HOSTFLAPPING
zafarfor69
Community Member
hi i am receiving the mentioned below error on my distribution switches which are connected to each other via fiber and bundled with etherchannel (Po1) the mac address are access switches
spanning tree working fine and everything is fine as yet but these error occurance is annoying please let me know the solution
3/29/2008 12:45 10.1.4.202 Warning 1239: 1d18h: %C4K_EBM-4-HOSTFLAPPING: Host 00:1A:70:27:5E:0C in vlan 1 is flapping between port Po1 and port Gi2/6
3/31/2008 19:40 10.1.4.202 Warning 171: 04:00:59: %C4K_EBM-4-HOSTFLAPPING: Host 00:1A:70:27:6A:F6 in vlan 1 is flapping between port Po1 and port Gi2/5
6 Replies 6
Hi zafar,
To make sure that the Po1(etherchannel)and ports(etherchannel) of the connected switch are correctly configured.
Is there any servers/pcs configured by using lancard-teaming features?
Cheers
Thot
Hi Thot,
Po1 (Etherchannel) between two of our Dist./Core is working fine (using LACP)with other switches these are the MAC address of two (Linksys SRW2048)switches which are causing these errors
I have'nt configured any server with the teaming feature, these error does'nt appear when i shutdown the backup interface of the Access switches.
shiva_ial
Level 4
Level 4
hi,
try to figure out and wireless devices
you are connecting with which may also
one source of the mentioned probelm
Hi Shiva,
I have already isolated the Wireless devices from these two switches, wireless devices are connected to other switches which are working fine.
you are using VLAN 1 for any data traffic
