how do i disable wirless on 3850x stack switch
gscalia01
I would like to know if the wireless features are enable by default on the 3850X and if so i do i disable wireless on the stack switch since we're not doing Cisco wireless.
Jack
Saurav Lodh
Level 7
Level 7
3850(config)#no wireless mobility controller
3850(config)#no wireless management interface x
Thanks for the info I appreciate it.
I do have another question in regards to the 3850 switches I have 4 switches stacked as one and I noticed in the config the redundancy mode is set to SSO and and i do see 2 members and one standby and one active. . How does SSO works on a stacked switch?
On the 3750 you have a master and members which is straight forward but the 3850 stack setup is a liitle confusing to me . Any explanation and info will be greatly appreciated.
Jack
