WS-X45-SUP6-E - 10GB SFP+ not detecting on twingig converter module
shamg1974
I have a 4506-E with the following supervisor module:
WS-X45-SUP6-E
It currently has 2 TwinGig converter modules installed. I want to upgrade the 2 1Gb connections to 2 10Gb connections. First I took out the converter modules and installed 2 X2-10Gb-SR's, but it didnt recognize ("No X2 GBIC")???
Then, I put the converter module back in and put two SFP-10GB-SR's in them, but they don't recognize either...???? I"m running IOS
12.2(54)SG1.
According to the 10Gb matrix, they should work:
Catalyst 4500 series
(continued)
WS-X45-SUP6-E
WS-X4606-X2-E
X2-10GB-CX4
X2-10GB-LX4
X2-10GB-LR
X2-10GB-SR
X2-10GB-ER
X2-10GB-LRM
X2-10GB-ZR
DWDM X2
12.2(54)SG
12.2(54)SG
12.2(50)SG
12.2(40)SG
12.2(40)SG
12.2(50)SG
12.2(50)SG
WS-X45-SUP6-E
WS-X4606-X2-E
(With CVR-X2-SFP10G converter for X2 ports)
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-H10GB-CU1M1
SFP-H10GB-CU3M1
SFP-H10GB-CU5M1
12.2(54)SG
12.2(54)SG
12.2(50)SG
12.2(54)SG
12.2(53)SG1
Can anybody help?
Thank you,
Bobby Grewal
Leo Laohoo
That will DEFINITELY won't work at all.  CVR TwinGig converter "converts" TEN Gig ports to two 1 Gbps.
amikat
It is likely the Sup6-E ports were configured for 1 Gb mode when using TwinGigs. You can check the configuration via the "show hw-module module m port-group" command, where m is your Sup6-E position number. You can further change the configuration via the "hw-module module m port-group p select tengigabitethernet" command.
Best regards,
Antonin
