03-11-2015 08:12 PM - edited 03-07-2019 11:03 PM
Hello Again,
On our new test network that consists of two Nexus 6004's and two Nexus 9372's that run vPC between the two. The network VLANs live on the Nexus 6004's and extend down to 9K's via vPC links
On one of our 9K's we have a host in
switchport access vlan 680
Simple right? :) well there is nothing simple about this network. From the nexus 6004 we can ping the host that sits behind vlan 680 but when we try to ping from the Nexus 9372 (leaf switch) that is directly connected to the host we get the following:
NExus9K# ping 172.16.8.199
PING 172.16.8.199 (172.16.8.199): 56 data bytes
ping: sendto 172.16.8.199 64 chars, No route to host
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 172.16.8.199 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
This switch is strictly L2
here is some config for reference
Nexus 6004 Primary
vlan 450
name P2P_VRF_SVI_DMZ
vlan 451
name P2P_VRF_SVI_Inside
vlan 600
name DMZ
vlan 652
name Management
vlan 680
name Inside
vrf context DMZ
vrf context Inside
vrf context management
ip route 0.0.0.0/0 172.16.52.1
vrf context peer-keepalive
vpc domain 99
role priority 1
peer-keepalive destination 10.200.50.2 source 10.200.50.1 vrf peer-keepalive
delay restore 120
interface Vlan1
interface Vlan450
description DMZ P2P to ASA
no shutdown
vrf member DMZ
ip address 172.16.230.1/29
ip router eigrp 100
no ip passive-interface eigrp 100
interface Vlan451
description Inside p2p to ASA
no shutdown
vrf member Inside
ip address 172.16.230.9/29
ip router eigrp 100
interface Vlan600
description DMZ
no shutdown
vrf member DMZ
ip address 172.16.0.2/22
ip router eigrp 100
hsrp 2
authentication text test1
preempt
priority 250
ip 172.16.0.1
interface Vlan651
interface Vlan680
description Inside Network
no shutdown
vrf member Inside
ip address 172.16.8.2/22
ip router eigrp 100
hsrp 1
preempt
priority 250
ip 172.16.8.1
interface port-channel99
description vPC Etherchannel
switchport mode trunk
switchport trunk allowed vlan 600,680
spanning-tree port type network
vpc peer-link
interface port-channel102
description vPC to Nexus 9372
vpc 102
interface Ethernet1/1
description vPC Peer Link 1.1
speed auto
channel-group 99 mode active
interface Ethernet1/7
description vPC Peer Link 1.7 to Nexus 9372 PRI
speed auto
channel-group 102 mode active
interface Ethernet2/1
description vPC Peer Link 2.1
speed auto
interface Ethernet2/7
description vPC Peer Link 2.1 to Nexus SEC
speed auto
interface Ethernet8/1
description keep-alive peer-link to ALNSWI02
no switchport
vrf member peer-keepalive
ip address 10.200.50.1/30
interface Ethernet8/2
description Uplink to ASA
switchport trunk allowed vlan 450-451
interface Ethernet8/9
description EIGRP PORT
interface mgmt0
vrf member management
ip address 172.16.52.3/23
line console
line vty
boot kickstart bootflash:/n6000-uk9-kickstart.7.0.1.N1.1.bin
boot system bootflash:/n6000-uk9.7.0.1.N1.1.bin
router eigrp 100
autonomous-system 100
vrf DMZ
router-id 172.16.0.1
default-information originate
vrf Inside
router-id 172.16.230.9
poap transit
Primary Leaf Nexus 9372
vlan 1,600,652,680
vlan 600
name DMZ
vlan 652
name Managment
vlan 680
name Inside
vpc domain 101
role priority 1
peer-keepalive destination 10.200.50.6 source 10.200.50.5 vrf peer-keepalive
interface Vlan1
interface Vlan652
no shutdown
interface port-channel101
vpc peer-link
vpc 102
sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 99
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 1
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po99 up 600,680
vPC status
id Port Status Consistency Reason Active vlans
102 Po102 up success success 600,680
interface Ethernet1/16
description HOST <<<<<<<<<<<<<<<<<<<<<<<<<<<< This is the host that we cant reach<<<<<<
interface Ethernet1/17
description SERVER1
interface Ethernet1/46
description keep-alive peer-link to ALNSWI04
no switchport
ip address 10.200.50.5/30
no shutdown
interface Ethernet1/47
description vPC Peer Link 1.47
channel-group 101 mode active
interface Ethernet1/48
description vPC Peer Link 2.48
interface Ethernet1/49
description vPC Link 1.49 to Nexus 6004 PRI
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
description vPC Link 1.53 to Nexus 6004 SEC
interface Ethernet1/54
interface mgmt0
ip address 172.16.52.5/23
line console
line vty
boot nxos bootflash:/n9000-dk9.6.1.2.I3.1.bin
sh vpc
Legend:
vPC domain id : 101
vPC role : primary
1 Po101 up 600,680
vPC status
So I confused on the ping status from the Leaf switch when it says "no route to host"
Any help is appreciated
Thank you
03-12-2015 01:03 PM
I am not sure how this helps in troubleshooting since if you create a static route back to n6k to reach hosts which are directly connected behind this switch.
in case of troubleshooting only, identify a free ip address in vlan 680 and create an SVI locally in n9k (interface vlan 680)so that it can resolve ARP for the hosts in vlan 680 and you can ping directly.
M
03-12-2015 04:13 PM
Creating another svi is not the point nor adding additional routes unless required for completing the flow. It's layer two switch so we should leave it at layer two. It had occurred to me that management is dedicated over a VRF (management vrf) which its gateway is the ASA FW. So from this point we know that the ASA can route and get to all subnets required.
I have put it down to an ASA being the point where things stop working.
as I said in my previous post I don't see any point, there is disadvantage using this way as troubleshooting approach, we are better off with the svi's on the N6K, but this is my own humble opinion.
