Bookmark
Subscribe
8458
How do I use a public IP Address on the LAN with Cisco 1905 Router
premvishwakarma
I have multiple public IP addresses (5 nos ) got from ISP.
I have Cisco 1905 router with 2 Ethernet port as GE0/0 and GE0/1 respectively.
I have configured one of public IP address in one of router ethernet  port GE0/0 and another port GE0/1 which is use as a LAN subnet.
Where I have created NAT, so network devices can communicate on LAN using private IP addresses.
Now, I want to use rest of free public IP address on host of LAN subnet behind  Router.  So I can directly communicate the devices on public IP address from outside. We don't want to use port forwarding of single public ip address.
Please suggest the solution for the same.
Prem Vishwakarma
7 Replies 7
what are the addresses ? LAN address and host addresses need to be in the same segment, so your only option would be to further subnet the public addresses you have been given. That is not likely to be possible, since the ISP has probably given you continuous addreeses.
Or you could use static 1-on-1 natting...
Thanks for the reply !!
We have public address are 5 nos. of same subnet  10.25.X.X/29.
For LAN we are using 192.168.X.X/24.
Our some host will  be on LAN subnet  192.168.X.X/24. and
two host required public IP directly on NIC 10.25.X.X/29
I have attached the topology diagram.
Prem V.
bridging could work here, if you connect the two hosts that need a public IP address to a different interface on the router.
Post the configuration of your router, I will try to fill in the necessary bits and pieces for that...
Here are My Router Configuration ....
CISCO1921#sh run
Building configuration...
Current configuration : 1950 bytes
! Last configuration change at 11:18:44 UTC Mon May 29 2017 by cisco
version 15.4
service password-encryption
hostname CISCO1921
boot-start-marker
boot-end-marker
enable secret 5 $1$6ooZ$dNRnrTUOVOd5XdP70Yab1
no aaa new-model
ip name-server 4.2.2.2
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FGL2309251CB
username cisco privilege 15 password 7 094F445G67H95F
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description "Internet"
 ip address 10.21.X.X 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description "LAN"
 ip address 192.168.0.250 255.255.255.0 secondary
 ip address 192.168.12.74 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Serial0/1/0
 description "Connectivity another end"
 ip address 172.16.2.1 255.255.255.252
interface Serial0/1/1
 no ip address
 shutdown
 clock rate 2000000
ip default-gateway 10.25.X.X
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.25.X.X
ip route 172.20.31.0 255.255.255.192 172.16.2.2
ip route 172.20.31.192 255.255.255.224 172.16.2.2
ip route 192.168.74.0 255.255.255.0 172.16.2.2
access-list 101 permit ip 192.168.12.0 0.0.0.255 any
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login local
 transport input telnet
 transport output telnet
scheduler allocate 20000 1000
end
CISCO1921#
CISCO1921#
CISCO1921#sh ip int bri
Interface                  IP-Address      OK? Method Status                Prot
ocol
Embedded-Service-Engine0/0 unassigned      YES NVRAM  administratively down down
GigabitEthernet0/0         10.21.X.X YES NVRAM  up                    up
GigabitEthernet0/1         192.168.12.74   YES NVRAM  up                    up
Serial0/1/0                172.16.2.1      YES NVRAM  up                    up
Serial0/1/1                unassigned      YES NVRAM  administratively down down
NVI0                       10.21.X.X YES unset  up                    up
CISCO1921#
Prem V.
sorry for the delay. The problem is that you have only two Ethernet ports, one of which is used for the Internet connection. Either way, with the configuration below (important parts are marked in bold), you can assign public IP addresses to the hosts connected to GigabitEthernet0/1. The default gateway for the hosts needs to be the IP address of BVI1.
version 15.4
hostname CISCO1921
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
redundancy
bridge irb
bridge 1 protocol vlan-bridge
bridge 1 route ip
no ip address
shutdown
bridge-group 1
duplex auto
speed auto
bridge-group 1
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
interface bvI1
ip nat outside
ip address 10.21.x.x 255.255.255.248
ip http server
ip nat inside source list 101 interface BVI1 overload
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login local
end
Thanks for the information.
I'll implement the configuration and update you on the same.
Just want to confirm,
Do I need additional port in Router.
OR
The configuration you shared will be work on the existing port.
Prem.
try using a secondary IP address on the bridged interface:
 bridge-group 1
 ip address 192.168.12.74 255.255.255.0 secondary
 duplex auto
 speed auto
I am not sure this will work though. If not, yes, you need another interface for your LAN hosts with private addresses...
