11-02-2006 06:22 AM - edited 03-05-2019 12:35 PM
router ospf 1
router-id 155.145.10.185
log-adjacency-changes
network 155.145.0.0 0.0.255.255 area 30.0.0.0
distance ospf external 130
11-02-2006 06:39 AM
What is the problem? The config looks fine.
11-06-2006 10:09 PM
I was not aware that instead of area 30 we can use area 30.0.0.0 .
11-06-2006 10:07 PM
Hello All,
I am able to got he Answer....here is the answer...........
Cisco IOS? software supports area IDs expressed in IP address format or decimal format, for example, area 0.0.0.0 is equal to area 0. So the 30.0.0.0 is area 30.
11-06-2006 10:35 PM
Strictly speaking, that is not quite correct. The area 30 (which is in decimal) is actually 0.0.0.30 when translated to dotted octet notation. Which means that area 30.0.0.0 is actually 256*256*256*30 = area 503316480 in decimal.
Hope that helps...
Paresh
PS> Pls do rate helpful posts...
11-06-2006 10:48 PM
Can you tell me what is the meaning of area 30.0.0.0 in below command.
Can you plz explain your above statement.
11-06-2006 10:53 PM
Firstly, you should not read too much into the actual number that an OSPF area is given - the only important thing that the identifier does it to distinguish one area from another (the actual numbers are really quite meaningless and you may as well give them names for the function they serve).
Having said that, your network statement will effectively enable OSPF operation over all interfaces with an IP address that falls within 155.145.0.0 and 155.145.255.255. In addition, it will place these interfaces in OSPF area 30.0.0.0.
Pls do remember to rate posts.
Paresh
11-06-2006 11:09 PM
I know how ospf network command works in ospf ,as I seen Do you mean area 30.0.0.0 is = area 30 ?
Akber.
11-06-2006 11:13 PM
Not quite, if you look back at my first post, you'll see that 30.0.0.0 is not area 30.
Area 30 in dotted octet notation is actually 0.0.0.30.
Paresh
PS> Pls rate all posts..
11-06-2006 11:26 PM
Paresh,
can u tell me what is this command meaning
network 155.145.0.0 0.0.255.255 area 30.0.0.0,
specifically wht is the meaning of area 30.0.0.0?
11-06-2006 11:30 PM
I'm obviously not answering your question correctly :-), but it's probably because I can't quite say what your actual question is...
The 'area 30.0.0.0' bit simply means that the network statement refers to OSPF area 30.0.0.0, which in decimal is area 503316480.
Paresh
11-07-2006 12:59 AM
Dear Paresh,
Let me explain you my question --
why we are using 30.0.0.0 below inplace of some number
Ex:-
Normally the command would be
network 155.145.0.0 0.0.255.255 area 1
11-07-2006 01:03 AM
Alright, that's a lot clearer...
There is no particular technical reason why one would use the first format in place of the other. Both are equally valid and in fact, they both end up being stored internally as a 32-bit number. It is merely a matter of convention as to which format you use. The bottom line is that either form is valid and there are no real reasons why one would use one format instead of another.
Hope that helps.
Paresh
PS. Pls do rate posts
04-13-2007 02:01 AM
hi,can any one tell me how do we calculate cost on a serial interface in ospf routing.
