higher than normal cpu for fed (PunjectRx) process
CrackedJack1
Level 3
Level 3
I noticed on my 3850 that the CPU seems to have gone up overnight a fed days ago and has stayed there. Everything seems to be fine at the moment but I was just wondering what the process is that's causing it (google gives me nothing) and if I should be worried.
Running show processes cpu sorted gives me this:
Core 0: CPU utilization for five seconds: 15%; one minute: 18%;  five minutes: 25%
Core 1: CPU utilization for five seconds: 97%; one minute: 45%;  five minutes: 34%
Core 2: CPU utilization for five seconds: 15%; one minute: 51%;  five minutes: 39%
Core 3: CPU utilization for five seconds: 10%; one minute: 20%;  five minutes: 42%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
5711   183846      14637156 217    27.84    27.34    27.31    1088  fed
10184  481691      20810070 573    5.20     5.37     6.54     34816 iosd
I asked for detailed info on the fed process and got the output below. As you'll notice, the high cpu value on the core doesn't always show up on the same core. What is that PunjectRx process that's responsible for the higher than normal value do?
Core 0: CPU utilization for five seconds: 20%; one minute: 27%; five minutes: 30%
Core 1: CPU utilization for five seconds: 18%; one minute: 24%; five minutes: 28%
Core 2: CPU utilization for five seconds: 8%; one minute: 25%; five minutes: 34%
Core 3: CPU utilization for five seconds: 92%; one minute: 70%; five minutes: 52%
PID     T C  TID     Runtime(ms) Invoked   uSecs  5Sec   1Min 5Min TTY   Process
5711    L            18656       146354252 217    26.9   27.2 27.3 1088  fed
5711    L 3  5711    29060       7853      0      0.00   0.00 0.00 1088  fed
5711    L 0  6144    2809206     23626670  0      0.00   0.01 0.02 1088  fed
5711    L 1  6145    5570        313407    0      0.00   0.00 0.00 1088  fed
5711    L 0  6146    296459      269367770 0      0.00   0.05 0.05 1088  CMI default xdm
5711    L 0  6147    3270        209596    0      0.00   0.00 0.00 1088  fed
5711    L 1  6150    2014171     254472866 0      0.34   0.30 0.29 0     fed-ots-main
5711    L 2  6151    600         13111     0      0.00   0.00 0.00 0     fed-ots-mo
5711    L 2  6153    3715892     3065842   0      0.48   0.48 0.48 0     fed-ots-nfl
5711    L 0  6154    326140      18702233  0      0.00   0.00 0.00 0     fed
5711    L 0  6155    137920      3126591   0      0.00   0.00 0.00 0     pdslib thread
5711    L 0  6156    1820820     117290277 0      0.00   0.02 0.02 0     Timer
5711    L 2  6157    0           2805      0      0.00   0.00 0.00 0     fed
5711    L 0  6176    290660      152790809 0      0.72   0.77 0.73 0     IntrDrv
5711    L 0  6179    486230      31194756  0      0.00   0.02 0.01 0     LED
5711    L 0  10160   60          9427      0      0.00   0.00 0.00 0     Xcvr
5711    L 0  10162   233781      204227456 0      0.24   0.24 0.24 0     Xcvr
5711    L 2  10686   50780       1309757   0      0.00   0.00 0.00 0     PdsEvent
5711    L 3  10687   2302060     113878739 0      24.0   24.0 24.0 0     PunjectRx
5711    L 2  10688   2689529     198752351 0      1.15   1.34 1.39 0     PunjectTx
5711    L 3  10689   0           7522      0      0.00   0.00 0.00 0     Consistency
5711    L 2  10690   0           7522      0      0.00   0.00 0.00 0     ShFwd
5711    L 0  10692   0           7544      0      0.00   0.00 0.00 0     eicore_bdn
5711    L 0  10693   0           7544      0      0.00   0.00 0.00 0     eicore_bdn
5711    L 0  10694   0           7544      0      0.00   0.00 0.00 0     eicore_bdn
5711    L 0  10696   50          7599      0      0.00   0.00 0.00 0     eicore_ipc
5711    L 3  10717   0           7752      0      0.00   0.00 0.00 0     fed
5711    L 0  10952   0           7849      0      0.00   0.00 0.00 0     fed
5711    L 0  11072   4281230     128013576 0      0.00   0.01 0.02 0     XcvrPoll
9 Replies 9
Gavin Barber
Level 2
Level 2
Seeing similar here on 3850 stack. Running 03.03.01SE IOS-XE.
