Higher TTL Reponse & Ping Breaks
We have Four 2960S Switches in Stack.  We have created Multiple VLANs.   While Pinging from Member PC to Member VLAN IP on Switch, we are getting Higher TTL response & Some ping breaks for One Particular VLAN...
While pinging from Member PC to Member PC, we are getting Normal Ping Response.
Is there any Problem in  Switch??
Sandeep
5 Replies 5
nkarpysh
No problem - ping between 2 PCs is going in HW on a switch. Ping from or to VLAN on switch requires it to be handled by CPU on a switch. CPU treats ICMP as low priority process thus you can see daly with these types of pungs. That is normal.
Nik
HTH,
Niko
Hello Nikolay,
Thanks for the response.   But, We are getting thses delays all time for One particular VLAN. lets say VLAN 4.
We are not getting this for any other VLAN ID.
That would mean that this VLAN getting some other traffic which needs to be handled by CPU causing ICMP traffic to wait for it's trun longer than for other VLANs.
you can check the utilization of SVIs
Nik
HTH,
Niko
HI,
If SVI CPU Utilization is higher, what we can do?
Sandeep
You will either need to do nothing if the load of VLAN is expected - ot analyze what traffic is hitting the VLAN.
Nik
HTH,
Niko
