hotswap network module 9300
bbb bbb
Level 4
Level 4
Dear Everyone,
Want to ask if I can do hot swap or remove a 10G network module on an operating Cisco Cat 9300.
If possible, need to relocate the unused network module that is in a production environment to another deployment.
Thank you and best regards,
3 Accepted Solutions
Mark Elsen
  - Yes, that is possible, before  doing ,have an SSH session connected to the switch
            and use the command terminal monitor  (to get console messages)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
Yes, the module support OIR (Online Insertion and Removal).
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Dear, Thank you for the response. will check your advice.
Leo Laohoo
