Host behind vPC not responding
Kemal Zuko
Level 3
Level 3
 Hello Again,
On our new test network that consists of two Nexus 6004's and two Nexus 9372's that run vPC between the two. The network VLANs live on the Nexus 6004's and extend down to 9K's via vPC links
On one of our 9K's we have a host in
switchport access vlan 680
Simple right? 🙂 well there is nothing simple about this network. From the nexus 6004 we can ping the host that sits behind vlan 680 but when we try to ping from the Nexus 9372 (leaf switch) that is directly connected to the host we get the following:
NExus9K# ping 172.16.8.199
PING 172.16.8.199 (172.16.8.199): 56 data bytes
ping: sendto 172.16.8.199 64 chars, No route to host
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 172.16.8.199 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
This switch is strictly L2
here is some config for reference
Nexus 6004 Primary
vlan 450
  name P2P_VRF_SVI_DMZ
vlan 451
  name P2P_VRF_SVI_Inside
vlan 600
  name DMZ
vlan 652
  name Management
vlan 680
  name Inside
vrf context DMZ
vrf context Inside
vrf context management
  ip route 0.0.0.0/0 172.16.52.1
vrf context peer-keepalive
vpc domain 99
  role priority 1
  peer-keepalive destination 10.200.50.2 source 10.200.50.1 vrf peer-keepalive
  delay restore 120
interface Vlan1
interface Vlan450
  description DMZ P2P to ASA
  no shutdown
  vrf member DMZ
  ip address 172.16.230.1/29
  ip router eigrp 100
  no ip passive-interface eigrp 100
interface Vlan451
  description Inside p2p to ASA
  no shutdown
  vrf member Inside
  ip address 172.16.230.9/29
  ip router eigrp 100
interface Vlan600
  description DMZ
  no shutdown
  vrf member DMZ
  ip address 172.16.0.2/22
  ip router eigrp 100
  hsrp 2
    authentication text test1
    preempt
    priority 250
    ip 172.16.0.1
interface Vlan651
interface Vlan680
  description Inside Network
  no shutdown
  vrf member Inside
  ip address 172.16.8.2/22
  ip router eigrp 100
  hsrp 1
    preempt
    priority 250
    ip 172.16.8.1
interface port-channel99
  description vPC Etherchannel
  switchport mode trunk
  switchport trunk allowed vlan 600,680
  spanning-tree port type network
  vpc peer-link
interface port-channel102
  description vPC to Nexus 9372
  vpc 102
interface Ethernet1/1
  description vPC Peer Link 1.1
  speed auto
  channel-group 99 mode active
interface Ethernet1/7
  description vPC Peer Link 1.7 to Nexus 9372 PRI
  speed auto
  channel-group 102 mode active
interface Ethernet2/1
  description vPC Peer Link 2.1
  speed auto
interface Ethernet2/7
  description vPC Peer Link 2.1 to Nexus SEC
  speed auto
interface Ethernet8/1
  description keep-alive peer-link to ALNSWI02
  no switchport
  vrf member peer-keepalive
  ip address 10.200.50.1/30
interface Ethernet8/2
  description Uplink to ASA
  switchport trunk allowed vlan 450-451
interface Ethernet8/9
  description EIGRP PORT
interface mgmt0
  vrf member management
  ip address 172.16.52.3/23
line console
line vty
boot kickstart bootflash:/n6000-uk9-kickstart.7.0.1.N1.1.bin
boot system bootflash:/n6000-uk9.7.0.1.N1.1.bin
router eigrp 100
  autonomous-system 100
  vrf DMZ
    router-id 172.16.0.1
    default-information originate
  vrf Inside
    router-id 172.16.230.9
poap transit
Primary Leaf Nexus 9372
vlan 1,600,652,680
vlan 600
  name DMZ
vlan 652
  name Managment
vlan 680
  name Inside
vpc domain 101
  role priority 1
  peer-keepalive destination 10.200.50.6 source 10.200.50.5 vrf peer-keepalive
interface Vlan1
interface Vlan652
  no shutdown
interface port-channel101
  vpc peer-link
  vpc 102
sh vpc
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 99
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 1
Peer Gateway                      : Disabled
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po99   up     600,680
vPC status
id     Port        Status Consistency Reason                     Active vlans
102    Po102       up     success     success                    600,680
interface Ethernet1/16
  description HOST        <<<<<<<<<<<<<<<<<<<<<<<<<<<< This is the host that we cant reach<<<<<<
interface Ethernet1/17
  description SERVER1
interface Ethernet1/46
  description keep-alive peer-link to ALNSWI04
  no switchport
  ip address 10.200.50.5/30
  no shutdown
interface Ethernet1/47
  description vPC Peer Link 1.47
  channel-group 101 mode active
interface Ethernet1/48
  description vPC Peer Link 2.48
interface Ethernet1/49
  description vPC Link 1.49 to Nexus 6004 PRI
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
  description vPC Link 1.53 to Nexus 6004 SEC
interface Ethernet1/54
interface mgmt0
  ip address 172.16.52.5/23
line console
line vty
boot nxos bootflash:/n9000-dk9.6.1.2.I3.1.bin
sh vpc
Legend:
vPC domain id                     : 101
vPC role                          : primary
1    Po101  up     600,680
vPC status
So I confused on the ping status from the Leaf switch when it says "no route to host"
Any help is appreciated
Thank you
31 Replies 31
Hi Kemal,
I have not looked at all config, however  a quick thought..If the switch is pure L2, you may not be able to ping it unless you have an SVI for that vlan present in it.
