRPC cts request
151           0           1         0 0.00% 0.00% 0.00%   0 HULC Msg Retry P
152       2898       18737       154 0.00% 0.00% 0.00%   0 HRPC dot1x reque
153           0           1         0 0.00% 0.00% 0.00%   0 Dot1X Msg Retry
154       8778       29486       297 0.00% 0.00% 0.00%   0 HULC DOT1X Proce
155           0           1         0 0.00% 0.00% 0.00%   0 HRPC epm vlan pl
156           0          3         0 0.00% 0.00% 0.00%   0 HRPC fmd request
157           0           2         0 0.00% 0.00% 0.00%   0 HULC FMD Config
158           0           1         0 0.00% 0.00% 0.00%   0 HRPC foxhound re
159           0           2          0 0.00% 0.00% 0.00%   0 Hulc Foxhound Pr
160           0           1         0 0.00% 0.00% 0.00%   0 HRPC lldp reques
161           0           2         0 0.00% 0.00% 0.00%   0 MACsec Process
162           0           1         0 0.00% 0.00% 0.00%   0 HRPC macsec requ
163           0           3         0 0.00% 0.00% 0.00%   0 HRPC msp request
164           0           1         0 0.00% 0.00% 0.00%   0 HULC MSP Snoop P
165          0           3         0 0.00% 0.00% 0.00%   0 HRPC system mtu
166           0           5         0 0.00% 0.00% 0.00%   0 HRPC rep request
167           9           4      2250 0.00% 0.00% 0.00%   0 REP Helper Proc
168           0           1         0 0.00% 0.00% 0.00%   0 HRPC sdm request
169           0           1         0 0.00% 0.00% 0.00%   0 SMI MSG Retry Pr
170           8           1       8000 0.00% 0.00% 0.00%   0 HRPC Smart Insta
171     2022536   47406800         42 0.15% 0.06% 0.09%   0 Hulc Storm Contr
172           0           2         0 0.00% 0.00% 0.00%   0 HSTP Sync Proces
173           0           1         0 0.00% 0.00% 0.00%   0 HRPC stp_cli req
174           0         29         0 0.00% 0.00% 0.00%   0 HRPC stp_state_s
175           0           2         0 0.00% 0.00% 0.00%   0 S/W Bridge Proce
176           0         17         0 0.00% 0.00% 0.00%  0 HRPC hudld reque
177           0           1         0 0.00% 0.00% 0.00%   0 HRPC vqpc reques
178           0           1         0 0.00% 0.00% 0.00%   0 HRPC iec_load_ba
179       68128     9545293         7 0.00% 0.00% 0.00%   0 IEC Load balance
180           0           1         0 0.00% 0.00% 0.00%   0 HRPC l2pt qnq rp
181           0         18         0 0.00% 0.00% 0.00%   0 HRPC hled reques
182 2039427150   239961593       8498 21.91% 22.87% 21.92%   0 Hulc LED Process
183           0           1         0 0.00% 0.00% 0.00%   0 HRPC hl3mm reque
184     139280     6640865         20 0.15% 0.01% 0.00%   0 hl3mm
185     817818     7037532        116 0.15% 0.03% 0.00%   0 HL3U bkgrd proce
186     368792     3854799         95 0.00% 0.01% 0.00%   0 HRPC hl3u reques
187     195389     2199130         88 0.00% 0.00% 0.00%   0 HIPV6 bkgrd proc
188     376255     3854795         97 0.00% 0.01% 0.00%   0 HRPC IPv6 Unicas
189       39611     2199054         18 0.00% 0.00% 0.00%   0 HL3U PBR bkgrd p
190       1651       80303         20 0.00% 0.00% 0.00%   0 HL3U PBR n-h res
191           0           1         0 0.00% 0.00% 0.00%   0 HRPC obfl reques
192           0           3         0 0.00% 0.00% 0.00%   0 OBFL Cfg Dispatc
193          0           1         0 0.00% 0.00% 0.00%   0 HRPC dtp request
194           0           1         0 0.00% 0.00% 0.00%   0 HRPC hmedianet p
195           0           1         0 0.00% 0.00% 0.00%   0 HRPC show_forwar
196           0          1         0 0.00% 0.00% 0.00%   0 HRPC snmp reques
197           0           1         0 0.00% 0.00% 0.00%   0 HULC SNMP Proces
198   48175636     1915545     25149 0.30% 0.45% 0.47%   0 HQM Stack Proces
199   26974889     7651862       3525 0.15% 0.19% 0.19%   0 HRPC qos request
200           0           1         0 0.00% 0.00% 0.00%   0 HRPC span reques
201           0           8         0 0.00% 0.00% 0.00%   0 HRPC system post
202           8           9       888 0.00% 0.00% 0.00%   0 Hulc Reload Mana
203         186         443       419 0.00% 0.00% 0.00%   0 HRPC hrcli-event
204       4308       53541         80 0.00% 0.00% 0.00%   0 HCMP sync proces
205           0           2         0 0.00% 0.00% 0.00%   0 image mgr
206           0           1         0 0.00% 0.00% 0.00%   0 HRFS OIR Proc
207         77         48       1604 0.00% 0.00% 0.00%   0 HL2MCM
208          66         24       2750 0.00% 0.00% 0.00%   0 HL2MCM
209           0           6         0 0.00% 0.00% 0.00%   0 Hulc SM10G Infra
210           0           2        0 0.00% 0.00% 0.00%   0 SM RBCP Monitor
211         60         395       151 0.00% 0.00% 0.00%   0 AAA Server
212         60         468       128 0.00% 0.00% 0.00%   0 AAA ACCT Proc
213           0           1         0 0.00% 0.00% 0.00%   0 ACCT Periodic Pr
214           0           1         0 0.00% 0.00% 0.00%   0 AAA System Acct
215           0           1         0 0.00% 0.00% 0.00%   0 Webauth client
216           0           1         0 0.00% 0.00% 0.00%   0 Auth-proxy HTTP
217           0           1         0 0.00% 0.00% 0.00%   0 IP Admin SM Proc
218   19698787   20594265       956 0.15% 0.25% 0.26%   0 CDP Protocol
219           0           1         0 0.00% 0.00% 0.00%   0 IPv6 Access Cont
220     331601     589927       562 0.00% 0.00% 0.00%   0 mdns Timer Proce
221           0           2        0 0.00% 0.00% 0.00%   0 AAA Dictionary R
222       4078       80312         50 0.00% 0.00% 0.00%   0 DHCP Snooping
223           0           1         0 0.00% 0.00% 0.00%   0 DHCP Snooping db
224           0           2         0 0.00% 0.00% 0.00%   0 Dot1x Mgr Proces
