Showing results forĀ
Search instead forĀ
Did you mean:Ā
How do I configure a C3750-X-12S-E?
ashfieldm
We recently purchased a C3750-X-12S-E device. I am having  a brutal time trying to configure it. I've tried:
1. The web interface. Using IE9 on a Windows7 device, the web interface allows me to login, but doesn't load properly. By that I mean, I'll click on something in the left menu and it doesn't fully come up in the right-side pane. Basically rendering it unusable. It did allow me to do Express Setup, but that was about it.
2. The Cisco Network Assitant. When I try to bring it up in CNA (v5.6.3), the device shows as unsupported. A quick check of the Release Notes for CNA shows that it is not listed as one of the supported models of 3750-X device as you can see below:
"Catalyst 3750-X switches (WS-C3750X-24T-L, WS-C3750X-48T-L, WS-C3750X-24P-L, WS-C3750X-48P-L, WS-C3750X-48PF-L, WS-C3750X-24T-S, WS-C3750X-48T-S, WS-C3750X-24P-S, WS-C3750X-48P-S, and WS-C3750X-48PF-S)"
3. When I try to SSH to the device for CLI access, i cannot seem to get on to configure it. I enabled Telnet via the web interface (one of the few things it allowed me to do), but I still cannot telnet either. I tried SSH'ing and it prompted me for login, but I coulnd't get on, using the password I setup in Express Setup. I tried a variety of usernames but no luck.
Probably the best bet is the CLI via console it would seem (although being relatively new to the CiscoIOS, I was hoping for some gui configuration tools!).
Any help is appreciated.
Thorkar12
I think the best way to configure the switch is via CLI.
What kind of configuration you have to do?
A other way is the Web GUI do you have tried a other Browser? May be you have to check the compatible modus of the IE
Kind regards
SunilKhanna
Here is the configuration guide
Sunil
Regards, Sunil Khanna
smogra
The best way to configure the switch is via CLI.
Try consoling into the device and see if you can configure from there.
What exact confiurations you are looking for?
Sweta
