bandwidth allocation
csco10983028
Community Member
We are creating two VLAN with a 1800 series router for two branch office each 64 Kbps(Total 128 Kbps).Can Any one tell me the configuration command for creating the VLAN for the above.
spremkumar
Level 11
Level 11
On which port you are trying to create the vlans ?
are you trying to create vlans on the ESW module ?
if yes you can refer the below link for the same..
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a00808066b8.shtml
regds
