How can we set Memory and CPU Threshold for Cisco 3650 Switches
CSCO12094806
Hi we are planning to configure CPU and Memory Threshold Notification for Cisco 3650.
we need to set below mentioned Processor, IO memory threshold and memory reservation for critical notification.
memory free low-watermark processor <threshold>
memory free low-watermark io <threshold>
memory reserve critical <value>
when we check the configuration we found following values we can configure:
sw(config)#memory free low-watermark processor ?
<1-3994575> low water mark of memory in KB
sw(config)#memory free low-watermark iO ?
what will be the best practices value for cisco 3650 24TD-S (IOS: Denali 16.3.6) switches (two switches in a stack).
expecting valuable inputs.
thanks in advance.
it depends on the values you see when you issue the 'show mem' command. You need to monitor these values over time to establish a baseline value.
Can you post the output of 'show mem' ?
Hi Georg Pauwen, Sorry i didn't collect the "Show memory" details.
we have "show processes memory" pls refer the attachment.
tomorrow we will share the "show memory" details.