225           0           1         0 0.00% 0.00% 0.00%   0 EAP Framework
226           0           1         0 0.00% 0.00% 0.00%   0 EAP Test
227     212322     9545286         22 0.00% 0.00% 0.00%   0 FHRP Main thread
228           0           1         0 0.00% 0.00% 0.00%   0 TRACK Main threa
229           0           1         0 0.00% 0.00% 0.00%   0 TRACK Client thr
230           0           1         0 0.00% 0.00% 0.00%   0 VRRP Main thread
231     4454206   142408722         31 0.00% 0.15% 0.22%   0 VRRS Main thread
232           0           2         0 0.00% 0.00% 0.00%   0 CEF switching ba
233       80137       81663       981 0.00% 0.00% 0.00%   0 IP ARP Adjacency
234     5962724   238894645         24 0.15% 0.27% 0.27%   0 IP ARP Retry Age
235     8080754   19460065       415 0.00% 0.17% 0.18%   0 IP Input
236           0           1          0 0.00% 0.00% 0.00%   0 ICMP event handl
237     345866   18511291         18 0.00% 0.00% 0.00%   0 IP ARP Track
238       17301     9567777         1 0.00% 0.00% 0.00%   0 fnvRootHubPortSt
239           0           1         0 0.00% 0.00% 0.00%   0 tHUB
240     348694   94715185         3 0.31% 0.11% 0.10%   0 MDFS MFIB Proces
241           0           1         0 0.00% 0.00% 0.00%   0 ADJ NSF process
242           0           1         0 0.00% 0.00% 0.00%   0 IPv6 ping proces
243           0           2         0 0.00% 0.00% 0.00%   0 KRB5 AAA
244           8           2       4000 0.00% 0.00% 0.00%   0 MKA
245         93         168       553 0.00% 0.00% 0.00%   0 SpanTree Flush
246           0           2         0 0.00% 0.00% 0.00%   0 REP Topology cha
247           0           2         0 0.00% 0.00% 0.00%   0 RIB LM VALIDATE
248     100711     9546318         10 0.00% 0.00% 0.00%   0 mDNS
249         17         32       531 0.00% 0.00% 0.00%   0 SMI Director DB
250     288336     1784723       161 0.00% 0.00% 0.00%   0 SMI CDP Update H
251           9           1       9000 0.00% 0.00% 0.00%   0 SMI Backup Proce
252           0           2         0 0.00% 0.00% 0.00%   0 SMI IBC server p
253           0           1         0 0.00% 0.00% 0.00%   0 SMI IBC client p
254           0           2         0 0.00% 0.00% 0.00%   0 SMI IBC Download
255   23234445   70213416       330 0.15% 0.46% 0.51%   0 Spanning Tree
256       21493     160619       133 0.00% 0.00% 0.00%   0 Spanning Tree St
257           0           2         0 0.00% 0.00% 0.00%   0 CDP Forward Proc
258       2281       16485       138 0.00% 0.00% 0.00%   0 802.1x switch
259     211222     645780       327 0.00% 0.00% 0.00%   0 DTP Protocol
260           0           3         0 0.00% 0.00% 0.00%   0 HRPC IPv6 Host r
261           0           5         0 0.00% 0.00% 0.00%   0 IPv6 Platform Ho
262           0           1         0 0.00% 0.00% 0.00%   0 axiom-module cra
263           0           1         0 0.00% 0.00% 0.00%   0 HRPC dai request
264           0           1         0 0.00% 0.00% 0.00%   0 HULC DAI Process
265           0           1         0 0.00% 0.00% 0.00%   0 HRPC power down
266           0           1         0 0.00% 0.00% 0.00%   0 HRPC ip device t
267           0           1         0 0.00% 0.00% 0.00%   0 HRPC ip source g
268           0           1         0 0.00% 0.00% 0.00%   0 HULC IP Source g
269           0           3         0 0.00% 0.00% 0.00%   0 HRPC rsvp reques
270       12085       3484       3468 0.00% 0.00% 0.00%   0 SpanTree Helper
271     999930     9545260       104 0.00% 0.09% 0.10%   0 PI MATM Aging Pr
272     1464790   96849497         15 0.00% 0.22% 0.33%   0 UDLD
273     438522     5103276         85 0.00% 0.00% 0.00%   0 Port-Security
274           0           2        0 0.00% 0.00% 0.00%   0 Switch Backup In
275           0           2         0 0.00% 0.00% 0.00%   0 IP Host Track Pr
276           0           1         0 0.00% 0.00% 0.00%   0 Link State Group
277       4832     160167         30 0.00% 0.00% 0.00%   0 MMN bkgrd proces
278       33381     960958         34 0.00% 0.00% 0.00%   0 Ethchnl
279       13928       3586       3883 0.00% 0.00% 0.00%   0 VMATM Callback
280           0           1         0 0.00% 0.00% 0.00%   0 XDR background p
281       76228     348800       218 0.00% 0.00% 0.00%   0 XDR mcast
282           0           3         0 0.00% 0.00% 0.00%   0 XDR RP Ping Back
283     446129     897096       497 0.00% 0.00% 0.00%   0 XDR receive
284         16           4       4000 0.00% 0.00% 0.00%   0 IPC LC Message H
285           0           1         0 0.00% 0.00% 0.00%   0 XDR RP Test Back
286       5371     160167         33 0.00% 0.00% 0.00%   0 FRR Background P
287     119371     674593       176 0.00% 0.00% 0.00%   0 CEF background p
288           0           1         0 0.00% 0.00% 0.00%   0 fib_fib_bfd_sb e
289           0           1         0 0.00% 0.00% 0.00%   0 IP IRDP
290           0           1         0 0.00% 0.00% 0.00%   0 Tunnel FIB
291           0           2         0 0.00% 0.00% 0.00%   0 Tunnel
292           0           1         0 0.00% 0.00% 0.00%   0 IPC UDP Input
293           0           1         0 0.00% 0.00% 0.00%   0 CEF RF HULC Conv
294       31709     961052         32 0.00% 0.00% 0.00%   0 IP ACL XDR LC Ba
295     180424     4790387         37 0.00% 0.00% 0.00%   0 CEF: IPv4 proces
296     2793044     9557736       292 0.00% 0.06% 0.05%   0 ADJ background
297     783353   10665500         73 0.00% 0.00% 0.00%   0 MDFS LC Process
298           0           2         0 0.00% 0.00% 0.00%   0 AN
299           0           1         0 0.00% 0.00% 0.00%   0 AN HELPER
300           0           1         0 0.00% 0.00% 0.00%   0 AN CONFIG DOWNLO
