how can I configure my routing if my given addresses for different serial port are the same?
ch_2718
hi there, I am doing a static and EIGRP routing but I cant connect the other routers for they have a the same network addresses, but I need some clarification on how will I differentiate the network address specially Router1 needs to be configured with both EIGRP and STATIC
balaji.bandi
You need to subnet in to small portion of addressing 10.10.40.0/24
depends on the users in the network  as per the diagram you need 3 users network IP address, so i do this as example :
10.10.40.0/26
10.10.40.0 10.10.40.1 - 10.10.40.62 10.10.40.63
10.10.40.64 10.10.40.65 - 10.10.40.126 10.10.40.127
10.10.40.128 10.10.40.129 - 10.10.40.190 10.10.40.191
10.10.40.192 10.10.40.193 - 10.10.40.254 10.10.40.255
First spoace for p2p address you need /30
example :  ( Bold us usable )
10.10.40.0 10.10.40.1 - 10.10.40.2 10.10.40.3
10.10.40.4 10.10.40.5 - 10.10.40.6 10.10.40.7
10.10.40.8 10.10.40.9 - 10.10.40.10 10.10.40.11
10.10.40.12 10.10.40.13 - 10.10.40.14 10.10.40.15
You can run IGP easy to manage than static.
BB
ch_2718
thank you for the answer but the instruction is to do the static and eigrp routing ,so how will this be possible?
we are not sure what is your home work given to you, you giving to us bit and piece information, suggest you to read some documents and understand and learn, in real environment  this help you,
as per the information, this can done both static routing and dynamic routing.
So as per the information run Eigrp process R0 and R1, make static route on rest all.
I can provide full config, but i would not do that here, since this is your learning lesson - but we are here to support if you stuck any where.
BB
