09-21-2008 10:52 AM - edited 03-06-2019 01:29 AM
how can i configure etherchannel on a switch
09-21-2008 11:08 AM
Hello Raul,
look at the following link:
this is for a C3750 IOS based switch.
the member links must have the same config about speed, duplex, access vlan (if access port) or native vlan and list of permitted vlans (if a L2 trunk link)
A L3 etherchannel can be configured by configuring the logical interface port-channel X.
Very important for L2 trunks all changes in the list of permitted vlans has to be done on the logical port-channel X and not on the single member links otherwise some instabilities can occur.
Hope to help
Giuseppe
09-21-2008 02:45 PM
If you have ports of the same speed ,duplex etc it can be as simple as putting " channel-group X mode desirable or channel-group X mode active if you want to use LACP " on the ports you want to use .