301           0           2         0 0.00% 0.00% 0.00%   0 Routing Topology
302       14304       5842       2448 0.00% 0.00% 0.00%   0 IP RIB Update
303     491378       8023     61246 0.00% 0.00% 0.00%   0 NIST rng proc
304     357269   18511297         19 0.00% 0.00% 0.00%   0 Timer Library
305           0           2         0 0.00% 0.00% 0.00%   0 App Route Proces
306           0           1         0 0.00% 0.00% 0.00%   0 IPv6 RIB Cleanup
307           0           1         0 0.00% 0.00% 0.00%   0 IPv6 RIB Event H
308         931       11211         83 0.00% 0.00% 0.00%   0 Auth Manager
309           0          1         0 0.00% 0.00% 0.00%   0 Critical Auth
310           0           1         0 0.00% 0.00% 0.00%   0 EPM MAIN PROCESS
311           0           1         0 0.00% 0.00% 0.00%   0 Timer Handler Pr
312           0           1        0 0.00% 0.00% 0.00%   0 EPM Downlad Mana
313     108885     1916098         56 0.00% 0.00% 0.00%   0 EPM ACL PLUG-IN
314     319985   19022800         16 0.00% 0.00% 0.00%   0 SVM UT Process
315           0           1         0 0.00% 0.00% 0.00%   0 CMD HANDLER
316         411       4415         93 0.00% 0.00% 0.00%   0 TCP Timer
317       6123       9293       658 0.00% 0.00% 0.00%   0 TCP Protocols
318       24378     9669446         2 0.00% 0.00% 0.00%   0 Socket Timers
319         476       32154         14 0.00% 0.00% 0.00%   0 HTTP CORE
320       1346     120461         11 0.00% 0.00% 0.00%   0 Cluster L2
321       38325     960959         39 0.00% 0.00% 0.00%   0 Cluster RARP
322     153135     1524247       100 0.00% 0.00% 0.00%   0 Cluster Base
323           0           2         0 0.00% 0.00% 0.00%   0 Dot1x Supplicant
324           0          2         0 0.00% 0.00% 0.00%   0 Dot1x Supplicant
325           0           2         0 0.00% 0.00% 0.00%   0 Dot1x Supplicant
326           0           1         0 0.00% 0.00% 0.00%   0 DSensor HTTP
327           0           2        0 0.00% 0.00% 0.00%   0 CEF RP Backgroun
328         176       8800         20 0.00% 0.00% 0.00%   0 Flow Exporter Ti
329           0           1         0 0.00% 0.00% 0.00%   0 DCT Bkgd Process
330           0           4         0 0.00% 0.00% 0.00%   0 MFIB Master back
331           0           2         0 0.00% 0.00% 0.00%   0 ENABLE AAA
332         888       8818       100 0.00% 0.00% 0.00%   0 MVPN Mgr Process
333           0           2         0 0.00% 0.00% 0.00%   0 Multicast Offloa
334       1975       9282       212 0.00% 0.00% 0.00%   0 RARP Input
335           9           7       1285 0.00% 0.00% 0.00%   0 static
336     1711242     618410       2767 0.00% 0.00% 0.00%   0 ADJ resolve proc
337           0           1         0 0.00% 0.00% 0.00%   0 IPv6 Static Hand
338           0           1         0 0.00% 0.00% 0.00%   0 MAB Framework
339           0          2         0 0.00% 0.00% 0.00%   0 Media Services P
340     513274     963412       532 0.00% 0.00% 0.00%   0 QoS stats proces
341           0           1         0 0.00% 0.00% 0.00%   0 LICENSE AGENT
342           0           2         0 0.00% 0.00% 0.00%   0 REP LSL Proc
343           0           2         0 0.00% 0.00% 0.00%   0 REP BPA/EPA Proc
344           0           5         0 0.00% 0.00% 0.00%   0 SNMP Timers
345           0           1         0 0.00% 0.00% 0.00%   0 HRPC hwccp reque
346           0           3         0 0.00% 0.00% 0.00%   0 HULC_WCCP_BACKGR
347           0           1         0 0.00% 0.00% 0.00%   0 HRPC dhcp snoopi
348           0           5         0 0.00% 0.00% 0.00%   0 HULC DHCP Snoopi
349           0           1         0 0.00% 0.00% 0.00%   0 HRPC sisf reques
350           8           3       2666 0.00% 0.00% 0.00%   0 HULC SISF Proces
351           0           1         0 0.00% 0.00% 0.00%   0 HULC SISF Source
352     4493831   19745136       227 0.15% 0.10% 0.11%   0 Inline Power
353     6282892   21095284       297 0.63% 0.27% 0.28%   0 Marvell wk-a Pow
354       65642     480494       136 0.00% 0.00% 0.00%   0 HULC stack power
355       20919     320321         65 0.00% 0.00% 0.00%   0 HRPC stack power
356       16431       15711      1045 0.00% 0.00% 0.00%   0 IGMPSN L2MCM
357           0           1         0 0.00% 0.00% 0.00%   0 IGMPSN MRD
358     111500     676864       164 0.00% 0.00% 0.00%   0 IGMPSN
359           0           1         0 0.00% 0.00% 0.00%   0 IGMPQR
360           0           3         0 0.00% 0.00% 0.00%   0 L2TRACE SERVER
361           0           2         0 0.00% 0.00% 0.00%   0 AUTO LAG Protoco
362       12859       15699       819 0.00% 0.00% 0.00%   0 MLDSN L2MCM
363          0           1         0 0.00% 0.00% 0.00%   0 MRD
364           0           1         0 0.00% 0.00% 0.00%   0 MLD_SNOOP
365           0           1         0 0.00% 0.00% 0.00%   0 TDP Discovery
366     2271936   93447201         24 0.00% 0.10% 0.11%   0 MDFS RP process
367           0           1         0 0.00% 0.00% 0.00%   0 EM Background Pr
368           0           2         0 0.00% 0.00% 0.00%  0 AAA Cached Serve
369           0           2         0 0.00% 0.00% 0.00%   0 MRIB Process
370       19938       97052       205 0.00% 0.00% 0.00%   0 HRPC hl2mcm igmp
371         25         90       277 0.00% 0.00% 0.00%   0 HRPC hl2mcm mlds
372           0           3         0 0.00% 0.00% 0.00%   0 LDAP process
373           0           2         0 0.00% 0.00% 0.00%   0 Crypto Support
374           9           1       9000 0.00% 0.00% 0.00%   0 IPSECv6 PS Proc
375           0           1         0 0.00% 0.00% 0.00%   0 Key chain liveke
376         61         278       219 0.00% 0.00% 0.00%   0 Collection proce
