How an Ethernet switch creates a collision domain on each port?
susim
Level 3
Level 3
Hi ,
8 Replies 8
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A switch port running in half duplex is basically the same as any other two hosts running half duplex between them.  When either host transmits, each has a chance to collide with a transmission from the other host.
As frames between switch ports are buffered, hosts on two different ports, even if they transmit at the same time, won't directly collide.  Again, though, if port is running half duplex, host can collide with switch port retransmitting the other host's traffic.  I.e. two hosts, on two different ports, behave (practically) as if they were directly connected.  The advantage of a switch, however, is another two hosts transmitting to each other won't collide between the two pairs, as they would on a hub.  I.e. on a hub A<>B frames may collide with C<>D frames, but they shouldn't on a switch.
If host ports are running in full duplex, there should be no collisions at all (which would also be true with a pair of hosts on a full duplex wire between them).
NB: above is just for unicast when switch "knows" destination MAC's port.
Hi Joseph
Thanks for reply
can you brief  if port is running half duplex, how  host can collide with switch port re transmitting the other host's traffic "
Disclaimer
Posting
Sorry, I don't think I can briefly explain half duplex Ethernet collisions. However, you should find much material on the Internet that does explain (but perhaps also not briefly).
Thanks again , if i rephrase the question
 Why are collisions possible between a switch port set to half duplex ?
Disclaimer
Posting
Because if both the switch port and connected host are running half duplex, if both start transmitting at about the same time, you get a collision.
If  there is only switch port set to half duplex and  the station is set to full duplex , the switch port will always see lot of collision . so the station has to re transmit all the frames ?
Disclaimer
Posting
That would be an incorrect configuration.  You want both to be full duplex or half duplex, not one of each.
If they are incorrectly mixed like that, interface will pass traffic, but besides collisions, you get other errors and very, very slow throughput.
Karan Puri
Hi Supportsib,
Switch has port phy which are connected via classic bus or switch fabric.
You may like reading this blog
http://etherealmind.com/what-is-the-definition-of-switch-fabric/
