How many Etherchannels are supported in Catalyst 3750-E
shuaibasghar
Hello Dear,
                    I am working in an evironment where i have to use more etherchannels, kindly tell me the way that how many etherchannels could we create on Cisco Switch 3750 e. do they can utlize high process resources of CPU.
Shuaib Khawaja
ciscoamit_497
Hi Shuaib,
Please find the below two links that will help u to understand all basics of etherchannel on 3750--
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
Hope this would be helpful to u...
Amit
***********Please rate helpful info*********
Raju Sekharan
on 3750
• Up to 48 EtherChannel groups are supported per stack.
link: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
Thanks Amit & Raj,
                              The problem is that when i am going to configure Multilayer Sw 3750 which is used in our productional environment. it shows that not more than 6 etherchannels are supported and it only 6 port-channels do you help me in this issue how can create more etherchannels.
Shuaib Khawaja
Hi Shuaib,
do you get an error message when u configure the 7th etherchanne e.g.?
what tells u that u can't configure more than 6?
regards,
Sebastian
