Topology:
Nexus 7710 to FEX. no VPC configuration. Image: 7.2(1)D1(1)
ESX host is not running spanning-tree, port configured as trunk with VLANs.
When I hook an ESX host up to my FEX host port configured as a trunk, the port does not go into err-disable mode, the FEX host port shows up/up but I cannot connect to any of the trunked VLANs either.
Am i missing something? Thanks
Config is as follow:
interface Ethernet8/19
description FEX TO N2248TP
switchport
switchport mode fex-fabric
fex associate 101
channel-group 101
no shutdown
interface port-channel101
switchport
fex associate 101
interface Ethernet101/1/3
description FEX TRUNK PORT
switchport
switchport mode trunk
switchport trunk allowed vlan 10-50
spanning-tree port type edge trunk
no shutdown
Eth101/1/3 FEX TRUNK PORT connected trunk full a-1000 10/100/1000
Port Vlans in spanning tree forwarding state and not pruned
Eth101/1/3 none <----not learning vlans from ESX host
# sh spanning-tree int e101/1/3 <-----HIF port is in forwarding
Vlan Role Sts Cost Prio.Nbr Type
VLAN10 Desg FWD 4 128.4196 Edge P2p
VLAN20 Desg FWD 4 128.4196 Edge P2p
VLAN30 Desg FWD 4 128.4196 Edge P2p
VLAN40 Desg FWD 4 128.4196 Edge P2p
VLAN50 Desg FWD 4 128.4196 Edge P2p
***end of file***