377           0          2         0 0.00% 0.00% 0.00%   0 LINE AAA
378         36         71       507 0.00% 0.00% 0.00%   0 LOCAL AAA
379     4318068   142408616         30 0.15% 0.18% 0.21%   0 MMA DB TIMER
380           8           1       8000 0.00% 0.00% 0.00%   0 MMA MSG MCOL
381           0           1         0 0.00% 0.00% 0.00%   0 Opaque Database
382         34         755         45 0.00% 0.00% 0.00%   0 TACACS+
383       3683       4438       829 0.00% 0.00% 0.00%   0 TPLUS
384     1181450     480481       2458 0.00% 0.00% 0.00%   0 HULC ISM FNF
385     120317       12370       9726 0.00% 0.00% 0.00%   0 hulc running con
386         427        33     12939 0.00% 0.00% 0.00%   0 crypto engine pr
387           0           1         0 0.00% 0.00% 0.00%   0 RSA background p
388         820       10714         76 0.00% 0.00% 0.00%   0 Crypto CA
389           0           1         0 0.00% 0.00% 0.00%   0 Crypto PKI-CRL
390     357905     9597571         37 0.00% 0.01% 0.00%   0 Crypto IKEv2
391           0           1         0 0.00% 0.00% 0.00%   0 IKEv2 AAA handle
392           0           1         0 0.00% 0.00% 0.00%   0 encrypt proc
393           0           2         0 0.00% 0.00% 0.00%   0 CRYPTO MAP FREE
394           0           1         0 0.00% 0.00% 0.00%   0 Crypto INT
395           0           2         0 0.00% 0.00% 0.00%   0 Crypto IKE Dispa
396           0           3         0 0.00% 0.00% 0.00%   0 Crypto IKMP
397           0           1         0 0.00% 0.00% 0.00%   0 IPSEC manual key
398       25451    480482         52 0.00% 0.00% 0.00%   0 IPSEC key engine
399           0           5         0 0.00% 0.00% 0.00%   0 Crypto ACL
400           0           1         0 0.00% 0.00% 0.00%   0 Crypto PAS Proc
401           0           5         0 0.00% 0.00% 0.00%   0 IPSec background
402           0           2         0 0.00% 0.00% 0.00%   0 MMON PROCESS
403     4351735   142408695         30 0.31% 0.16% 0.21%   0 MMA DP TIMER
404     4492904 299961959         14 0.00% 0.14% 0.12%   0 MMON MENG
405           0           1         0 0.00% 0.00% 0.00%   0 HRPC x_setup req
406           0           2         0 0.00% 0.00% 0.00%   0 REP Switch Helpe
407           0           1          0 0.00% 0.00% 0.00%   0 Licensing MIB pr
408           0         23         0 0.00% 0.00% 0.00%   0 VTP Trap Process
409         67           5     13400 0.00% 0.00% 0.00%   0 OBFL MSG obfl0
410         267       8934         29 0.00% 0.00% 0.00%   0 ASP Process Crea
411         57         391       145 0.00% 0.00% 0.00%   0 AAA SEND STOP EV
412           0           1         0 0.00% 0.00% 0.00%   0 Test AAA Client
413           8           8       1000 0.00% 0.00% 0.00%   0 DCM Core Thread
414           0           2         0 0.00% 0.00% 0.00%   0 DHCP Security He
415           0           1         0 0.00% 0.00% 0.00%   0 dcm_cli_engine
416           0           3         0 0.00% 0.00% 0.00%   0 dcm_cli_provider
417           8           4       2000 0.00% 0.00% 0.00%   0 EEM ED Generic
418           8           4       2000 0.00% 0.00% 0.00%   0 EEM ED Routing
419       20623     221652         93 0.00% 0.00% 0.00%   0 EEM ED Syslog
420           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Media Ser
421           0           1        0 0.00% 0.00% 0.00%   0 Syslog Traps
422         67           5     13400 0.00% 0.00% 0.00%   0 OBFL ENV obfl0
423       6040     160167         37 0.00% 0.00% 0.00%   0 vlmap logger
424           0           1         0 0.00% 0.00% 0.00%   0 HCD Process
425           0           1         0 0.00% 0.00% 0.00%   0 HRPC cable diagn
426           0           1         0 0.00% 0.00% 0.00%   0 HRPC archive_dnl
427           0           1         0 0.00% 0.00% 0.00%   0 HRPC rsu request
428           0           2         0 0.00% 0.00% 0.00%   0 DiagCard9/-1
429           0           1         0 0.00% 0.00% 0.00%   0 Online Diag EEM
430     2327145   80270462         28 0.15% 0.06% 0.07%   0 PM Callback
432       8265     770432         10 0.00% 0.00% 0.00%   0 dhcp snooping sw
434         60         106       566 0.00% 0.00% 0.00%   0 EEM Server
435         17          3       5666 0.00% 0.00% 0.00%   0 Call Home proces
436         49         131       374 0.00% 0.00% 0.00%   0 EEM Helper Threa
437       11050     160193         68 0.00% 0.00% 0.00%   0 Call Home Timer
438       81341     961300        84 0.00% 0.00% 0.00%   0 Bulkstat-Client
439           0           4         0 0.00% 0.00% 0.00%   0 CTS credentials
440           0           1         0 0.00% 0.00% 0.00%   0 HRPC eee request
441           0           6         0 0.00% 0.00% 0.00%   0 DCM snmp dp Thre
442           8           3       2666 0.00% 0.00% 0.00%   0 snmp dcm ma shim
443           0           2         0 0.00% 0.00% 0.00%   0 EEM Policy Direc
445           9           3       3000 0.00% 0.00% 0.00%   0 EEM ED CLI
446           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Config
447           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Counter
448           0           4         0 0.00% 0.00% 0.00%   0 EEM ED CRASH
449           0           4         0 0.00% 0.00% 0.00%   0 EEM ED DS
450           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Env
451         17           4      4250 0.00% 0.00% 0.00%   0 EM ED GOLD
452           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Interface
453           0           4         0 0.00% 0.00% 0.00%   0 EEM ED IOSWD
454           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Ipsla
455           0           4         0 0.00% 0.00% 0.00%   0 EEM ED None
