How does load balancing work if you have 2 routers?
rshum
Just working some theory through my head and I'm at a brick wall. Here's the sceneario:
1 segment with 2 routers. Each of the routers have a 10mbs WAN circuit to the same destination terminating on 2 routers.
Say there's a HSRP interface between the 2 routers in the same LAN segments.
How would load sharing across the two WAN links work?
2 Accepted Solutions
fb_webuser
Level 6
Level 6
for load sharing, implemet GLBP (gateway load balancing protocol) in lieu of HSRP. there are similarities in commands. for detailed infor google GLBP.
Posted by WebUser Neeraj Jagga from Cisco Support Community App
5 Replies 5
fb_webuser
Level 6
Level 6
Thanks guys, I forgot about GLBP. I guess back before GLBP we used to have 2 default gateways on each segment 1 for each HSRP address and have the users split between them.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Yes, especially mHSRP, but you could also, with some routing protocols, start with one router and use the other path.  This might perform better than GLBP as GLBP ties to MACs and routing round robins on flows.
Another possible alternative might be OER/PfR.  OER/PfR also performs dynamic load balancing.
fb_webuser
Level 6
Level 6
Hi, we featured your question on Page. Check out some of the responses here: http://www.facebook.com/CiscoSupportCommunity/posts/382613405105023
Posted by WebUser Cisco NetPro from Cisco Support Community App
