High CPU utilzation on 3750switch
ikbalc
We are facing high CPU utilization on 3750 due to the process hl3mm.Please find the output of show process cpu sorted,show process cpu and show version attached here.
Please help
Ikbal
Mahesh Gohil
Level 7
Level 7
Hi Ikbal,
Please confirm do you see any log message while your cpu is high ? If no message best way it to log case with cisco as i do not find any bug
related to hl3mm process.
In addition please check duplex mode on switch for all the ports. This cause high cpu because multiple users passing traffic to a port
with half duplex operation
you can share switch config which might be helpful to know the exact reason
Mahesh
To resolve this situation (not to receive any extra traffic from users), you can create ACL and apply it to all VLAN, which should work IPTV.  Let the multicast channels are located in range 225.1.1.1 to 225.1.1.255, and nothing but them we do not need.
ip access-list extended PreventMulticastDoS
permit ip any 225.1.1.0 0.0.0.255
deny ip any 224.0.0.0 15.255.255.255
permit ip any any
int vlan 101
ip access-group PreventMulticastDoS in
'igmp filter' for this case does not work -- mroute table still overflow. The same applies to the 'ip igmp access-group'