456           0           4         0 0.00% 0.00% 0.00%   0 EEM ED OIR
457           0           2         0 0.00% 0.00% 0.00%   0 STP FAST TRANSIT
458           0           4         0 0.00% 0.00% 0.00%   0 EEM ED SNMP
459           8           4       2000 0.00% 0.00% 0.00%   0 EEM ED SNMP Obje
460           8           4       2000 0.00% 0.00% 0.00%   0 EEM ED SNMP Noti
461           0           4         0 0.00% 0.00% 0.00%   0 EEM ED Test
462       9016     210491         42 0.00% 0.00% 0.00%   0 EEM ED Timer
463       58035     215404      269 0.00% 0.00% 0.00%   0 Syslog
464       27605     640628         43 0.00% 0.00% 0.00%   0 OBFL I/O Buffer
465           0           6         0 0.00% 0.00% 0.00%   0 RBM CORE
466           0           5         0 0.00% 0.00% 0.00%   0 CSRT RAPID TRANS
467         24           6       4000 0.00% 0.00% 0.00%   0 VLAN Manager
468         51       2680         19 0.00% 0.00% 0.00%   0 SSH Event handle
469           0           1         0 0.00% 0.00% 0.00%   0 DiagCard8/-1
470       14667     169051         86 0.00% 0.00% 0.00%   0 IP Background
471       1714       14150       121 0.00% 0.00% 0.00%   0 IP Connected Rou
472     1080191   10019513       107 0.00% 0.02% 0.00%   0 DHCPD Receive
473     2511654   96618573         25 0.00% 0.05% 0.12%   0 IGMP Input
474     5425656   206263986         26 0.15% 0.23% 0.27%   0 PIM Process
475     1869316   96220812         19 0.15% 0.12% 0.10%   0 Mwheel Process
476           0           1         0 0.00% 0.00% 0.00%   0 mcast_rw_process
477     305592     9717654         31 0.00% 0.01% 0.00%   0 NTP
479       44049     109179       403 0.00% 0.00% 0.00%   0 IP SNMP
480       41311       74936       551 0.00% 0.00% 0.00%   0 PDU DISPATCHER
481     135036       75081       1798 0.00% 0.00% 0.00%   0 SNMP ENGINE
482           0          2         0 0.00% 0.00% 0.00%   0 IP SNMPV6
483           0           1         0 0.00% 0.00% 0.00%   0 SNMP ConfCopyPro
484         26           7       3714 0.00% 0.00% 0.00%   0 SNMP Traps
485       1476       82982         17 0.00% 0.00% 0.00%   0 DHCPD Timer
486       5216     160166         32 0.00% 0.00% 0.00%   0 DHCPD Database
488     690433     4182565       165 0.00% 0.00% 0.00%   0 EIGRP-IPv4
489     1066113     8307387       128 0.15% 0.02% 0.00%   0 EIGRP-IPv4 Hello
AFTER when more stable:
CPU utilization for five seconds: 36%/0%; one minute: 40%; five minutes: 40%
   1       11102     132585         83 0.00% 0.00% 0.00%   0 Chunk Manager
   2       73261     1927939         37 0.00% 0.00% 0.00%   0 Load Meter
   3       2642         471       5609 0.00% 0.00% 0.00%   1 SSH Process
   4   240755181   10265024     23453 0.00% 2.03% 2.25%   0 Check heaps
   5       3240       46607         69 0.00% 0.00% 0.00%   0 Pool Manager
   6           0           1         0 0.00% 0.00% 0.00%   0 DiscardQ Backgro
   8         664       31374         21 0.00% 0.00% 0.00%   0 WATCH_AFS
   9     599331   38557806         15 0.00% 0.00% 0.00%   0 HUSB Console
11   26820064     160201     167416 0.00% 0.28% 0.23%   0 Licensing Auto U
13   16877935   27065967       623 0.00% 0.14% 0.12%   0 ARP Input
14     598883     9955061         60 0.00% 0.00% 0.00%   0 ARP Background
20       68794     1916243         35 0.00% 0.00% 0.00%   0 IPC Event Notifi
21     106735     9332471         11 0.00% 0.00% 0.00%   0 IPC Mcast Pendin
22       5999     160209         37 0.00% 0.00% 0.00%   0 IPC Dynamic Cach
25     112380     9332500         12 0.00% 0.00% 0.00%   0 IPC Periodic Tim
26     108540     9332467         11 0.00% 0.00% 0.00%   0 IPC Deferred Por
28     993511     4948165       200 0.00% 0.00% 0.00%   0 IPC Seat Manager
29       5110     550518         9 0.00% 0.00% 0.00%   0 IPC Check Queue
32       9944     963993         10 0.00% 0.00% 0.00%   0 IPC Keep Alive M
33       53393     1922426         27 0.00% 0.00% 0.00%   0 IPC Loadometer
40     170126     9639694         17 0.00% 0.00% 0.00%   0 GraphIt
45       82571     9547807         8 0.00% 0.00% 0.00%   0 Dynamic ARP Insp
47     8753885   11440407       765 0.00% 0.09% 0.06%   0 Net Background
49       23245     427602         54 0.00% 0.00% 0.00%   0 Logger
50       91769     9548053         9 0.00% 0.00% 0.00%   0 TTY Background
54         236       10401         22 0.00% 0.00% 0.00%   0 IF-MGR event pro
56     2141667   18587944       115 0.00% 0.00% 0.00%   0 Net Input
57     2872297     1958085       1466 0.00% 0.00% 0.00%   0 Compute load avg
58     6839507     171806     39809 0.00% 0.07% 0.05%   0 Per-minute Jobs
59     6494536     9725346       667 0.00% 0.02% 0.00%   0 Per-Second Jobs
62         241       11502         20 0.00% 0.00% 0.00%   0 Transport Port A
63     1304070     2732518       477 0.00% 0.00% 0.00%   0 HC Counter Timer
67     610445     2039005       299 0.00% 0.00% 0.00%   0 EEM ED ND
69     509622   183394994         2 0.00% 0.00% 0.00%   0 DownWhenLooped
81       17000     320479         53 0.00% 0.00% 0.00%   0 PSP Timer
85   271029893   193525373       1400 2.24% 2.25% 2.33%   0 RedEarth I2C dri
86   622994511   119979004       5192 6.88% 6.81% 6.70%   0 RedEarth Tx Mana
87   16920487   90190970       187 0.15% 0.15% 0.15%   0 RedEarth Rx Mana
88       26712     1927943         13 0.00% 0.00% 0.00%   0 HULC Thermal Pro
92     4110623     1098195       3743 0.00% 0.02% 0.00%   0 Adjust Regions
93     493024     4800159       102 0.00% 0.00% 0.00%   0 hrpc -> response
94     431672   12972009         33 0.00% 0.00% 0.00%   0 hrpc -> request
95     4414522   12505748       352 0.15% 0.02% 0.00%   0 hrpc <- response
97     2231341   48196105         46 0.00% 0.01% 0.00%   0 yeti2_emac_proce
