how can outside global hosts identify inside local ?
sharath413
If using private addresses in my LAN network and a NAT on the router,How can outside hosts(on Internet) can ping my inside local(private address) hosts?
thank you.
5 Replies 5
Dan Lukes
You have no full Internet connectivity for your local hosts. You can't ping your hosts.
So,what is the possible solution?
Do I need to use public IP for LAN hosts?
For the hosts you wish to be reachable for ICMP ping from outside ? Yes.
Hello
By NAT static translations
example:
ip nat inside source static 192.168.1.10  1.1.1.10
<  thus internet hosts(outside) would ping 1.1.1.10 to reach 192.168.1.10
res
Paul
Kind Regards
Paul
Thank you for the answer.But,what  if I use PAT?
