high memory I/O utilization on 2960S switch
hello,
i always observe more than 80% I/O memory utilization in my switches as shown below
Processor Pool Total: 60627512 Used: 44893596 Free: 15733916
I/O Pool Total: 14680064 Used: 12439436 Free: 2240628
Driver te Pool Total: 1048576 Used: 40 Free: 1048536
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 77442260 25888064 48132920 0 0 *Init*
0 0 13644 261332 13644 0 0 *Sched*
0 0 14873592 13466852 1235120 12336767 8504 *Dead*
0 0 0 0 0 0 0 *MallocLite*
1 0 234180 51296 190076 0 0 Chunk Manager
2 0 232 232 4192 0 0 Load Meter
3 1 2125460 2031048 104392 0 0 SSH Process
4 0 4744 232 11756 0 0 Check heaps
5 0 3513744 3513744 74764 3415932 3415932 Pool Manager
6 0 0 0 7192 0 0 DiscardQ Backgro
7 0 232 232 7192 0 0 Timers
8 0 0 0 4192 0 0 WATCH_AFS
9 0 0 0 7192 0 0 License Client N
10 0 138494508 138494508 7208 0 0 Licensing Auto U
11 0 0 0 7192 0 0 Image License br
12 0 37072 288 43976 0 0 ARP Input
13 0 5688 6168 7192 0 0 ARP Background
14 0 0 0 7192 0 0 AAA_SERVER_DEADT
noting that the IOS version is 15.2(1)E2
please if anyone can advise how to solve this problem or it's normal in this model or I need to change the IOS version and if it is, there is any document proof that ?
it's not effecting the function of the switch and the CPU is normal
Leo Laohoo
Upgrade the firmware.
thank u i'll try and see the results
Unfortunately, upgrading the software does not solve the problem. I think the switch just has hardware limitations and might be advice-able to upgrade to  a higher end switch.
The Ops' switch is running on a short-lived 15.2(1)E train -- not a particular train/version I want to "brag" about.