101       99971     1916211         52 0.00% 0.00% 0.00%   0 HIPC bkgrd proce
104     1044661     3739080       279 0.00% 0.01% 0.00%   0 Hulc Port-Securi
105     649303     3087785       210 0.00% 0.00% 0.00%   0 HRPC hpsecure re
112       61689     3203984         19 0.00% 0.00% 0.00%   0 HVLAN main bkgrd
117       6147     160207         38 0.00% 0.00% 0.00%   0 hulc_xps_process
118     207974     1590209       130 0.00% 0.00% 0.00%   0 HRPC ilp request
119     145439     9547678         15 0.00% 0.00% 0.00%   0 Hulc ILP Alchemy
120     791570     640798       1235 0.00% 0.00% 0.00%   0 Strider Tcam Mem
121       44939     232709       193 0.00% 0.00% 0.00%   0 HRPC hlfm reques
122     9191385   238955261         38 0.00% 0.06% 0.06%   0 HLFM address lea
123    131823     9547634         13 0.00% 0.00% 0.00%   0 HLFM aging proce
124       48723     2443579         19 0.00% 0.00% 0.00%   0 HLFM address ret
125       84463       84335       1001 0.00% 0.00% 0.00%   0 HULC PM Vector P
128   19254027   188843923       101 0.15% 0.26% 0.20%   0 hpm main process
129       3553       12879       275 0.00% 0.00% 0.00%   0 HPM Stack Sync P
130       9981       30214       330 0.00% 0.01% 0.00%   0 HRPC pm request
132   145111882     9639700     15053 1.59% 1.55% 1.48%   0 hpm counter proc
133   10257248   11966123       857 0.00% 0.06% 0.06%   0 HRPC pm-counters
136       20128       4719       4265 0.00% 0.00% 0.00%   0 HCEF ADJ Refresh
138       48427     4800164         10 0.00% 0.00% 0.00%   0 hl3mm_rp
144       53058     4800153         11 0.00% 0.00% 0.00%   0 Hulc Axiom Mgmt
146        1885       32181         58 0.00% 0.00% 0.00%   0 OBFL TEMP obfl0
149     114687    9555124         12 0.00% 0.00% 0.00%   0 Hulc CTS Process
152       2898       18755       154 0.00% 0.00% 0.00%   0 HRPC dot1x reque
154       8803       29568       297 0.00% 0.00% 0.00%   0 HULC DOT1X Proce
171     2023547   47418511         42 0.00% 0.00% 0.00%   0 Hulc Storm Contr
179       68169     9547662         7 0.00% 0.00% 0.00%   0 IEC Load balance
182 2040013082   240021082       8499 19.84% 19.85% 19.93%   0 Hulc LED Process
184     139348     6642525         20 0.00% 0.00% 0.00%   0 hl3mm
185     818164     7039309       116 0.00% 0.00% 0.00%   0 HL3U bkgrd proce
186     368965     3855757         95 0.00% 0.00% 0.00%   0 HRPC hl3u reques
187     195471     2199676         88 0.00% 0.00% 0.00%   0 HIPV6 bkgrd proc
188     376413     3855753         97 0.00% 0.00% 0.00%   0 HRPC IPv6 Unicas
189       39619     2199602         18 0.00% 0.00% 0.00%   0 HL3U PBR bkgrd p
190       1651       80323         20 0.00% 0.00% 0.00%   0 HL3U PBR n-h res
198   48188407     1916021     25150 0.47% 0.45% 0.47%   0 HQM Stack Proces
199   26982024     7653774       3525 0.31% 0.28% 0.27%   0 HRPC qos request
204       4308       53555         80 0.00% 0.00% 0.00%   0 HCMP sync proces
212         60         470       127 0.00% 0.00% 0.00%   0 AAA ACCT Proc
218   19704230   20599284       956 0.00% 0.20% 0.17%   0 CDP Protocol
220     331711     590088       562 0.00% 0.00% 0.00%   0 mdns Timer Proce
222       4078       80332         50 0.00% 0.00% 0.00%   0 DHCP Snooping
227     212418     9547649         22 0.00% 0.00% 0.00%   0 FHRP Main thread
231     4456326   142443725         31 0.00% 0.01% 0.00%   0 VRRS Main thread
233       80352       81755       982 0.00% 0.00% 0.00%   0 IP ARP Adjacency
234     5964889   238953044         24 0.00% 0.03% 0.00%   0 IP ARP Retry Age
235     8084706   19467783       415 0.15% 0.31% 0.20%   0 IP Input
237     345983  18515872         18 0.00% 0.00% 0.00%   0 IP ARP Track
238       17353     9570146         1 0.00% 0.00% 0.00%   0 fnvRootHubPortSt
240     349372   94738466         3 0.00% 0.00% 0.00%   0 MDFS MFIB Proces
248     100745     9548687         10 0.00% 0.00% 0.00%   0 mDNS
250     288447     1785196       161 0.00% 0.00% 0.00%   0 SMI CDP Update H
255   23241579   70230066       330 0.31% 0.24% 0.20%   0 Spanning Tree
256       21501     160659       133 0.00% 0.00% 0.00%   0 Spanning Tree St
258       2290       16543       138 0.00% 0.00% 0.00%   0 802.1x switch
259     211281     645950       327 0.00% 0.00% 0.00%   0 DTP Protocol
270       12187       3507       3475 0.00% 0.00% 0.00%   0 SpanTree Helper
271     1000565     9547622       104 0.00% 0.00% 0.00%   0 PI MATM Aging Pr
272     1467264   96873488         15 0.00% 0.00% 0.00%   0 UDLD
273     438631     5104137         85 0.00% 0.00% 0.00%   0 Port-Security
277       4832     160206         30 0.00% 0.00% 0.00%   0 MMN bkgrd proces
278       33389     961196         34 0.00% 0.00% 0.00%   0 Ethchnl
279       13980       3601       3882 0.00% 0.00% 0.00%   0 VMATM Callback
281       76263     348972      218 0.00% 0.00% 0.00%   0 XDR mcast
283     446295     897328       497 0.00% 0.00% 0.00%   0 XDR receive
286       5371     160206         33 0.00% 0.00% 0.00%   0 FRR Background P
287     119413     674765       176 0.00% 0.00% 0.00%   0 CEF background p
294       31709     961291         32 0.00% 0.00% 0.00%   0 IP ACL XDR LC Ba
295     180515     4791579         37 0.00% 0.00% 0.00%   0 CEF: IPv4 proces
296     2793895     9560343       292 0.00% 0.01% 0.00%   0 ADJ background
297     783633   10668133         73 0.00% 0.01% 0.00%   0 MDFS LC Process
303     491629       8026     61254 0.00% 0.00% 0.00%   0 NIST rng proc
304     357351   18515877         19 0.00% 0.00% 0.00%   0 Timer Library
308         947       11250         84 0.00% 0.00% 0.00%   0 Auth Manager
313     108910     1916572         56 0.00% 0.00% 0.00%   0 EPM ACL PLUG-IN
