Hold-queue on ASR 1002x
Sergey Rozanov
Hello!
I have a problem with hold queue on ASR 1002x Gigabit interface. Hold-queue counter reaches max value and interface drops all inbound traffic. Hold-queue value isn't decreased  until reboot the router or change max size of hold-queue on interface. Is it bug or wrong configuration?
GigabitEthernet2 is up, line protocol is up
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 13/255
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is T
output flow-control is on, input flow-control is on
Last input 00:00:00, output 00:00:01, output hang never
Input queue: 8373/8500/5025763/68 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 51031000 bits/sec, 9418 packets/sec
5 minute output rate 7029000 bits/sec, 5468 packets/sec
14711966808 packets input, 7361786748794 bytes, 0 no buffer
Received 228129169 broadcasts (0 IP multicasts)
0 watchdog, 296496994 multicast, 0 pause input
12568622289 packets output, 2984983109390 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Thanks!
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I would suspect a bug; sounds like a variation of a Wedged Interface bug.
Joseph W. Doherty
Disclaimer
Posting