Madhu.
Hi Madhu,
Are you saying that I may need the SVI created and configured for an IP address?
That SVI already lives upstream on the core Nexus 6004. I am not 100% sure how this would work.
Dear Kemal,
I am not an expert on n9k, but what is the issue here?
are you able to ping the host in vlan 680 from n6k ? What i was saying you may not be able to ping the host from L2 only switch since it does not have any route to it.
M
  If the ASA is the gateway for 172.16.52.3 then the ASA would have to have a connection to the n6k and  statements pointing to everything that is on that N6k if you need to get to those networks.  When pinging from the 9k  then you have to specify which vrf you are pinging which in your case looks to be the management vrf .  On the nexus cisco plays loose with the ip route statements while its a route statement it is basically just a default gateway statement   for a L2 switch .  It works the same way on the L2 N5k's that we use. In our case though we chose to use a SVI  and an address that is allowed down the VPC's .
Yes,
The ASA is the gateway for all devices that have a MGMT IP. and correct it is directly uplinked to the n6k which are running EIGRP between the two.
Kemal
Is 172.16.52.1 the ASA we have been talking about in the other thread ?
And is it vlan 652 that is used for this IP subnet ?
And finally are you using the same link to the ASA that is also used for vlans 450 and 451 ?
If so you need to allow vlan 652 on that trunk link because currently it isn't.
Jon
Jon,
Yes that is the same setup as we were discussing in the vPC thread.
Yes, it is vlan 652 that is being used for the ip subnet.
Yes, Using the same link to the ASA that is also using the transit vlans 450 and 451
Okay but you are not allowing that vlan on the trunk link.
But as per my last post you can't because it is a vPC vlan.
So you need to -
1) create SVIs and configure HSRP for vlan 652
2) create a new non vPC vlan together with the SVIs and allow it on the dedicated trunk link between the switches and on the link connecting to the ASA
3) place the new vlan and vlan 652 into their own VRF
Jon
Jon,
So what you are saying is, move the MGMT connection from MGMT port on the Nexus to a SVI?
Vlan 652 is Management vlan
At the moment can you ping 172.16.52.1 from either N6K switch ?
Jon
Yes I can from all 4 Nexus switches
SWI01# ping 172.16.52.1 vrf MANagement
PING 172.16.52.1 (172.16.52.1): 56 data bytes
64 bytes from 172.16.52.1: icmp_seq=0 ttl=254 time=0.616 ms
64 bytes from 172.16.52.1: icmp_seq=1 ttl=254 time=0.494 ms
64 bytes from 172.16.52.1: icmp_seq=2 ttl=254 time=0.519 ms
64 bytes from 172.16.52.1: icmp_seq=3 ttl=254 time=0.516 ms
64 bytes from 172.16.52.1: icmp_seq=4 ttl=254 time=0.575 ms
--- 172.16.52.1 ping statistics ---
5 packets transmitted, 5 packets received, 0.00% packet loss
round-trip min/avg/max = 0.494/0.544/0.616 ms
Here is the setup for Management
ASA MGMT Interface  172.16.52.0/23 connects to a L2 Cisco 2960 MGMT switch
From there, there is an SVI 652 configured for 172.16.52.0/23 with the ip default-gateway 172.16.52.1 which is the ASA
From the MGMT switch (cisco 2960) port 1/0/43 goes to the MGMT on the Cisco Nexus 6004 MGMT intrface
interface GigabitEthernet1/0/43
 description Uplink to Nexus 9372 PRI
 switchport access vlan 652
 switchport mode access
On the Nexus 6004 here is the MGMT config
interface mgmt0
Okay, I didn't realise you had a totally separate connection on the ASA for management.
You won't be able to do the ping then as far as I am aware.
The management interface on the ASA will not pass through traffic from one interface to another.
So when you ping from the 9372 the traffic arrives on the management interface but the ASA routing table shows the route for 172.16.8.0/22 via the inside interface.
And it can't pass that traffic through from the management interface to the inside interface.
So it's nothing to do with your switch configurations and there is nothing you can do to make this work, as far as I am aware,  because of the way the management interface on the ASA works.
Jon
Yea, that is what I thought.
Ultimately we  could take the Managment interfaces on the n9K's and move them to a regular port, IP the sVI 652 for an IP address, apply the vlan to the interface and I think that might do it.
At this point this is very minor but it's something that has been bothering me.
It may be worth considering.
A lot people don't use the management port for this very reason.
Bear in mind that if you wanted to access your switches remotely then it won't work because your IP would not be from the 172.16.52.x IP subnet so the ASA won't pass that traffic.
You would need to be in the same IP subnet.
You may be better off doing what I suggested earlier as that way all traffic goes via the inside interface of the ASA and then you would be able to access your switch IPs remotely.
You can still control who could get that access via the ASA.
Jon
