Host behind vPC not responding
Kemal Zuko
 Hello Again,
On our new test network that consists of two Nexus 6004's and two Nexus 9372's that run vPC between the two. The network VLANs live on the Nexus 6004's and extend down to 9K's via vPC links
On one of our 9K's we have a host in
switchport access vlan 680
Simple right? :) well there is nothing simple about this network. From the nexus 6004 we can ping the host that sits behind vlan 680 but when we try to ping from the Nexus 9372 (leaf switch) that is directly connected to the host we get the following:
NExus9K# ping 172.16.8.199
PING 172.16.8.199 (172.16.8.199): 56 data bytes
ping: sendto 172.16.8.199 64 chars, No route to host
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 172.16.8.199 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
This switch is strictly L2
here is some config for reference
Nexus 6004 Primary
vlan 450
  name P2P_VRF_SVI_DMZ
vlan 451
  name P2P_VRF_SVI_Inside
vlan 600
  name DMZ
vlan 652
  name Management
vlan 680
  name Inside
vrf context DMZ
vrf context Inside
vrf context management
  ip route 0.0.0.0/0 172.16.52.1
vrf context peer-keepalive
vpc domain 99
  role priority 1
  peer-keepalive destination 10.200.50.2 source 10.200.50.1 vrf peer-keepalive
  delay restore 120
interface Vlan1
interface Vlan450
  description DMZ P2P to ASA
  no shutdown
  vrf member DMZ
  ip address 172.16.230.1/29
  ip router eigrp 100
  no ip passive-interface eigrp 100
interface Vlan451
  description Inside p2p to ASA
  no shutdown
  vrf member Inside
  ip address 172.16.230.9/29
  ip router eigrp 100
interface Vlan600
  description DMZ
  no shutdown
  vrf member DMZ
  ip address 172.16.0.2/22
  ip router eigrp 100
  hsrp 2
    authentication text test1
    preempt
    priority 250
    ip 172.16.0.1
interface Vlan651
interface Vlan680
  description Inside Network
  no shutdown
  vrf member Inside
  ip address 172.16.8.2/22
  ip router eigrp 100
  hsrp 1
    preempt
    priority 250
    ip 172.16.8.1
interface port-channel99
  description vPC Etherchannel
  switchport mode trunk
  switchport trunk allowed vlan 600,680
  spanning-tree port type network
  vpc peer-link
interface port-channel102
  description vPC to Nexus 9372
  vpc 102
interface Ethernet1/1
  description vPC Peer Link 1.1
  speed auto
  channel-group 99 mode active
interface Ethernet1/7
  description vPC Peer Link 1.7 to Nexus 9372 PRI
  speed auto
  channel-group 102 mode active
interface Ethernet2/1
  description vPC Peer Link 2.1
  speed auto
interface Ethernet2/7
  description vPC Peer Link 2.1 to Nexus SEC
  speed auto
interface Ethernet8/1
  description keep-alive peer-link to ALNSWI02
  no switchport
  vrf member peer-keepalive
  ip address 10.200.50.1/30
interface Ethernet8/2
  description Uplink to ASA
  switchport trunk allowed vlan 450-451
interface Ethernet8/9
  description EIGRP PORT
interface mgmt0
  vrf member management
  ip address 172.16.52.3/23
line console
line vty
boot kickstart bootflash:/n6000-uk9-kickstart.7.0.1.N1.1.bin
boot system bootflash:/n6000-uk9.7.0.1.N1.1.bin
router eigrp 100
  autonomous-system 100
  vrf DMZ
    router-id 172.16.0.1
    default-information originate
  vrf Inside
    router-id 172.16.230.9
poap transit
Primary Leaf Nexus 9372
vlan 1,600,652,680
vlan 600
  name DMZ
vlan 652
  name Managment
vlan 680
  name Inside
vpc domain 101
  role priority 1
  peer-keepalive destination 10.200.50.6 source 10.200.50.5 vrf peer-keepalive
interface Vlan1
interface Vlan652
  no shutdown
interface port-channel101
  vpc peer-link
  vpc 102
sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 99
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 1
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po99   up     600,680
vPC status
id     Port        Status Consistency Reason                     Active vlans
102    Po102       up     success     success                    600,680
interface Ethernet1/16
  description HOST        <<<<<<<<<<<<<<<<<<<<<<<<<<<< This is the host that we cant reach<<<<<<
interface Ethernet1/17
  description SERVER1
interface Ethernet1/46
  description keep-alive peer-link to ALNSWI04
  no switchport
  ip address 10.200.50.5/30
  no shutdown
interface Ethernet1/47
  description vPC Peer Link 1.47
  channel-group 101 mode active
interface Ethernet1/48
  description vPC Peer Link 2.48
interface Ethernet1/49
  description vPC Link 1.49 to Nexus 6004 PRI
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
  description vPC Link 1.53 to Nexus 6004 SEC
interface Ethernet1/54
interface mgmt0
  ip address 172.16.52.5/23
line console
line vty
boot nxos bootflash:/n9000-dk9.6.1.2.I3.1.bin
sh vpc
Legend:
vPC domain id                     : 101
vPC role                          : primary
1    Po101  up     600,680
vPC status
So I confused on the ping status from the Leaf switch when it says "no route to host"
Any help is appreciated
Thank you
31 Replies 31
I said yesterday that its something on the ASA. hehe.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Yes you did :-)
Jon
Yea, the Nexus stuff is definetley a different beast ...
