How do I enable Firewall and VPN feature on Cisco 1941?
howardwen
hello, I got a Cisco 1941, and found just IP feature, not have Firewall and VPN feature.
johnd2310
Level 8
Level 8
What permanent licence do you have on your router? You will need to buy the security and ssl licence to get firewall and ssl vpn on your router. If you would like to evaluate these feature, just activate the evaluation licence.
John
**Please rate posts you find helpful**
