Showing results forĀ
Search instead forĀ
Did you mean:Ā
How create alias which backup running config on startup and tftp server simultaneously?
josedunet
Hello all,
How may I create one alias " wr me " which backup simultaneously the configuration of a router  or switch in start-up and on a TFTP server?
Thanks in advance.
Best Regards
josedunet
I have just seen that the archives command allows to make it.
But I would like I could put the date of the backup in the name of the file. How may I make it?
Thanks in advance.
$t  used in the
archive
  path ....
command might make it.
But I never tested that with TFTP and the example
http://www.cisco.com/en/US/customer/docs/ios/fundamentals/command/reference/cf_m1.html#wp1049550
or
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_m1.pdf
is using disk0 to save the archive files.
But according to the Usage Guidelines this might work with TFTP, too, I hope.
BR,
Milan
