01-28-2013 12:21 AM - edited 03-07-2019 11:20 AM
My network Infrastructure consists of 2 core switches(cisco 3950, 24 port) and 3 access switches (cisco 2960G, 48port). No distribution layer.Both Core switches are connected to the BVI of a VPN router.PVST is running in all switches. The STP results are all good. We have 3 VLAN's in the LAN an IP routing is enables in the core switch. The network diagram is attached.
The issue we are facing is that , we get intermittent packet drops while pinging towords the access switches, and there is always a higher latency towords these assess switches.These issues are present even with no other users using the LAN. But these issues are not present while pinging towards the GW.
I guess, it is because of this, we have issues the accessing file server in the LAN. How do we go ahead with the troubleshooting. Will upgrading the IOS help resolve this.The present version details is..
WS-C2960G-48TC-L 12.2(44)SE6 C2960-LANBASEK9-M
Thanks in advance for the help.
01-28-2013 12:31 AM
Can u check on the uplink ports for any errors like CRC,FCS etc.
01-28-2013 05:25 AM
in the trunk linkm, for a million packet input 6 crc errors ....440 output drops are shown...but these are full duplex 1000 mbps links....
03-31-2014 02:28 AM
Do you still have this problem of is it solved?
i have the same kind of issue, so any help or information is welcome!
Tom
