How do I configure it so I can Hit a Wan ip address from My Lan?
dallas590
Namely, I want to be able to use the wan IP address for MY Terminal Server, WSUS Server, etc from both My LAN users and WAN users.
I should mention that I am using a Cisco 1811 and SDM Version 2.41
John Blakley
If you're wanting someone to come into your network to use your TS, you'll need to configure static nat and map your public IP to a private address on the inside.
HTH,
John
HTH, John *** Please rate all useful posts ***
I can already hit them all from the outside, and have this set up.
I want to be able to hit my servers on my 192.168.1.*, using their Wan addresses 205.*.*.20 from on the LAN (192.168.1.*).
Something to tell my internal network machines that the wan address given should be redirected to in-house.
I'm not sure this will be possible, but I've never had to configure it.
John