Core 0: CPU utilization for five seconds: 45%; one minute: 40%; five minutes: 39%
Core 1: CPU utilization for five seconds: 57%; one minute: 46%; five minutes: 45%
Core 2: CPU utilization for five seconds: 58%; one minute: 57%; five minutes: 54%
Core 3: CPU utilization for five seconds: 39%; one minute: 56%; five minutes: 56%
5679    L            2207615     162418091 66     23.7   23.1 22.7 1088  fed
5679    L 2  5679    29940       7879      0      0.00   0.00 0.00 1088  fed
5679    L 0  6112    321780      319764    0      0.00   0.03 0.04 1088  fed
5679    L 2  6113    520         24080     0      0.00   0.00 0.00 1088  fed
5679    L 2  6114    8770        5395188   0      0.00   0.03 0.04 0     CMI default xdm
5679    L 1  6115    320         16534     0      0.00   0.00 0.00 0     fed
5679    L 2  6118    1130370     5020432   0      0.62   0.74 0.74 0     fed-ots-main
5679    L 1  6119    20          1303      0      0.00   0.00 0.00 0     fed-ots-mo
5679    L 2  6121    3855140     224587    0      0.52   0.49 0.48 0     fed-ots-nfl
5679    L 1  6122    23500       1399239   0      0.00   0.04 0.01 0     fed
5679    L 2  6123    11430       231772    0      0.00   0.01 0.03 0     pdslib thread
5679    L 1  6124    189270      9882134   0      0.05   0.04 0.04 0     Timer
5679    L 1  6125    0           2808      0      0.00   0.00 0.00 0     fed
5679    L 1  6144    793970      8150598   0      0.29   0.21 0.20 0     IntrDrv
5679    L 1  6147    33730       2295636   0      0.00   0.01 0.00 0     LED
5679    L 0  10452   40          9474      0      0.00   0.00 0.00 0     Xcvr
5679    L 1  10456   1922330     107887089 0      0.33   0.22 0.20 0     Xcvr
5679    L 3  12275   110         10697     0      0.00   0.00 0.00 0     PdsEvent
5679    L 2  12276   980070      7963687   0      0.71   0.49 0.48 0     PunjectRx
5679    L 0  12277   1263190     4878455   0      21.1   20.8 20.5 0     PunjectTx
5679    L 0  12278   0           7567      0      0.00   0.00 0.00 0     Consistency
5679    L 0  12279   0           7567      0      0.00   0.00 0.00 0     ShFwd
5679    L 1  12283   0           7580      0      0.00   0.00 0.00 0     eicore_bdn
5679    L 1  12284   0           7580      0      0.00   0.00 0.00 0     eicore_bdn
5679    L 1  12285   0           7579      0      0.00   0.00 0.00 0     eicore_bdn
5679    L 3  12289   10          7608      0      0.00   0.00 0.00 0     eicore_ipc
5679    L 0  12298   0           7788      0      0.00   0.00 0.00 0     fed
5679    L 2  12610   0           7875      0      0.00   0.00 0.00 0     fed
5679    L 2  12801   233040      8635591   0      0.05   0.02 0.03 0     XcvrPoll
I'm running 3.3.1 as well. I see your high usage is on transmit, not receive. Do you know if it was a sudden jump or more gradual or always like that?
Mine was sudden and in the middle of the night when nobody was working and I've not noticed any other issues which makes me think something in the switch has gone wrong.
I've opened a tac case but i'm not holding my breath. My environment has a lot of arp and broadcast traffic which, based on past experience, tends to be a red herring when it comes to troubleshooting and lots of time spent looking at false leads. I'm thinking reboot the stack but I would prefer to avoid that unless absolutely required.
If there's any info you can think of which might help me figrue this out i would appreciate it.
Don't know if this is related but I've noticed my time is off by almost a minute on the switch. I've seen a note in my log saying time is running backwards on the 2nd switch in the stack and even though it says my NTP source is syncrhonized, it's about 50 seconds aheads of the real time.
An older cisco switch trunked off the 3850 which is getting NTP time from the same source as the 3850 is ok though. Just the 3850 is wrong but I don't know when that problem started (or how to fix it)
CrackedJack1
Level 3
Level 3
Bringing back my old thread here.... I'm still having the problem but now the process which is using 20%+ under fed is PdsEvent.
At one point both PunjectRx and PdsEvent were high, now PunjectRx is down to normal and PdsEvent is up there.
Anyone know what PdsEvent is?
I'm running 3.3.3 at the moment.
Tzy Chun Chong
Level 3
Level 3
I got the same issue, i found this article is useful to find out the culprit switchport, but am not trying yet. use sharing purpose for you to try out. Let me know your outcome if possible.Thanks.
Was there supposed to be a link in your post? Doesn't look like it came through.
At the moment my CPU is ok (around 35%) and both the PdsEvent and PunjectRx are good. I've looked at the CPU troubleshooting article but it didn't help me much.
Opps.. My bad, yes I found this link.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117594-technote-hicpu3850-00.html
My device that happened already power cycled (due to traffic intermittent) and problem resolved, but I managed to show-tech during the problem. From show-tech I found the iosd and fed CPU utilization are higher than normal. In my current status each iosd and fed only average in 3% CPU consumption but from the show-tech it surged to iosd 25% and fed 17% and the total CPU goes up to >60% and caused traffic intermittent. If the same problem happen again i gonna try this step to find out the culprit switchport.
Cheers
John Comfort
Frequent Visitor
Frequent Visitor
I experienced a similar problem where FED CPU was at 50+%, PDSD was around 30%.  Switch uptime was 1yr, 14wks.  Power cycling each switch individually (to eliminate downtime) corrected the problem.  I started with the master switch 1, then switch 2 to reduce number of switchovers.  Be sure to WAIT for all processes to sync.  That is, stack members (show switch) will show Active/Member prior to HA sync.  We want the stack members to show Active/Standby.  After the HA sync process completes, the next switch is ready to be power cycled.
CPU is holding at <10% which is normal.
Kushal Singh Bisht
Community Member
Want to know the reason for High utilization due to Fed(PunjectRx) .
what is PunjectRx actually  ?
