how does a switch choose its default source interface
curtmcgirt
Level 3
Level 3
i have a stack of 3750x, with minimal configuration. there are two vlans, and two vlan interfaces with IP addresses. when i ping out from this switch to another host, it picks vlan1's ip address as the source automatically. i tested this by doing two pings with extended options using each vlan's interface as the source, and got different results. i'm just curious how the switch decided to use the first vlan's ip address as a source if i didn't explicitly tell it to.
11 Replies 11
Arumugam Muthaiah
Usually when you perform the normal ping, the source address of the ping packet would be the address of the outgoing interface. When a normal ping command is sent, the source address of the ping is the IP address of the interface that the packet uses to exit the switch.
If an extended ping command is used, the source IP address can be changed to any IP address on this switch. The extended ping is used to perform a more advanced check of host reachability and network connectivity. The extended
ping command works only at the privileged EXEC command line. The normal ping works both in the user EXEC mode and the privileged EXEC mode.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
there are two interfaces with ip addresses.
i can telnet to either of these ip addresses remotely to manage the device.
but when i do a simple ping FROM the device, it defaults to one of those interfaces. how did it decide to use one interface instead of the other as a source?
Based ot its routing table, the switch choses the outgoing interface when Pinging to any device.
And as Aru said already, it's using the outgoing interface IP address as the source IP address of the Ping packet.
BR,
Milan
"show ip route" on this switch is empty. there is no routing table. neither interface has a default gateway set. it is a layer 2 switch.
so again, how is the switch choosing which interface to use as its source by default?
STK1#show ip route
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
STK1#show run int vlan202
Building configuration...
Current configuration : 121 bytes
interface Vlan202
  ip address 10.160.6.254 255.255.255.0
no ip redirects
no ip unreachables
end
STK1#show run int vlan203
Current configuration : 125 bytes
interface Vlan203
  ip address 10.160.13.254 255.255.252.0
no ip redirects
no ip unreachables
end
STK1#ping 10.242.2.86
Sending 5, 100-byte ICMP Echos to 10.242.2.86, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
STK1#ping 10.242.2.86 source 10.160.13.254
Packet sent with a source address of 10.160.13.254
Success rate is 0 percent (0/5)
Strange,
with such a configuration the switch should be able to reach directly connected subnets only.
So ping 10.242.2.86 source 10.160.6.254 works OK?
Isn't there any L3 device in your LAN with proxy ARP enabled?
What does trace  10.242.2.86 show in the output?
BR,
Milan
Milan,
ping 10.242.2.86 source 10.160.6.254 works just as plain old ping 10.242.2.86 works.
there is an ASA firewall at 10.160.6.1 that i do not manage, and it does not respond to icmp so a trace from the switch to 10.242.2.86 is just a bunch of asterisks.
10.160.6.1 would be the default gateway if i had set it, but i didn't. what's proxy arp?
I would like to add some points.
  • Proxy ARP can help machines on a subnet reach remote subnets without the need to configure routing or a default gateway.
  • Proxy ARP must be used on the network where IP hosts are not configured with a default gateway or do not have any routing intelligence.
Refer:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094adb.shtml
I hope Milan would like to understand that is there any Layer 3 device in LAN segment which is enable with Proxy ARP which will reply to source behalf of the destination network.
1. does your neighboring device has the route for both network 10.160.6.254 & 10.160.13.254?
2. Can you reach any other IP Address on your neighboring device from both vlan?
3. may be your neighboring device or remote network doesnt have route to reach vlan 203 10.160.13.254, hence it ccould drop the ping when using vlan 203 as source
4. Verify the vlan 203 mapped to any interface and it is up.
5. Please share the show run from the switch.
Aru
just to add what Aru said:
If proxy ARP is working in your case, you should be able to see an APR entry for 10.242.2.86 in the switch ARP cache by issuing
show arp
command.
And the MAC address assigned to 10.242.2.86 should be the MAC address of the device providing the proxy ARP service.
HTH,
Milan
i'm going to guess it's the proxy arp thing. it would make sense. there is a load balancer out in this DMZ LAN as well, so the firewall does not have an interface in the 13 subnet. host machines in the 13 subnet use the load balancer as a default gateway.
internal network (10.242.2.86)
    ->Firewall
DMZ network (10.160.6.1) (vlan 202)
     ->F5 Load balancer
load balanced host network (10.160.12.18/22) (vlan 203)
we've seen a few weird routing issues from hosts in the the 12-13 network because of that F5. now that you mention it, those may be because the firewall has no route to the 12-13 network.
from 10.242.2.86 (off of the Inside interface of the firewall)  i can ping BOTH 10.160.6.254 and 10.160.13.254 (off of the DMZ1 interface of the firewall).
from 10.160.6.254, i can ping 10.242.2.86. but from 10.160.13.254, i cannot ping 10.242.2.86.
10.242.2.86 is in the show arp results. i cannot verify that the mac address is the firewall's since i don't own that firewall, but i would assume that it is.
so before i even attempt to ping 10.242.2.86 from the switch, is the switch aware that there is a proxy arp off of the .6 interface, but NOT off of the .13 interface? we've established why the 6 interface works and the 13 doesn't, but i'm still confused how the switch automatically knew to use the 6 by default.
if you are in the same subnet as the FW, you can try to Ping it.
Even if no reply to Ping, it should reply to the ARP request and you should see its MAC in your ARP cache.
I guess the switch sends an ARP request from ALL its L3 ports when finds no routing entry for a destination out of its directly connected subnets?
As a last chance try?
BR,
Milan
yes, pinging the firewall did add the same mac address to the arp cache. and that makes sense that it sends an arp request and just uses whichever interface gets the first reply. thanks everybody for your help and insight.
