How do I connect remotely to my switch or router?
djchitown
Hello, I have four 2521 routers and three 2954 switches.  I connected my ISPs modem from the ethernet port and plugged it into port 24 of one of my switches.  I also configured the switch for VTY access and gave it a login password.  I would like to log into the switch to configure it and telnet into all the other devices from a remote location.  But I am unable to ping the public address assigned to me by my ISP.  So I can't even telnet to the switch.  Help
Mizanul Islam
Hi ,
When physically access the 2521 router you below test:
1. Ping to 8.8.8.8
2. Telnet to internal pc
3. You must be configure Enable password.
Before you telnet from remote location first you check the ping test then you telnet.
I hope it could help you
Parosh
This discussion has been reposted to the LAN, Switching and Routing community.
