High latency issue in LAN - between two switches.
bimalnp4me
HI
PC -> core SW(6500) -> fiberswitch -> fiberSW - > core SW(4500) -> ------- ping time < 1ms
Reply from 10.10.3.7: bytes=32 time<1ms TTL=254
Reply from 10.10.3.7: bytes=32 time=1ms TTL=254
Ping statistics for 10.10.3.7:
    Packets: Sent = 927, Received = 927, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 196ms, Average = 0ms
PC -> core SW(6500) -> fiberswitch -> fiberSW - > core SW(4500) -> Desk Switch (2960) ---- ping time is very inconsistent
Reply from 10.10.3.93: bytes=32 time=4ms TTL=254
Reply from 10.10.3.93: bytes=32 time=5ms TTL=254
Reply from 10.10.3.93: bytes=32 time=17ms TTL=254 -----------------------
Reply from 10.10.3.93: bytes=32 time=72ms TTL=254 --------------------------
Reply from 10.10.3.93: bytes=32 time=6ms TTL=254
Reply from 10.10.3.93: bytes=32 time=7ms TTL=254
Reply from 10.10.3.93: bytes=32 time=11ms TTL=254 -----------------------
Ping statistics for 10.10.3.93:
    Packets: Sent = 2076, Received = 2062, Lost = 14 (0% loss),
    Minimum = 3ms, Maximum = 160ms, Average = 7ms
can enyone help me to troubleshoot this issue.. some times it even conectivity get lost..
18 Replies 18
Leo Laohoo
What troubleshooting have YOU done?
1.  Did you check for interface line errors?
2.  When does the high latency occurs?
Well we know that the problem is probably anwhere between here:
Since everything before that is less than or equal 1ms which is acceptable LAN performance right?
Can we do a 'show interface' on the 4500 and the 2960 for the interfaces which connect them together please?
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
no line errors..
I'm new to this env.. issue was initialy there..
no line errors..
lauxtobias1
Hi Bimal,
could you also provide the output of following commands:
  • show processes cpu history
  • show version
Maybe this is due to a IOS bug which is causing high CPU utilization.
Bimal,
1. Can you check duplix mismatch errors on both switches.
2. check recent logs for any errors.
Sri
WareHouse_1#show processes memory
Processor Pool Total:   34988900 Used:    9477732 Free:   25511168
      I/O Pool Total:    4186112 Used:    1646136 Free:    2539976
Driver te Pool Total:    1048576 Used:         40 Free:    1048536
WareHouse_1#show processes cpu
CPU utilization for five seconds: 6%/0%; one minute: 6%; five minutes: 6%
bimalnp4me
WareHouse_1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  10.10.3.93      YES NVRAM  up                    up
FastEthernet0/1        unassigned      YES unset  up                    up
FastEthernet0/2        unassigned      YES unset  down                  down
FastEthernet0/3        unassigned      YES unset  up                    up
FastEthernet0/4        unassigned      YES unset  up                    up
FastEthernet0/5        unassigned      YES unset  up                    up
FastEthernet0/6        unassigned      YES unset  up                    up
FastEthernet0/7        unassigned      YES unset  up                    up
FastEthernet0/8        unassigned      YES unset  up                    up
GigabitEthernet0/1     unassigned      YES unset  up                    up
WTM-WareHouse_1#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
XWCORE2.X.com
                 Gig 0/1           174           S I      WS-C4507R Gig 3/48
SEP0013C4C63D00  Fas 0/8           133           H P      IP Phone  Port 1
SEP0021A02D56AC  Fas 0/1           132           H P      IP Phone  Port 1
WareHouse_1#          show  version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 18:10 by gereddy
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
WareHouse_1 uptime is 17 weeks, 14 hours, 3 minutes
System image file is "flash:c2960-lanbasek9-mz.122-44.SE6/c2960-lanbasek9-mz.122-44.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-8TC-L (PowerPC405) processor (revision C0) with 61440K/4088K bytes of memory.