314     320168   19027461         16 0.00% 0.00% 0.00%   0 SVM UT Process
316         411       4452         92 0.00% 0.00% 0.00%   0 TCP Timer
318       24402     9671873         2 0.00% 0.00% 0.00%   0 Socket Timers
319         476       32162         14 0.00% 0.00% 0.00%   0 HTTP CORE
320       1346     120491         11 0.00% 0.00% 0.00%   0 Cluster L2
321       38342     961197         39 0.00% 0.00% 0.00%   0 Cluster RARP
322     153160     1524628       100 0.00% 0.00% 0.00%   0 Cluster Base
328         176       8836         19 0.00% 0.00% 0.00%   0 Flow Exporter Ti
332         888       8854       100 0.00% 0.00% 0.00%   0 MVPN Mgr Process
340     513425     963680       532 0.00% 0.00% 0.00%   0 QoS stats proces
352     4495246   19749972       227 0.00% 0.04% 0.01%   0 Inline Power
353     6285501   21100491       297 0.00% 0.05% 0.05%   0 Marvell wk-a Pow
354       65659     480612       136 0.00% 0.00% 0.00%   0 HULC stack power
355       20927     320399         65 0.00% 0.00% 0.00%   0 HRPC stack power
356       16481       15785       1044 0.00% 0.00% 0.00%   0 IGMPSN L2MCM
358     111728     677987       164 0.00% 0.00% 0.00%   0 IGMPSN
362       12961       15772       821 0.00% 0.00% 0.00%   0 MLDSN L2MCM
366     2272962   93469952         24 0.00% 0.00% 0.00%   0 MDFS RP process
370       19938       97122       205 0.00% 0.00% 0.00%   0 HRPC hl2mcm igmp
379     4320086   142443637         30 0.00% 0.02% 0.00%   0 MMA DB TIMER
382        34         759         44 0.00% 0.00% 0.00%   0 TACACS+
383       3700       4448       831 0.00% 0.00% 0.00%   0 TPLUS
384     1181848     480600       2459 0.00% 0.00% 0.00%   0 HULC ISM FNF
388         820       10716         76 0.00% 0.00% 0.00%   0 Crypto CA
390     358058     9599949         37 0.00% 0.00% 0.00%   0 Crypto IKEv2
398       25459     480601         52 0.00% 0.00% 0.00%   0 IPSEC key engine
403     4353853   142443719         30 0.15% 0.03% 0.00%   0 MMA DP TIMER
404     4494486   300035654         14 0.15% 0.02% 0.00%   0 MMON MENG
410         267       8971         29 0.00% 0.00% 0.00%   0 ASP Process Crea
419       20623     221726         93 0.00% 0.00% 0.00%   0 EEM ED Syslog
423       6040     160206         37 0.00% 0.00% 0.00%   0 vlmap logger
430     2328009   80286112         28 0.00% 0.00% 0.00%   0 PM Callback
432       8273     770624         10 0.00% 0.00% 0.00%   0 dhcp snooping sw
437       11050     160232         68 0.00% 0.00% 0.00%   0 Call Home Timer
438       81383     961542         84 0.00% 0.00% 0.00%   0 Bulkstat-Client
462       9040     210543         42 0.00% 0.00% 0.00%   0 EEM ED Timer
463       58092     215452       269 0.00% 0.01% 0.00%   0 Syslog
464       27614     640786         43 0.00% 0.00% 0.00%   0 OBFL I/O Buffer
470       14691     169128         86 0.00% 0.00% 0.00%   0 IP Background
471       1763       14208       124 0.00% 0.00% 0.00%   0 IP Connected Rou
472     1080771   10022079       107 0.00% 0.00% 0.00%   0 DHCPD Receive
473     2513137   96642695         26 0.00% 0.01% 0.00%   0 IGMP Input
474     5427933   206314831         26 0.15% 0.03% 0.00%   0 PIM Process
475     1870274   96244779         19 0.00% 0.00% 0.00%   0 Mwheel Process
477     305774     9720087         31 0.00% 0.00% 0.00%   0 NTP
479       44058     109195       403 0.00% 0.00% 0.00%   0 IP SNMP
480       41311       74944       551 0.00% 0.00% 0.00%   0 PDU DISPATCHER
481     135053       75091       1798 0.00% 0.00% 0.00%   0 SNMP ENGINE
485       1476       83002         17 0.00% 0.00% 0.00%   0 DHCPD Timer
486       5216     160205         32 0.00% 0.00% 0.00%   0 DHCPD Database
488    690602     4183604       165 0.00% 0.00% 0.00%   0 EIGRP-IPv4
489     1066579     8309503       128 0.00% 0.00% 0.00%   0 EIGRP-IPv4 Hello
Any advice is really appreciated.  Also, PoE consumption is very low on this stack
HI
 HULC is fictitious bug and has no real effect on traffic/cpu its just bug that's Unfortunatly  in lot of versions of IOS , saying that you have a high interrupt 36% which means the switch could not process and had to process in hardware , this can happen if ip cef is not enabled or if the switch has to much traffic coming through it while its trying to process it
Total CPU Utilization: 94% Process Utilization: 58% Interrupt Utilization: 36% 58% then minus 21% for HULC = 37% actual traffic being correctly processed and 36% being process switched by hardware
You need to run a full EEM script as its happening see what's collected , also check exactly on the network what's going on during these times , any type of backup , antivirus push outs etc that could spike the traffic, the EEM should capture the ints etc while the issues occurring
This is an EEM I use that may help you
event manager applet High_CPU
    event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.4.1 get-type exact entry-op ge entry-val "70" exit-time 10 poll-interval 5
    action 0.1 syslog msg "CPU Utilization is high"
    action 0.2 cli command "enable"
    action 0.4 cli command "show log | append flash:CPU_Profile.txt"
    action 0.5 cli command "show process cpu sorted | append flash:CPU_Profile.txt"
    action 0.6 cli command "show interfaces | append flash:CPU_Profile.txt"
    action 0.7 cli command " show ip cef switching stat | append flash:CPU_Profile.txt"
    action 0.8 cli command " show ip traffic | append flash:CPU_Profile.txt"
    action 0.9 cli command " show int switching | append flash:CPU_Profile.txt"
    action 1.0 cli command "end"
Haihua Rong
Hello Vijay,
Spikes are commonly seen around IOS platforms based on the inputs received by CPU and are not necessarily a problem.
