02-07-2007 07:28 AM - edited 03-05-2019 02:12 PM
Does the cisco 3745 support hot swap of network modules?
02-07-2007 07:42 AM
Not really but somethings can be swaped.
Check this link and rate if you find it usefull
02-07-2007 07:46 AM
Yes and No,
WIC cards can be installed hot, but hot-swap is not supported.
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a00800ab515.shtml
Some switch modules can be in-line inserted (hot swap) but it is always best to look at the installation instructions for the specific module you are concerned with.
