10-11-2010 08:12 AM - edited 03-06-2019 01:26 PM
How do I tell which Catalyst 4506 chassis I have, I need to upgrade it, and only have remote access. show version etc., doesn't show whether it is an E type or not.
10-11-2010 08:17 AM
A "show inventory" should supply the needed info.
Dan
10-11-2010 08:21 AM
Dan, I have tried that and
it doesn't show the chassis as a Cat4506-E, on a swi
tch I believe to be an E type switch
10-11-2010 08:46 AM
The "show inventory" will show:
------------------ show inventory ------------------ NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506-E 6 slot switch " PID: WS-C4506-E , VID: V02, SN: Or------------------ show inventory ------------------ NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506 6 slot switch " PID: WS-C4506 , VID: V07, SN: If it doesn't show as WS-C4506-E, then it's not, or you've located a DDTS.
If you think it is an E chassis, I would recommend a TAC case to sort it out.
Dan
10-11-2010 08:49 AM
Thanks Dan, I'll get the someone to physically check the switch.
10-11-2010 09:59 AM
Show idprom chassis will show you what it is ...