It is slightly difficult to track the process which is causing spike, as it may last only for a short interval. The common cause could be, regular SNMP polling or any other kind of Process Switched traffic, regular CLI commands executed, like wr mem, sh runn or sh tech which is handled in CPU causing short spikes.
Every command executed or every external management/monitoring action to the switch will register as a short cpu spike. However the CPU is never monopolised by a single process.
Please refer to this document:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/cpu_util.html#wp998829
You can configure an EEM script if you want to know the processes that are reaching 100% of cpu utilization and to confirm that are expected.
EEM is first supported on:
6500 - 12.2(18)SXF4 ?7600 - 12.2(33)SRA?3750/3560/ME-3750/ME-3400 - 12.2(40)SE?4500 - 12.2(40)SG
config t
event manager applet cpu_stats
event snmp oid 1.3.6.1.4.1.9.9.109.1.1.1.1.3.1 get-type exact entry-op gt entry-val 100 exit-op lt exit-val 40 poll-interval 5
action 1.1 syslog msg "------HIGH CPU DETECTED----, CPU: $_snmp_oid_val %"
action 1.2 cli command "enable"
action 1.3 cli command "show proc cpu sort | append nvram:cpu_stats"
action 1.4 cli command "sho spann detail | append nvram:cpu_stats"
action 1.5 cli command "sho log | append nvram:cpu_stats"
b) to remove the script, once it is not needed anymore
conf t
no event manager applet cpu_stats
end
Explanation:
The script will monitor the CPU every 5 seconds100% in the event line is the utilization that will trigger the script.
Once is triggered the CPU has to come down to 40% and it will be triggered again.
Haihua
Hi Leo ,
We are running  version of
c3750e-universalk9-mz.122-55.SE5.bin .
Hi Haihu ,
We have identified the process spiking the CPU is " HULC' process . The output is as follws
processes cpu | exclude 0.00
CPU utilization for five seconds: 99%/5%; one minute: 32%; five minutes: 29%
   4   258638827  11402314      22683  0.45%  0.71%  1.09%   0 Check heaps
  10    13921000  17727828        785  0.15%  0.38%  0.26%   0 ARP Input
  38    21012754  20354975       1032  0.15%  0.03%  0.03%   0 Per-Second Jobs
  74    97782083 149788981        652  0.76%  0.45%  0.47%   0 RedEarth I2C dri
  75   605768871  99084729       6113  1.99%  2.40%  2.42%   0 RedEarth Tx Mana
  76     1965792  74894378         26  0.15%  0.03%  0.02%   0 RedEarth Rx Mana
  81   715470342   7252398      98655  3.83%  3.12%  3.22%   0 Adjust Regions
  84    11864720  42473212        279  0.15%  0.06%  0.05%   0 hrpc <- response
118   376140309  40324036       9327  1.53%  1.53%  1.57%   0 hpm counter proc
119    13391666  42223280        317  0.15%  0.04%  0.04%   0 HRPC pm-counters
158   603839277 465763712       1296  0.45%  0.62%  0.76%   0 Hulc LED Process
159     6742985  20431422        330  0.61%  0.16%  0.11%   0 HL3U bkgrd proce
169    78496155   4137435      18972  0.45%  0.35%  0.36%   0 HQM Stack Proces
170    31111496  17635930       1764  0.15%  0.21%  0.21%   0 HRPC qos request
200    92929040 125560792        740  2.75%  2.23%  2.02%   0 IP Input
219    85511651 248146851        344  0.76%  0.70%  0.72%   0 Spanning Tree
261    13554971  46977580        288  0.61%  0.24%  0.21%   0 DHCPD Receive
287     1036221      5476     189229 73.45%  5.88%  1.25%   0 hulc running con
323       62212      9439       6590  1.27%  1.10%  2.38%   0 Exec
342    28032934  23540805       1190  0.47%  0.11%  0.06%   0 SNMP ENGINE
Are we hitting the bug ,
CSCtn42790 .  Wther upgrading the image will solve the issue ? Kindly confirm.
BR//
Vijay
Vijay,
Try 12.2(55)SE8.
ehshum
Hi All,
I am having the same problem on two 3750 stacks. IOS versions used:
Stack1: 4x 3750X with IOS Version 12.2(55)SE8
Stack2: 4x 3750G with IOS Version Version 12.2(55)SE5
Symptom:
High CPU Spikes happening daily due to the hulc running process. This matches exactly with
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-switches/68461-high-cpu-utilization-cat3750.html#topic4
High CPU During a Configuration Change
There are no cpu spike when I run command like "show run", "show start", "write mem" but I was able to reproduce the issue by issuing the below commands:
conf t
exit
Specifically, the CPU will spike when the "exit" command is issued. The CPU will then spike up momentarily as shown in the history graph below:
sh proc cpu history
                 11111
    1113333399999000003333111111111111111111111111111111111111
    2222222299999000002222444445555555555666644444555553333355
100         **********
90         **********
80         **********
70         **********
60         **********
50         **********
40         **********
30    *******************
20    *******************     **************     *****     **
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    1 1
    0302322222222222222222222222222222224222222222222212222222
    0005046879364633702523353689946454658433741458156594795536
100 * *
90 * *
80 * *
70 * *
60 * *
50 * *                                 *
40 * *                                 *
30 #*#** **** * *  *  *   * **** * * ***   *   ** ***  **** *
20 #########*#*##*####*###########*##**##*###*#*###**####*#*#
10 ##########################################################
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
Notes:
1) I have checked the bug toolkit and there seems to be a few bugs for 3750 platform due to hulc but none is matching my environment
2) There are no spanning tree issues on the switch
3) The 72hours baseline is at 30%-40% with the high CPU spikes occuring daily.
Do the stack run a config sync periodically which might cause this? I am quite sure that during the spikes there are no users logged in the switch and doing any configuration change.
Please advise. Thanks in advance.