Processor board ID XXXXXXXXXXXXX
Last reset from power-on
1 Virtual Ethernet interface
8 FastEthernet interfaces
1 Gigabit Ethernet interface
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : XXXXXXXXXXXXXXXX
Motherboard assembly number     : 73-10611-07
Power supply part number        : 341-0208-01
Motherboard serial number       : FOC140359C9
Power supply serial number      : LIT13510LWX
Model revision number           : C0
Motherboard revision number     : D0
Model number                    : WS-C2960-8TC-L
System serial number            : FOC1404V0WF
Top Assembly Part Number        : 800-28132-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COM8A00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 9     WS-C2960-8TC-L     12.2(44)SE6           C2960-LANBASEK9-M
Configuration register is 0xF
Reply from 10.10.3.93: bytes=32 time=129ms TTL=254
Reply from 10.10.3.93: bytes=32 time=28ms TTL=254
Reply from 10.10.3.93: bytes=32 time=26ms TTL=254
Reply from 10.10.3.93: bytes=32 time=164ms TTL=254
Reply from 10.10.3.93: bytes=32 time=106ms TTL=254
Reply from 10.10.3.93: bytes=32 time=110ms TTL=254
Reply from 10.10.3.93: bytes=32 time=141ms TTL=254
Reply from 10.10.3.93: bytes=32 time=97ms TTL=254
Request timed out.
Reply from 10.10.3.93: bytes=32 time=159ms TTL=254
Reply from 10.10.3.93: bytes=32 time=116ms TTL=254
Reply from 10.10.3.93: bytes=32 time=130ms TTL=254
Request timed out.
Reply from 10.10.3.93: bytes=32 time=8ms TTL=254
Reply from 10.10.3.93: bytes=32 time=45ms TTL=254
Reply from 10.10.3.93: bytes=32 time=140ms TTL=254
Reply from 10.10.3.93: bytes=32 time=81ms TTL=254
Reply from 10.10.3.93: bytes=32 time=105ms TTL=254
Reply from 10.10.3.93: bytes=32 time=182ms TTL=254
On the 2960 can you please do 'show interface Gig 0/1'
On the 4507R can you also show us 'show int Gig 3/48'
Thank you
SWCORE2#show interfaces GigabitEthernet 3/48
GigabitEthernet3/48 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is 0013.7f64.fd9f (bia 0013.7f64.fd9f)
  Description: ###WareHOUSE##
  MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
     reliability 255/255, txload 35/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is off, output flow-control is off
  Last input 00:00:09, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 17120466
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 51000 bits/sec, 26 packets/sec
  5 minute output rate 14013000 bits/sec, 1913 packets/sec
     603576762 packets input, 222995427904 bytes, 0 no buffer
     Received 215844037 broadcasts (101082233 multicast)
     7958878068 packets output, 3814037747442 bytes, 0 underruns
     0 lost carrier, 0 no carrier
WareHouse_1#show interfaces Gig 0/1
GigabitEthernet0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is ec44.76ff.db89 (bia ec44.76ff.db89)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
     reliability 255/255, txload 1/255, rxload 20/255
  Keepalive not set
  Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  5 minute input rate 8026000 bits/sec, 1112 packets/sec
  5 minute output rate 40000 bits/sec, 17 packets/sec
     3447611911 packets input, 1613371505792 bytes, 0 no buffer
     Received 931660812 broadcasts (462987703 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 462987703 multicast, 0 pause input
     153756051 packets output, 58314509602 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Are the ping times from the PC to the management IP Address of the the switches involved?
Can you post the "sh interface " and "sh controller e "?
WareHouse_1#show controllers  ethernet-controller  Gig 0/1
     Transmit GigabitEthernet0/1              Receive
   2481345501 Bytes                       2925250836 Bytes
    145930333 Unicast frames              2516123349 Unicast frames
      6779361 Multicast frames             462998037 Multicast frames
      1052141 Broadcast frames             468687974 Broadcast frames
            0 Too old frames              2466301232 Unicast bytes
            0 Deferred frames             1623208448 Multicast bytes
            0 MTU exceeded frames         2381842690 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   1 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames              171465 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames            25375590 Minimum size frames
            0 8 collision frames          1656591706 65 to 127 byte frames
            0 9 collision frames           513507334 128 to 255 byte frames
            0 10 collision frames          280950707 256 to 511 byte frames
            0 11 collision frames          206106014 512 to 1023 byte frames
            0 12 collision frames          189194709 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames          576254766 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      1059255 64 byte frames                       0 Valid frames, too small
    104685963 127 byte frames
      6885273 255 byte frames                      0 Too old frames
      7803365 511 byte frames                      0 Valid oversize frames
      2278629 1023 byte frames                     0 System FCS error frames
     21695573 1518 byte frames                     0 RxPortFifoFull drop frame
      9353777 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Undersized frames?????  That's not good.
Can you elaborate what is connected to this port?
