How can I view module type or model in a router using CLI?
vlad110226
I have a 2800 series router, i need to check what type of interface module installed in my device? what command on the router to be able to view this? thanks
5 Replies 5
Edison Ortiz
show interface should provide that information as well as show controller.
thanks bro
mohammedmahmoud
Level 11
Level 11
"show diag" should give you full info about the attached modules.
HTH,
Mohammed Mahmoud.
thanks bro..
Sh diag would give you a detail description of the modules installed.
The ISR routers like the 2800 also support the Sh inventory command which will provide a brief description of all the modules present.
Narayan
