high CPU Utilization in WS-C2960X-24TS-L
Ranjan Singh
Hi ,
I have WS-C2960X-24TS-L  model and i can observe CPU utilization always remain more than 22% in all X model Switches.Currently It  carries 15.2(2)E3 IOS and to also I have uploaded latest IOS on it but Utilization never comes down.
I have observed Hulc LED Proces is the bottleneck and taking high CPU process.
Please help us to reduce it.
apparently, this is normal behavior:
Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X switch
CSCtg86211
Description
Symptom:
Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X 24 or 48-port switch.
Conditions:
The CPU utilization for Hulc LED Process will be in the 6-23% range for the
Catalyst 2960 series like 2960, 2960S, 2960X switch models.
For WS-C2960X-48LPS-L which is 48ports PoE 2960X switch Hulc LED Process
Could reach about 22%-23%.
The is seen in 12.2(50)SE03 or later releases.
Workaround:
This is an expected behavior and there is no workaround.
Further Problem Description:
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD)
detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
Hi gpauwen,
What if it comes at a specific period of time and it goes directly from 30% to 90%.
Although this is a bug but there must be some workaround to resolve it.
Please find attached.
30 to 90 percent is high, too high actually to be blamed on the bug...
Try and shut down all unused ports, that should bring CPU utilization down at least some.
