How do I setup a PVLAN between two Cisco ME 1200 switches...
mohdyasir.02
Hi all,
Below is the attached network topology...
Andrew Khalil
@mohdyasir.02
Can you please explain why specially private vlans? as you topology can be achieved using normal vlans
Please don't forget to rate all helpful responses and mark solutions,
Bst Rgds,
Andrew Khalil
Thanks for the quick reply...
My existing switch is running with PVLAN....
Deepak Kumar
I checked datasheet and found PVLAN is not supported on this switch model number.
Datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/me-1200-series-carrier-ethernet-access-devices/datasheet-c78-731467.html
Configuration Guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/metro/me1200/hardware/guide/me1200_hig.pdf
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