Kemal
Actually if that is the issue you can't allow it on the trunk link because it would be a vPC vlan.
I don't think you can extend that vPC vlan back to the ASA unless you connect the ASA using a vPC in which case you would need to not run EIGRP and use HSRP with static routes.
Or you could create another matching pair as you did with vlans 450 and 451 and vlans 600 and 680.
You would then create SVIs for vlan 652 on the Nexus switches and use a new non vPC vlan in the same VRF to extend it back to the ASA.
Jon
Bilal Nawaz
Hello Kemal,
your output indicates that you have no route to the host from the N9K. You should have route via N6K because its directly connected. Can you ping from the gateway i.e. Nexus 6K?
If so then its working as expected, if you want the N9K to be able to ping, it needs a route - it needs to know how to get to the host in vlan 680. You can see if the N9K has a route by doing "show ip route 172.16.8.199"
Your vpc config seems ok from what i've seen.
Bilal
Hello Bilal,
Yes I can ping the host from the Nexus 6004, and I can also ping the host from my ASA which hangs off the 6004. That tells me that the packet flow works, however I am a little confused with the Nexus lineup on why everything needs a route, even though the vlan 680 is extended from the Nexus 6004 (Gateway) to the Nexus 9372.
There is no route in the N9372 other then the management.
Kemal, lets put ourselves in the shoe's of the Nexus 9372. If we want to get to 172.16.8.199, we always do a lookup of some sort - route lookup. Do I know how to get to x.x.x.x? In this case from a layer 3 point of view, answer is no, the N9K does not know how to get there, because there is no route.
From a layer 2 perspective, yes by all means it is carrying that VLAN, you'll be able to see layer 2 information like mac address's for hosts on that vlan, it is providing a means for transit traffic on that segment. But for this scenario we do not have a layer 3 interface with an IP in the 680 vlan. Quite opposite on the N6K, we do have an interface in vlan 680, everything to your ASA is routed, they have routes to the destination network. The ping works.
To get the ping to work on N9K, you would have to put in a route (static) or make the N9K part of your dynamic routing protocol (if you are using one) to learn about the route to the vlan 680.
Hope this helps
Bilal
Makes sense of course. I see how the Nexus switches are different from the old IOS switch.
If I create a static route of some sort am I taking the Switch out of L2 mode?
And would I just create a static route pointing to the core gateway?
ip route 172.16.8.0 255.255.252.0 172.16.8.1 <<<< this one being the gateway?
Kemal
Do you have an SVI on the 9372 for management.
If you do then the gateway is the IP of the SVI on the Nexus switches for that vlan.
On IOS for a L2 switch you used to configure a default gateway but I believe with NXOS even for a L2 switch you configure a route.
Jon
Hi Jon,
No I don't have an SVI for MGMT. I am using the MGMT interface for management.
interface mgmt0
Sorry Kemal, can you try one thing for me please?
On your nexus 9K do this:
ping 172.16.8.199 vrf management
Tell me if it works.
hi Bilal,
No I cant. Here is the output
interface mgmt0
NK9 # ping 172.16.8.199 vrf management
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
Kemal, does the host 172.16.52.1 have a route to 172.16.8.199. What is 172.16.52.1?
May I also ask if it is a real requirement for an "access switch" to reach this server on vlan 680 :)
172.16.52.1 is our ASA. It handles all the MGMT stuff.
We would like to have that feature in case of troubleshooting...
So I think your policy on the ASA is blocking the ping? Take a look at the logs on the ASA and ping the same time, you should see the traffic if a deny rule is set for logging.
i would say that your troubleshooting is better off on the N6K because there's less hops to go through.
